Question about Sanyo DS24424 24" TV
POWER MY TV DOES NOT POWER ON. I TRIED USING THE REMOTE , IT STILL DID NOT POWER ON. THE OUTLET IS FINE ALSO. COULD IT BE THE FUSE?
  • Anonymous Nov 14, 2008
    i have the same problem t.v doesn't power on i checked fuse and it's good so don't know what it could be.
  • tcmlcm Jan 21, 2009
    Same problem -- tv will not power up.
I would like to know who is near the Orange County area since I bought my TV. for 50 bucks I don't want to buy a new remote. maybe I can use some ones remote for a few dollars I can bring my TV. to your house just to take the V-Guide off. my kids need a TV. bad. My e rudy@admiralcapitallending.com
Posted on Sep 13, 2009
  • 298 Answers
I too.
My fuse is good, I took the plunge and removed the 6 screws around the cabinet and 1 in back by the Video In jacks, pulled it back 8" and checked. Then I went further and disconnected everything (careful with the TV HV Rubber capped tension lead - it can kill you! and I found some board discoloration (heat) and tshot some more and found a bad transistor in the HORIZ OUT section. Mine is a TT2168 and I am looking for a replacement part now.
Typically when these fail, it is because of excess voltage or excesss heat. It gets kicked thru a coil, which gets kicked from another chip. I will let you know what I find out.
Posted on Mar 28, 2009
Sanyo DS27530 won't come on
if no any power indicator at the front panel what you can do is to remove the back cover of the tv then look for a blown fuse at the power supply section. if ok, at this time a trouble shooting must be applied if you want to do it with your own just let me know and i can give you further solution good day.
Sep 18, 2012 | Televison & Video
No power
If your television has no power, try the following:
1. Check the power cord for breaks, tears, or exposed wires .
2. Check to be sure that the power cable is fully inserted in the outlet and that the outlet is working.
3. Go to your fuse box or circuit breaker box and check the fuse or circuit breaker of the circuit your TV is plugged into. Replace the fuse or reset the breaker if necessary.
4. Replace the batteries in the remote control, and then try turning on the TV using the remote.
5. Unplug the TV, wait five minutes, plug the TV back in, and then try turning on the TV.
If the recommendations above do not resolve your problem, most likely the power supply in your TV has failed and your television needs service.
Thank you !!
Jun 04, 2010 | Hitachi 55PMA550 55 in. HD-Ready Plasma...
No power to tv - but ac cord and wall outlet are fine though
hello the glass fuse inside the tv might blew make sure the tv unpluged take the back in the power supply you should see a glass fuse if the fuse is black then it's blew if you put another 1 in and it blows again then you have a dead short somewhere
shaun
Nov 06, 2009 | Philips 60PW9363 60" Rear Projection...
Rca f36650yx01 will not turn on
I feel foolish asking this but have you plugged it in? If you have it plugged in are you trying to turn it on with the remote? Have you tried to turn it on by pressing the on switch on the tv? Does the outlet work?
There could be any number of reasons for this. If the outlet has power (you can check this with any electrical device you have, plug it in and turn it on). So if the outlet has power AND the remote has fresh batteries AND the tv is plugged in to the outlet but still will not turn on even after pressing the switch on the tv...then you may have a blown fuse on the power input line into the tv. Take the tv to your local repair shop and ask them to look, if the fuse is blown they'll replace it and voila, your tv is fixed!
Please do not try to do this yourself, there is over 10,000 volts available at the flyback transformer even with the tv not plugged in.
Sep 07, 2009 | RCA F36650 36" TV
Television will not power up
Have you tried both power buttons? On the set and on the remote? If yes, you might have a blown fuse or a bad board.
Jul 09, 2009 | Televison & Video
Tv is frozen
Try unplugging the TV from the power outlet. Let is sit for 30 minutes. Plug it back in .. see how it is then
Mar 23, 2009 | Sanyo Televison & Video
Tv wont turn on
take your tv to technician who can check your power supply, if your power is coming on and off, than a problem is not as big. firstly let him check a ht of a supply constantly, your supply is cutting.
Nov 03, 2008 | Panasonic CT-32SC13 32" TV
TV won't turn on
the power supply of your tv is not working,coldsolder the mainboard of your tv,
Apr 26, 2008 | RCA 32F531T 32" TV
Samsung Flat Screen Won't turn On
yea take your tv to a tech tv has a problem in the power supply there is 10mf cap in the power supply that likes to go bad replace it if that model does not have it check regulator and the microchip.however your problem lies in the powerand related circuit.good luck
Apr 02, 2007 | Samsung TXN3275HF 32" TV
Cant get the tv to power up
I'm having the same problem. No power at all, tv was working fine and shut off by itself WS-65517. Please help!
Oct 15, 2006 | Mitsubishi VS-55601 55" Rear Projection...
Sanyo DS24424 24" TV Logo
133 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
