Question about Sony Video Game Consoles & Games
I have connected my ps3 to a HDMI cable into my t.v but would like to connect my ps3 via the av output socket on the side of my t.v how do i change the setrtings on my ps3 to enable this
Go into settings on the ps3 and video settings and change the settings from HDMI to AV plug in the AV cable and it gives you a few seconds to choose ok and disconnect the HDMI cable and thats it
Posted on Sep 09, 2008
PS3 HDMI - Sony Bravi KDL-40V2000 Problem
  • Have your ps32_bing.gif in standby mode (red light).
  • Now, press andhold the power button in the front down. Your ps3 will beep twice. Letit go almost exactly after you heard the second beep.
  • Wait 10-15 seconds. A display will show up, and just answer yes to all!
try this
May 08, 2010 | Sony Playstation 3 (PS3) Console
When i connected my ps3 and plasma via a hdmi cord, i was asked "connect via hdmi - yes/no". i selected yes. Subsequently my hdmi card is faulty on the plasma and now have connected via av cables again but...
Ok you just have to do a video reset on the system, this is easy. first turn the system to standby/off with just the red light on. Then hold the front power switch (the system will turn on) till it beeps twice and shuts down. Then turn the system back on, this will reset the video/audio output to its default settings which are AV.
Dec 02, 2009 | Sony Playstation 3 (PS3) Console
My PS3 will not play sound on my Sony Bravia HDX275 surround sound system. I have the HDMI cable plugged from the PS3 to the TV. I have another HDMI cable from the receiver to the TV as well as a opitcal...
Adjust the system's audio output settings. These settings are mainly used when the system is connected to audio devices that support digital audio output, such as AV amplifiers (receivers) for home entertainment systems.
1.
Confirm the formats supported by your audio device.
Settings vary depending on supported formats. For details, refer to the instructions supplied with the audio device.
2.
Select in_soundset.gif (Sound Settings) under in_setting.gif (Settings) in the home menu.
3.
Select [Audio Output Settings].
4.
Select the input connector on the audio device. Channel numbers and audio formats that are supported vary depending on the connector in use.
soundoutput001.jpg Input connectors on the TV or AV amplifier (receiver) PS3™ system output connectors Channels that can be used for output 2 Ch. 5.1 Ch. 7.1 Ch. HDMI HDMI OUT connector in_maru.gif in_maru.gif in_maru.gif Digital Out (Optical) Digital Out (Optical) connector in_maru.gif in_maru.gif - Audio Input Connector / SCART / AV MULTI AV MULTI OUT connector in_maru.gif - - 5.
Select audio output formats.
Select all output formats that are supported by the audio device in use. If [Audio Input Connector / SCART / AV MULTI] is selected in step 4, the screen for selecting audio output formats will not be displayed. If [HDMI] is selected, you can also select to automatically set the audio output format. (In this case, the HDMI device must be turned on.)
soundoutput003.jpg 6.
Check your settings.
You can go back to the previous screen and revise the settings by pressing the in_left_key.gif button.
soundoutput002.jpg 7.
Save your settings.
The audio output settings are saved on the system.
Hints
  • [Linear PCM 2 Ch.] audio is set to be output from all output connectors by default. If you change the audio output settings, audio will be output only from the connectors that were set.
  • If you change the audio output settings, the system will no longer be able to output audio from multiple output connectors at the same time. For example, if your system is connected to a TV via an HDMI cable and to an audio device via a digital optical cable and you switch to [Digital Out (Optical)] under [Audio Output Settings], audio will no longer be output from the TV. To output audio from the TV, switch the setting to [HDMI], or select in_setting.gif (Settings) > in_soundset.gif (Sound Settings) > [Audio Multi-Output] and set the option to [On].
  • If you select [Linear PCM 2 Ch. 88.2 kHz] or [Linear PCM 2 Ch. 176.4 kHz] in step 5, sound may be intermittent or may not be emitted from some audio devices.
  • When using an HDMI cable, only [Linear PCM 2 Ch.] audio will be output from PlayStation®2 and PlayStation® format software. To output Dolby Digital or DTS audio, you must connect the PS3™ system and the audio device using a digital optical cable and switch to [Digital Out (Optical)] under [Audio Output Settings].
  • If a device that is not compatible with the HDCP (High-bandwidth Digital Content Protection) standard is connected to the system using an HDMI cable, video and/or audio cannot be output from the system.
(Information taken from here)
Hope it helped.
Nov 18, 2009 | Sony Playstation 3 (PS3) Console
PS3 doesn't work with tv anymore
did you move the ps3 while it was on. If you did the reset for AV should repair both the AV problem and your HDMI as well. Shoot me a message back if it works or doesn't.
Thx
Aug 01, 2009 | Sony Playstation 3 (PS3) Console
Av connections not giving signal to tv
you have to manually change the output in the settings menu back to ANALOG Using an HDMI TV or monitor 1st, when you select RCA, or AV output and restart, it will work, but when you switch back, you have to change it (back to HDMI output) on the analog monitor, or use analog TV inputs, then reboot PS3 and connect HDMI.
I do not know why Sony did not make this switch automatic and self scanning on boot, but alas I have had the same issue, so I know this is your problem, not the AV cables.
Please give a fixya rating if you find this solves your problem, Thanks for the question
Apr 12, 2009 | Sony Playstation 3 (PS3) Console
I need to know how to run my ps3 thru the optical wire to my hdtv
Before you start ensure that you read the TV instruction manual to know which resolution supports it. Do not switch on the TV and your console
You can connect your Playstation 3 to your TV in three different methods:
  1. Connecting with an AV cable
  2. Connecting with an HDMI cable
  3. Connecting with an Optical Cable
Connecting with an AV Cable:
  1. You are supplied with a Composite AV cable which would typically look like the below image
  2. Connect the AV Multi Out Connector to the socket on the back of your PS3 Console.
  3. Match the colors of the Jacks with the connectors on the TV which says "Video in".
Connecting with an HDMI Cable:
HDMI cable is not supplied with the PS3. You need to purchase it seperately. This cable would enhance the audio-video quality of your TV.
  1. Just connect one end of the connector to the HDMI OUT connector socket on the back of the console
  2. Connect the other end to the socket on the back of your TV which says HDMI IN.
Connecting with an Optical cable:
You need to purchase an Optical cable if you wish to connect your PS3 console through a digital audio device (Home theater, AV receiver etc.,). You need to connect Video ouput seperately with a help of Video output cable (HDMI, AV Cable etc.,)
  1. Connect one end of the optical cable to "Audio Out" socket on the console
  2. Connect the other end to the audio receiver.
Note: You can also connect your console to the Internet to use the Playstation 3 internet capabilities. Here's how you do it:
The Playstation 3 only supports 10BASE-T, 100BASE-TX and 1000BASE-T type networks. It needs a High speed internet connection. Do not connect it to a standard telephone connection or cables that are not supported. It might cause a malfunction or damage to the system.
Dec 11, 2008 | Computers & Internet
PS3 hdmi connection
With your PS3 on standby (red light) hold the on/off button down until it goes green and then back to red. This restores your PS3 to "factory settings", i.e. it is waiting for you to tell it how you want it to connect to your TV. Now disconnect any HDMI cables you may be trying to use and connect your PS3 to your TV via a scart connection. Now switch your PS3 on and turn to your AV channel and you should have both sound and pictures.
Oct 24, 2008 | Sony Playstation 3 (PS3) Console
PS3 No picture or sound
When you connecting sony via hdmi sony and tv must be shut down.First turn on sony then tv.Connect also and av cable or scart then go to sony settings and change out signal via hdmi or scart or av cabel and confirm.That should work
Jun 25, 2008 | Sony Playstation 3 (PS3) Console
Connect PS3 for playing/viewing blue-ray thru surround sound
Connect the PS3 to your TV with the hdmi cable and to the surround sound system with a digital optical cable, then set your PS3 to output sound through the optical port (through the sound options menu) and you're good to go!
Oct 27, 2007 | Sony DAV-HDX500 System
Video Game Consoles & Games Logo
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
