Question about Nikon Coolpix 4300 Digital Camera
Auto reset following each picture shot
I am getting the sand clock after each picture shot. before that or after that the lcd display gets black and following 5-10 seconds the camera comes back to life. the entire process before a new shot can be taken is almost 20 seconds!
    Novelist:
    Champion:
  • 277 Answers
Well most digital cameras are not equipped to allow to take a lot of action photos or just snap off various pictures of the same subject in a relatively short time. The models which are ill-equipped require more time between shots to save the image to the memory card. Just imagine the time it takes to save something on a disk. Keep in mind that the burst mode allows temporary storage of images. This way, you could take as many pictures as you can in no time. With the Nikon Coolpix 4300 Digital Camera, you can expect to find a shutter speed of 1/1000 to 8 seconds. One more camera feature include a Self-Timer mode, which provides a three- or 10-second delay between the time the Shutter button is pressed and the time the image is actually captured... Good luck!
Posted on Oct 23, 2005
I turn it on and the screen is black and it can take pictures and do all that stuff but the screen is black and dosnt show anything
Please check if the LCD backlight isn't turned off by pressing DISPLAY botton (it may be labeled as DISP or with a display icon) several times until the screen appears, if this doesn't work perform the following reset procedure on the camera:
  1. Locate the RESET button on the camera.
  2. Use a pointed object (like a ballpoint pen) to press and hold the RESET button for 2-3 seconds.
  3. After 2-3 seconds has elapsed, release the RESET button.
Mar 08, 2011 | Sony Cyber-shot DSC-W50 Digital Camera
How do i turn on the auto timer?
Hi, Follow these steps:
1. In any Still mode, tap Settings to open the Settings panel.
2. Tap Self-Timer/Burst repeatedly, until the desired Self-timer icon appears at the bottom of the LCD: 10 seconds—A picture is taken after a 10-second delay (so you have time to get into the scene). 2 seconds—A picture is taken after a 2-second delay (for a steady, auto-shutter release on a tripod). 2 shot—The first picture is taken after a 10-second delay. A second picture is taken 8 seconds later.
3. Compose the scene. Press the Shutter button halfway, then completely down. The camera takes the picture/pictures
Apr 13, 2010 | Sony Cyber-Shot DSC-W5 Digital Camera
Sony cybershot, but displays neg through lcd
This happened because you are not a camera repair technician. You took a complicated piece of electronic equipment apart without any knowledge of what you were doing. I'm glad that at least, your pics turn out.
Feb 02, 2010 | Sony Cyber-shot DSC-S700 Digital Camera
Black lcd screen on Ixus 70 shows icons but will not take picture
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open).
To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see the following for further info and a simple fix that may help:
http://camerarepair.blogspot.com/2009/05/simple-fix-for-stuck-shutter.html
Jun 13, 2009 | Canon PowerShot SD750 / IXUS 75 Digital...
I can't view my pictures after the shot,it very blerr
I'm not sure if you are talking about the quick view of a picture just taken, or using playback mode to view shots taken. Either way, I suggest changing batteries so they are fresh.
There are 3 different LCD choices when in "Shooting Mode."
Press "DISP."
The display mode will change each time you press this button.
1- Standard (no info displayed, just pic)
2- Detailed (infor displayed)
3- Off
If you have tried this, then you may want to perform a reset to the cam. This will reset any screen/LCD settings that may have been changed.
Goto the Setup Menu and select "Reset All." Select "OK" and press "Func. Set."
This reset WILL NOT reset the following:
-Current Shooting Mode
-Date/Time, Language, & Video System settings
-White Balance Data (of you have custom settings changed in the custom white calance function)
Apr 30, 2009 | Canon PowerShot A450 Digital Camera
Canon A700 black screen when i want to take a picture
Did you accidentally press the DISP or DISPLAY button on the back of your camera? This button manually turns the LCD display on and off to save batteries. Pictures will still appear momentarily when shot.
Jan 19, 2009 | Canon PowerShot A700 Digital Camera
Pictures are black
My 4300 works fine until this week. No picture display on the LCD screen. Settings like date, exposure, etc.. are fine on the LCD screen. Able to get into setup mode and the colour menu selection box is fine. This shows that the LCD screen is working fine. Prior to this happening, I notice that when I took pictures in zoom mode, the picture turn out to be orange. I suspect this is caused by electronic failure. Light entering the lens cannot be transmitted to the LCD screen. Some photoelectronic stuff had reached its MTBF (mean time between failure)? Is there a way to save this camera?
Mar 17, 2008 | Nikon Coolpix 4300 Digital Camera
Colors in QL-711V shifted to green
Hi, I had the same problem and I wrote an email to Nu. They wrote me back that I should use the Factory reset feature which you have to go through the Factory Menu to get to. Instructions to do this are as follows. I got to the menu my first try but it has been a pain to get back to it. I hope it will be easier to access for yours.
Hope this helps
-Nate
Page 1
You will need to display a gray scale picture which varys from black to white
You will need to display a gray scale picture which varys from black to white. Displaymate 16 grays pattern is good or something like the picture to the right. 1 Press and hold SEL/AUTO and press the power button. Then release the SEL/AUTO button. 2 Press the MENU key to display the factory menu. Sencore 11 gray Pattern 3 Press the and select FACTORY2 menu. Factory2 is at the bottom. Press SEL/AUTO to select the FACTORY2 menu. 4 Press the to select AUTO COLOR. 5 Press the to run AUTO COLOR. Wait until finished. You will see the colors changing and then become stable when finished. About 10 seconds. 6 Press the and select COLOR UPDATE. 7 Press the to run COLOR UPDATE. It will finish quickly. < 1second. 8 Press MENU to exit the menu. Power off/on.
Nov 05, 2007 | NuTech QL-711V 17" Flat Panel LCD Monitor
Problems with the LCD monitor
You've probably got something as simple as a ribbon cable loose in the camera. Beware though, dismantling is a serious task unless you have experience. Amazingly the CCD is often connected in such a simple, analog-esqe, way that disconnecting it doesn't cause an error, just a black screen.
Sep 13, 2005 | Pentax Optio S Digital Camera
Nikon Coolpix 4300 Digital Camera Logo
94 people viewed this question
Top Nikon Cameras Experts
Ric Donato
pictureman4u
Geoff Hone
Are you a Nikon Camera Expert? Answer questions, earn points and help others
