Question about HP LaserJet 2300 Printer
Tray2 Paper emty message after swapping out tray2 pickup roller
I swapped out the Tray2 pickup roller. Now the printer doesn't see the paper in the paper tray. What should I try?
Thanks
  • Anonymous Mar 20, 2014
    doesn't pick papers
  • 138 Answers
Your problem is more than likely that the sensor lever is not properly positioned. You may also have dislodged the shaft from the drive gears (gears on right out side of carriage). Both are easy to do.
Here's a couple pictures of the exact positioning of the paper sensor positioning. It should freely flip up and fall back down with gravity. Remove the tray and check the flag that hangs down.
Just in case you have dislodged the shaft from the geartrain, here's a free copy of the HP Service manual for the printer that will walk you through disassembling the right side for re-mounting the shaft and holder clip for the shaft.
Hope that helps you. :)
If this resolves the issue, hit me with a Fixya! If not ask me further and I'll try and help you some more.
Posted on Sep 10, 2008
Hp laserjet p2055dn tray1 manual feed problem
Go to menu, in tray tray behaving tray1 select as unless paper load,in tray2 page size as any size.. while giving print command select printer properties, goto paper/quality select paper source automatic or tray2 & shoot print command & check...
# if you are not selected tray 1 as unless paper load, it will ask paper to load after command reached to it.
# if you are not selected tray2 as any paper size, defined paper size only it will allow to print..any paper size it will print with out questing you..
Aug 01, 2012 | HP LaserJet P3005n Printer
How to fix this error in printer hp p2055dn ''manual feed press ok for available media into tray 1
Aug 01, 2012 | HP LaserJet P2055d Printer
Manual feed tray bypass
Jul 25, 2012 | HP LaserJet 4250n Printer
Bottom tray is not pulling paper?
Due to old age pick up roller might be warn out.. replace the tray2 pick up roller P.No RB2-2891
Browse the link and see how to replace the pickup roller..http://printertechs.com/tech/mkinst/mk-2100-3tray2puroller.php
Oct 28, 2011 | HP LaserJet 2100 Printer
Printer indicates error 5.0
Replace paper pick up roller tray2.. take out tray2 cassette, you can see the pick up roller..un lock both side lock to take out the roller..if no part avail remove roller Tyre, re-fix in different angle..
Jun 07, 2011 | HP LaserJet P3005n Printer
Paper jam in tray 2 but there is no paper jam?
check the pick roller from tray2.
try to change the pick rollers tire in the tray.
it worked for me many times
stefan
Apr 14, 2010 | IBM Infoprint 1532 Laser Printer
IBM Infoprint 1532 Tray Selection
For tray linking to work, both Paper Size AND Paper type must be configured the same for both trays. You probably have the paper sizes the same but types could be different. The is no setting to make tray linking work.. it will do it automatically if the above settings are correct.
Feb 24, 2009 | IBM Infoprint 1532 Laser Printer
13.20.00 paper jam error
hi,
i think you having problem on your pickup rollers maybe it's worn out that's why you having that message always...try to replace the 2pcs, pickup roller to fix your problem..
i hope it would help you...
Oct 28, 2008 | HP 4250 Monochrome LaserJet Printer
Paperjams
Sounds like the pick up rollers are worn or dirty.
You can try to clean them with alcohol.
When you pull the tray out the rollers
should be towards the front of the printer.
Nov 21, 2007 | HP Color Laserjet 3550 Printer
HP LaserJet 2300 Printer Logo
2,304 people viewed this question
Ben Johnson
