Question about Brother GX-6750 Typewriter
Typewriter ax-10 by brother
It does not type or it is in delay stage. will here a beep after about a second and than it will type on its own. but can not get it to return back to left margin
  • Anonymous Dec 11, 2008
    Can not get the typwriter to type at all, the typing mechanism has slid all the way to one side and will not move and beeps until I shut it off. I tried unplugging it and shuttig it off for a long period of time but it won't move. How do I check the typing mode?
    Scholar:
  • 183 Answers
Turn off machine. Unplug machine for at least 1 minute. Plug back in and turn machine back on. If it still doesn't work, check to see what typing mode it is in, and change it if necessary.
Posted on Oct 28, 2008
The number keys to the right will not work, even after pressing number lock. suggestions?
Please open Device Manager and uninstall what is showing under "Keyboards". If you're unsure on how to perform these steps, follow this link:http://h10025.www1.hp.com/ewfrf/wc/document?cc=us&dlc=en&docname=c03540049&lc=en&product=5450010&tmp...
Once you have uninstalled the keyboard driver, restart your notebook and it should automatically reinstall for you.
Let me know if this resolves the issue.
  • If the keyboard is not working in Windows, continue with these steps to uninstall and reinstall the keyboard software in Device Manager.
  • Click Start , then click Control Panel.
    Control Panel opens.
  • Click Hardware and Sound.
  • Click Device Manager under Devices and Printers.
    Device Manager opens.
  • Click View, and select Show Hidden Devices.
  • Double-click Keyboards, right-click the keyboard name, and then click the Uninstall button to remove the device from Windows.
  • Restart the computer.
  • The keyboard should now work correctly.
  • Your computer comes with several software programs that can test the keyboard for key or hardware failures. For more information, see the HP Support document Testing for Hardware Failures.
  • Notebook key presses are slow to respond
    If there is a short delay from the time a key is pressed to the time the character displays on the screen, the Filter Keys function might be activated. The Filter Keys function provides a greater range of key press options to fine-tune key delays and prevent inadvertent key presses. To disable Filter Keys and return to the default keyboard behavior, use the following steps:
    1. Click Start , and type keyboard in the Search box. Then select Change how your keyboard works under Control Panel.
    2. Remove the selection from Turn on Filter Keys. Then click Set up Filter Keys.
    3. Remove the check next to Turn on Filter Keys when SHIFT is pressed for eight seconds.
    4. Click Apply, click OK, and then close the Ease of Access Center.
      The keys should be more responsive.
    Pressing a notebook key once types several characters
    If two or more characters appear when pressing a key, use the following steps to adjust the key repeat delay:
    1. Click Start , and type keyboard in the Search box. Then click Keyboard under Control Panel.
      The Keyboard Properties page opens.
    2. Set the Repeat delay slider to Long. Click Apply, and then click OK.
    Notebook beeps while typing
    If the computer sometimes beeps while you are typing, Toggle Keys or Sticky Keys is active. Toggle Keys causes the computer to emit a beep when the Lock keys are pressed. Sticky Keys causes the computer to emit a beep when the Ctrl, Alt, Shift, or Lock key is pressed. Use the following steps to disable Sticky Keys and Toggle Keys:
    1. Click Start , and type keyboard in the Search box. Then click Change how your keyboard works under Control Panel.
    2. If selected, remove the check next to Turn on Sticky Keys. Then click Set up Sticky keys.
    3. Remove the check next to Turn on Sticky Keys when SHIFT is pressed five times.
    4. Click Apply, and then click OK to return to the Make the keyboard easier to use page.
    5. Remove the check next to Turn on Toggle Keys.
      If selected, remove the selection from Turn on Toggle Keys by holding down the NUM LOCK key for five seconds.
    6. Click Apply, click OK, and then close the Ease of Access Center.
      The beeps no longer sound.
    Wrong characters appear when typing, changing keyboard language, or Dvorak
    If the wrong characters appear when you are typing, or you are trying to use a different keyboard, use the following steps to synchronize Windows to the type of keyboard you are using:
    1. Click Start , and type region into the Search field. Click Region and Language from the search results.
    2. Click the Keyboards and Languages tab, and then click Change Keyboards.
      The Text Services and Input Languages page opens.
    3. Click Add.
    4. Select the keyboard you want to use, and click OK.
    5. From the Text Services and Input Languages page, select the new keyboard in the list and click Move up until it is first in the list. This makes it the default keyboard.
    6. Click OK. You can now use the new keyboard.
      If you find that the new keyboard service works correctly and you do not want to use the other keyboard, repeat these steps and Remove the keyboard service that you do not need.
    HP Notebook PCs Notebook Keyboard Troubleshooting Windows 7
    Aug 23, 2015 | HP Computers & Internet
    Need self-cleaning instructions....missing manual.
    To Self-Clean: 1. Close the oven door. 2. Move the door lock lever to the right to the locked position. 3. Press CLEAN. 4. Press the "up" or "down" arrow pad. CL-M (Clean - Medium soil, 3 hours) appears in the display. If the door is not closed, beeps will sound and "door" will appear in the display until the door is closed and the Clean pad is pressed again. If the door is not closed within 45 seconds, the self-cleaning operation will be canceled and the display will return to the time of day. If more than 5 seconds elapse between pressing the Clean pad and the "up" or "down" arrow pad, the program will automatically return to the previous display
    5. To choose a clean setting other then Medium, press the "up" or "down" arrow pads to scroll through the self-cleaning settings. CL-H (Clean - Heavy soil, 4 hours) CL-M (Clean - Medium soil, 3 hours) CL-L (Clean - Light soil, 2 hours) Choosing a cleaning level automatically programs the selfcleaning time. 6. After 4 seconds, the oven will start cleaning. "LOCK" and "CLEAN" will appear in the display. The cleaning time will count down in the display. To Delay Start Self-Clean: Before delay starting Self-Clean, make sure the door is closed completely or it will not lock and the cycle will not begin. 1. Press DELAY. "DELAY" will flash and "00:00" will appear in the display. 2. Press the "up" or "down" arrow pads to enter the amount of time you want to delay the cycle. Delay time can be set from 10 minutes (00:10) to 11 hours and 59 minutes (11:59). 3. While "DELAY" is flashing, press the CLEAN pad. "CLEAN" will flash in the display. 4. Press the "up" or "down" arrow pad. CL-M (Clean - Medium soil, 3 hours) appears in the display. 5. To choose a clean setting other then Medium, press the "up" or "down" arrow pads to scroll through the self-cleaning settings. CL-H (Clean - Heavy soil, 4 hours) CL-M (Clean - Medium soil, 3 hours) CL-L (Clean - Light soil, 2 hours) Choosing a cleaning level automatically programs the selfcleaning time. After 4 seconds, "CLEAN," "DELAY," and "LOCK" will appear in the display to show that the oven is set for a delayed clean operation. The delay time is displayed
    Apr 21, 2015 | Kitchen Ranges
    I have a 1995 sl320 on occation my reverse is delayed for a few seconds and when in reverse backing up a hill it wants to shutter I then stop put in park and then reverse will be alright ,,any idea?
    Stage pistons may be going bad. They can be replaced in car depending. If replacing fluid and stage pistons don't help then full rebuild is required.
    Oct 25, 2013 | Mercedes-Benz S-Class Cars & Trucks
    Ge adora washing machine beeps when pushing start with door closed
    Hit the power button until there is NO display . Unplug and wait a minimum of 30 seconds , plug back in and within 30 seconds hit SIGNAL button then DELAY START button then SIGNAL button again then DELAY START button again. door should lock and display t01 It is now in test mode . There are 14 different test it can run through in this mode , but all we are trying to do is check for error codes now and maybe get you back to normal, So turn the knob one click clockwise and hit the START/PAUSE button and see if any error codes come up. To exit the diagnostic mode - hit signal button then delay start button then signal button then delay start button and you are out of service test mode and back to normal. Post any error codes.
    Dec 07, 2012 | GE WSXH208A Front Load Washer
    My daughter just got a used Brother AX-12 typewriter but it doesn't have a manual. Where can I find a manual?
    yoYI would so to ask.com and type in manaul for brother ax-12 typerwriter.
    Or, you could just google Brother Ax-12 typewriter and then click on the information and the manual will probably be listed.
    Mar 30, 2011 | Brother GX-6750 Typewriter
    Need to make entry time longer . I am able to delete option 10 but can't add option 10. Entry is only 5 sec.
    Here is instructions from Installation Manual. I am also attaching links to full Installation as well as User Manuals for your reference at the bottom of page. Make certain to input as 3 digit time - example 45 seconds as 045. Good luck!
    Option 10: Entry Delay (Default = 030 sec.)
    Determines how much time the user has to disarm the system
    after entering the armed premises through a designated delay
    door, before an alarm occurs. Beeps sound during the entire
    delay time to remind the user to disarm the system.
    When turned on, the Entry Delay can be set from 005-254
    seconds (030-254 if SIA Limits Option 69 is on). All entries
    must be 3 digits. When turned off, the Entry Delay is set to
    005 seconds.
    Note
    For UL listed systems, the entry delay must not exceed 45 seconds.
     To set Entry Delay, press:
    1. Add
    2. Option #
    3. 10
    4. Use the numbered keys to enter the 3-digit delay
    time.
    5. DONE
     To turn off Entry Delay, press:
    1. Delete
    2. Option #
    3. 10
    4. DONE
    Installation - http://www.homesecuritystore.com/downloadmanual.aspx?mnl_id=334&prod_id=171
    Users: http://www.safemart.com/manuals/simon3.pdf
    Oct 02, 2010 | GE Security Simon 3 Wireless Home Security...
    Looking for instructions on how to change correction ribbon on Brother AX-10 typewriter
    Go to brother.com, click on support, poke around you will find a downloadable manual there.
    DickyO
    Aug 24, 2010 | Brother Office Equipment & Supplies
    Brother GX-6750 Typewriter Logo
    104 people viewed this question
    James Cagle
    James Cagle
    Samyfam
    Samyfam
    Victorman
    Victorman
