Question about Canon imageRUNNER 2000 Copier
Stuck on double-sided
Hello
Thank you for this great service.
Our machine has been stuck on double-sided for a month.
We have tried
-reset
-turn machine off
-unplug
But nothing helps. There is no icon that says 1 --> 1.
Do you have any ideas?
Many thanks,
Caroline at the Montessori School
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Canon Master
  • 1,362 Answers
You may have to go in the double sided mode to deactivate.
choose double sided, it should show you pics of different types and choose 1-1 or clear.
It's been awhile since I worked on it, could figure it out if in front of. are you in Miami?
Posted on Sep 05, 2008
My A42T wo't finish loading the Ifit software. which means the treadmill won't start. The software is stuck in a loop. How can I reset it or get out of this so I can use it? Thank you.
Turn it off from Machine build switch, then turn it of from mains, then unplug it from mains, wait for some time and then Plug it to mains, switch on from mains and switch on local machine switch. If the process above fails, you should contact the Dealer or Authorized Service Center.
Apr 26, 2014 | Epic A42T Platinum Treadmill
The locking mechanism seems to be stuck on my Frigidaire front loading washing machine. When the door is closed it buzzes and machine won't start.
Hello Craig, thank you for your post!
I understand that the door lock on your washer is stuck and washer will not operate. Try resetting the unit by either unplugging it or flipping the household circuit breaker off. Wait approximately 2 minutes and turn on the washer. Select a normal cycle and verify if the washer will start. If your washer will not operate then it possibly have a faulty door lock assembly or a communication problem with the control board. I am fairly confident that an authorized service agent will be able to restore your appliance to its normal operating condition. You can often locate a qualified service technician on the manufacturer website.
Thanks for allowing me the opportunity to assist you!
Oct 27, 2013 | Frigidaire Washing Machines
Washer pauses with a unbalance load...the load does not seem to be related to the pausing of this machine.
Hello dsr_mech, great question! First, let's try resetting the washer. This can be done by either unplugging it or flipping the household circuit breaker off. It is important to wait roughly ten minutes and then turn the washer on. If the instructions above do not solve the problem, then based on the symptoms you are describing the issue may be related to a stuck key on keypad or a potential control failure. I am fairly confident that an authorized service agent will be able to restore your appliance to its normal operating condition. You can often locate a qualified service technician on the manufacturer website.
Aug 26, 2013 | Frigidaire Washing Machines
Dell V715w all-in-one print job stuck in que
If you have Windows OS, try this:
Clear Printer Spooler files and enable the Spooler service.
a. Click Start, type "services.msc" (without quotes) and press Enter.
b. Double-click "Printer Spooler" in the Services list.
c. Click Stop and click OK.
d. Click Start, type "%WINDIR%\system32\spool\printers" (without quotes) in the search box and press Enter. In the open window, and delete all files in this folder.
e. Now, go to “Services” again. Double-click "Printer Spooler".
f. On the General tab, next to Startup type, make sure that Automatic is selected.
g. If the service is not already running, under Service status, click Start, and then click OK.
Jan 27, 2018 | Dell All-in-One Multifunctional (v715w)...
All of the lights contiuously flash and will not brew. I have reset the machine, unplugged and re-plugged the machine, dumped rinsed and refilled the water resivoir. Still nothing good and no coffee. I...
All of the lights contiuously flash and will not brew. I have reset the machine, unplugged and re-plugged the machine,All of the lights contiuously flash and will not brew. I have reset the machine, unplugged and re-plugged the machine, dumped rinsed and refilled the water resivoir. Still nothing good and no coffee. I have since put the machine away and have stopped trying to use it. Any help that you might be able to give would be greatly appreciated. Thank you Tandie Grant
Oct 26, 2010 | Braun Tassimo Espresso Machine/Coffee...
When washer done rinse cycle lights flash and washer stops doesn't rinse and spin
Hello
Try reseting the machine.Unplug power for 60 seconds.
Plug back in,then turn knob to reset.Then try another load of wash or finish the one that is stuck before rince cycle.
It is possible the control timer is going bad.
Aug 29, 2010 | GE Washing Machines
This frigidaire (side by side) only blows warm air on both sides
Good day,
First, I would unplug the machine, and then unplug the ice maker. Wait 20 minutes and plug in refrigerator. See if it cools without the ice maker in the equation.
Sounds more like starting components on the compressor, or a compressor starting to fail.
Post back with results.
Thank you.
Feb 12, 2010 | Frigidaire FRS3R5EMB Side by Side...
Gaggia Titanium: stuck on 'rinse'.
Try first unplugging power cable for five minutes, see if this reset machine.
Aug 20, 2008 | Gaggia Titanium Espresso Machine
Pause mode stuck
Is the door firmly closed? Open the door and close it firmly. If the pause button is really stuck, you will need to repair/replace the board.
Oct 17, 2007 | Whirlpool Duet GHW9150P Front Load Washer
"Call Service 3"
if doing menu #9000*550 did not solve the problem for call service 3, it is better to call your panasonic service center.
the problem is in fuser unit. the thermistor maybe dirty or damage. careful to touch the fuser unit for it is really hot.
Nov 02, 2006 | Panasonic KX-FL611 Plain Paper Laser Fax
Canon imageRUNNER 2000 Copier Logo
104 people viewed this question
old marine
old marine
