Question about Toshiba 15DLV76 Television
Black menu-like box randomly appears, covering the picture
My 15DLV76 is 1.5 years old. Within the past 2 weeks, when watching antenna TV (not cable, not DVD), a black box randomly appears on the bottom half of the screen. It is a single black box, not like the 3 boxes that appear with the setup menu. If I change the channel the box disappears and may or may not reappear. Help?
  • cindy_san Sep 05, 2008
    Hey, thanks for the reply!
    This is actually happening with the antenna, not cable. It's been happening on all 4 of my channels. The Closed Caption was on "C2" so I've shut it off and will see what happens over the next few days. I'll reply again once I give it some time.
    Thanks!
    Scholar:
  • 141 Answers
This is a problem with closed-captioning. What you are seeing is a closed captioning box with no captioning in it. Usually this is being accidentally transmitted by the cable company "head end". Just make sure your closed captioning function is completely turned off. if you are seeing it randomly, it may well be coming from your cable company. Is it just on certain channels?
Posted on Sep 05, 2008
  • Steve Froese
    Steve Froese Sep 05, 2008
    Hopefully turning it off will solve the problem. CC2 tends to cause this.....
My tv just stopped getting antenna reception today.
It is not possible clear picture use indoor antenna it is use cable tv then get a lot of channel enjoy
Sep 24, 2009 | Philips SAA7130 TV Tuner/FM Radio/Video...
Black square in middle of picture
your captioning or "text" is on. usually inside the tv menu. if not its your cable or dish box has captioning on. black box usually means its in text mode instead of CC thus the black box rather than text
Jun 03, 2009 | Televison & Video
I have a black retangular box in the middle of the picture screen
i had the same problem with a Sanyo tv, was ready to trash it and a friend told me how to fix it.i went to the tv menu (not cable or satellite menu) and from the settings list chose CLOSED CAPTION . i had inadvertantly made a change there which left me with a black text box and very little viewing area. i just had to make sure all of the options for CC were OFF. hope this helps
May 27, 2009 | JVC AV-27F802 27" TV
Green screen with sound from cable, but picture is fine with Wii
That would be my solution. The trouble is either in the box or your connecting cables. Verify this by connecting the cable directly to the set. Then try a new set of connecting cables, or call the cable provider to replace the box.
Feb 07, 2009 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Fuzzy picture on my 42" akai lcd tv
Check the menu ,,it should have a option ,,called convergenge ,,that realigns the colors,, and some tvs have geomagnetic correction,, good luck
Oct 05, 2008 | Akai LCT3201AD 32 in. LCD Television
No picture for 3-4 minutes after start up
Roger,
Could be as simple as a software upgrade if the picture looks okay after it come on... What software version are you currently running?
SOFTWARE VERSION CHECK Step (1) Turn the TV ON. Step (2) Using the TV Remote, Select Antenna C. Step (3) Press the MENU button on the Remote. Step (4) Menu will appear
(Figure 1)
Step (5) Press the Cursor Down button and Highlight SETUP
(Figure 2)
Step (6) Press SELECT on the Remote Control. Setup Menu will appear
(Figure 3)
Step (7) Cursor Down and highlight UPGRADES
(Figure 4)
Step (8) Press the SELECT button on Remote Control. Upgrades Menu will appear
(Figure 5)
Step (9) Read the Software Version
Let me know!
Bill
Dec 12, 2007 | Hitachi 53SDX01B 53" Rear Projection...
Sony Trinitron KV-32S40 32" TV problem
This is a simple and common problem. The solder joints on the vertical output IC have cracked loose. I actually did a housecall on the exact same set with the exact same symptoms this morning! A good tech will resolder the pins of the vertical output IC and all other major solder joints on the main board and the set will play fine.
Sep 30, 2007 | Sony FD Trinitron WEGA KV-32FS100 32" TV
Black square in the middle of the picture
You have the set configured to display "text 1 or Text 2" in the closed captioning menu. You will need to turn closed captioning off to get rid of this box.
Jan 13, 2007 | Craig CTV-41904 19" TV
Televison & Video Logo
173 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
