Question about Canon PIXMA MX310 All-In-One Printer
Print from memory
Machine will not print frm memory
  • pedsunlimite Oct 27, 2008
    My Lexmark x63 will not print from memory
If you still have the paper manual it's on page 54 and 55
basically you have to press fax button, then press the menu button, then use the right or left arrows (on the side of the ok button) to select "memory reference" then press "ok", then press the arrows again to print which document in memory you want to print (usually the most recent is listed) then press "ok" again.
finally press the arrows to select "yes" to print only the first page or "no" to print the entire document and press the ok button one last time. it should print.
if you are still receiving a "change paper size" type error, go ahead and press the fax button, then the settings button, use the arrows to select your paper size, press ok, then select media type, in this case "plain paper" and press "ok"
that should do it.
Posted on Feb 10, 2009
Dra.harigopal@gmail.comi'm using DG31pr motherboard with intel core2duo processor,, my pc is not starting when i restarted it... the red led is not turning on after restarting the pc & 3beep sounds...
is a memory problem:
  • Reseat the memory.
  • Make sure that the contacts on the memory and the socket are clean.
  • Try removing one bank of memory modules at a time. (Some systems may require a memory module in Bank 0.)
  • Try using memory modules from the same manufacturer with the same part number and speed.
  • Check for a faulty memory module by trying the memory in a known good system.
If this helps orsolves the issue, please rate it and give a testimonial for myresponse.
Feb 26, 2011 | Intel DG31PR Motherboard
Not my memory card it's my cell phone his does not see the memory card what i should do??
The memory card is bad.
get another memory card and it will work fine.
Thanks for contacting Fixya.
Jul 02, 2010 | Nokia E75 Cell Phone
Can i delete the songs from my sd memory card? or Can i add more music to the memory card which already has songs on it?
yes if you plug your player into your computer go into the players file it will show all songs on your memory you just delete what you don't want
Mar 24, 2010 | GPX MW249 MP3 Player
I cant print anything frm hp f4288
hi
you have a bud refilling process
check here how to refill right fro black
http://www.youtube.com/watch?v=MPi2GqJg5QM
for color http://www.youtube.com/watch?v=C6-N-Pxmjxk
Mar 06, 2010 | HP DeskJet F380 All-In-One Printer
Can i play games frm memory card with updated psp 5.51 firmware
it should be possible if you get custom firmware or downgrade
how you can do this is by using a pandora battery and a magic memory stick
you can buy a pandora battery off ebay or whatever for cheap these days and you can use your current memory card as a magic memory stick
all it does is start the psp in a mode where you can reinstall the firmware with whatever firmware you want.
you will have to research into it because i have done it on my psp
im running 5.00 m33-2
but my psp is a 1002 model
good luck mate,
if you have any questions, email me
deano_90@hotmail.com
Jun 29, 2009 | Sony PlayStation Portable (PSP) Console
My Sharp UX-355L Fax machine printed unwanted information
Sounds like you have the machine set up to print reports on all occasions, fax transmission, error, etc. You can change this by doing the following:
1 Press these keys:
The display will show:
FUNCTION
TRANSACTION LIST
2 Press a number from 1 to 5 to select
the condition for printing.
ALWAYS PRINT A report will be printed after each
transmission, reception, or error.
ERR/TIMER/MEM A report will be printed after an error,
timer operation, or memory operation.
SEND ONLY A report will be printed after each
transmission.
NEVER PRINT A report will never be printed.
ERROR ONLY A report will be printed only when an
error occurs.
To print from memory:
If the memory becomes full...
If the memory becomes full while the document is being scanned,
MEMORY IS FULL will appear in the display.
♦ Press the START/MEMORY key if you want to transmit the pages
which have been stored up to that point in memory. The remaining
pages will be ejected from the feeder. After transmission, the memory
will be cleared and you can transmit the remaining pages. You
will also need to transmit the page which was being scanned when
the memory filled up.
♦ Press the STOP key if you want to cancel the entire transmission.
Hope this helps. : )
Mar 30, 2009 | Sharp UX 355L Plain Paper Thermal transfer...
Fax thinks it has printed from memory.
no, once the machine thinks it has printed them there's no way to retrieve them
Jan 22, 2009 | Panasonic KX-FP205 Plain Paper Fax Machine...
Sony memory stick pro
r u havin card reader.....
if u hv....then
first take it out urs memory stick n fit it in to card reader n copy all pics frm ur memory card....
after copying it u should format d card frm computer.....
when u r joinning card reader wid to compter a new drive autoatically made on ur pc frm dat drive right click on it and chosse option format..........
den ur memory stick totally ger formated n free frm errors....
if u still hvin problem ask me for more soln. .......
Jun 16, 2008 | Sony Cyber-shot DSC-W70 Digital Camera
Canon PIXMA MX310 All-In-One Printer Logo
109 people viewed this question
old marine
old marine
