Question about Coleman Powermate Premium Plus 6250W Portable Generator
Colemen powermate Generator 6875w 5500
Hello i purchased this generator about 3 years ago brand new we kept it inside adn started it every month or so when i went to use ti it wouldn't power up it runs but no power to the plugs do you have any idea's i was using it last time i was whippersnipping my lawn adn ran out of gas now wont' power up can you help. I also heard that i can't get parts this company went out of buniess have any idea's thanks
If your's is not a brushless type then see owners manual regarding how to re-excite the generator using a battery 6 volt (dry cell) or 12 volt auto. Be careful when removing the plastic brush cover plate
don't pull at just the bottom tab,  pull it at the bottom tab and at the sides. Parts may become available as plant has been re-opened by
Pramac.
Posted on Sep 07, 2008
    Novelist:
  • 72 Answers
GENSET ALL PROBLEM FIXES - 2 PARTS
My answer:
Almost 90-95% of all the Genset problems found by the factory approved Genset Service Centers are related to the fact that people don't read the OWNERS MANUAL first, and just didn't put OIL in the Genset (or the right amount) - as they are shipped from the MFR without OIL in the units to begin with!!!! (See esp #3 and Final Notes below as well)
And here I thought everybody KNEW THAT!!
I guess sometimes you just have to ask the most OBVIOUS ??'s first huh (dumb as " it " may sound)?
If you bought your Genset from other then a Home Depot Store, and it's still under warranty - then you will have to contact that outlet, and see what they have to say or hopefully can do for you.
Esp all those Gensets that are Made in China and have flooded the USA market in the last 10 years or so - no thanks to our representatives in WASH DC that's for sure. It's a wonder this country even functions with all this "inferior" Made in China JUNK that keeps prematurely failing before it's normal time. Sad to say the least!
Some other obvious things to CHECK for that may be the cause of a NO start condition even after adding proper gas & oil to the brand new Genset:
1 - Some Genset gas tanks come with a gas cap "blocking insert" under the gas cap that should be removed according to your manual if it states this. (Read manual section on "First Time Starting")
2 - Is the gas tank shutoff valve FULLY OPEN? By the same token (even if the Genset is or isn't brand new) does it have an in-line fuel filter anywhere in the gas line? If not then esp read #5. Always check as well the AIR FILTER for proper cleanliness (if oiled type), or clean appearance if it's a paper element type. Clean or replace as needed!
3 - Is the RUN SWITCH set to ON or RUN position (this is purely an "Electrical ON-OFF Switch" usually a single-pole single-throw type btw, and it can go bad with high usage)? Does it move freely from OFF to ON? Is it working properly? Test it using a known good quality DVM or OHM meter! It's contacts may have become tarnished just from sitting around too long? Esp where you have saltwater conditions in the surrounding air! This switch actually & electronically is wired in REVERSE so that when switched to the ON position the wired contacts are OPEN thus letting the Ignition Coil fire for SPARK. When switched to the OFF position the wired contacts are now CLOSED thus connecting (or switching) the "Control Board" logic voltage signal (usually anywhere from +3 to +12 VDC upon start-up) to GROUND - thus cutting the RUN voltage to the Ignition Coil fire - as in SHUTDOWN. On some model designs there also may be a separate IDLE CONTROL SWITCH and POWER REGULATOR BOARD for better POWER LOAD self-regulation depending on constant variable loads placed on the Genset as related to the work-site demands. If there is NO VOLTAGE OUTPUT but yet good engine RPM function - then I would look at this part first and then #8.
4 - Is the choke being set to the proper position with or without using Ether spray to the Carb?
5 - Does the Carb have a Yellow or Black wire coming off of the bottom of the Float Bowl? This goes to the GAS CUT OFF SOLENOID mounted in the Main Jet inside the Float Bowl. NEVER CUT THIS WIRE as some know-nothings have suggested here and elsewhere in postings, as there are better ways to test the solenoid without doing that! If equipped with one - This anti-dieseling solenoid has to work properly or else flooding will occur with the gas shutoff valve OPEN.
6 - VERY IMPORTANT - Is the Carb Float stuck in the CLOSED position not letting gas into the Main Jet? If the Genset is brand brand new and truly has never been fired up even once and used, such as like that of 2-3 years or longer from actual date of purchase, then that Carb Float may very well be stuck CLOSED. Worse yet - the Main Jet may be clogged with MICRO DEBRIS coming down from the new gas tank - esp if there is NO FUEL FILTER present in the fuel line. I've heard of this happening more then just a few times myself. You might try and TAP CAREFULLY on the bottom or side of the Float Bowl with a hard rubber hammer first to try and see if you can dislodge the stuck Float inside. If there is that colored WIRE (see #5 again) at the bottom of the Float Bowl on your model - DO NOT HIT THAT GAS SHUT-OFF SOLENOID WITH THE RUBBER HAMMER - as you WILL damage it! If this dislodges the stuck Carb Float to the point that the Genset now wants to run to some degree better then before, but not fully 100% better and to spec - then you definitely still have Carb Float and/or fuel delivery related issues, and/or MICRO DEBRIS in the Carb Bowl or Main Jet inlet. If the Genset begins to run great - as it should - and continues to do so - then your NO FUEL or NO RUN problem is solved! I would still take the Carb Bowl off and clean out the whole Assy there just as an added precaution anyway as you just never know. When Gensets are truly needed in an emergency condition you just don't want to RISK anything!! NEVER FORCE ANYTHING EITHER!! It's possibly that you might have to loosen slightly, and/or totally remove the Float Bowl (usually 2 screws) to see if indeed any gas is getting inside to the Float at all. If gas comes out readily but still no gas is getting into the Main Jet and intake then you purely have a DIRTY CARB issue and nothing more! If you're not smelling gas through the air filter box then you are FUEL STARVED. ALSO - Many a brand new shipped Genset will have some kind of NEW gas tank (usually metal gas tanks only) MICRO DEBRIS inside the tank itself or even in the rubber gas line (I've heard of this problem before, and seen this myself 100's of times with cheaper rubber hoses). That is why an added in-line FUEL FILTER (if your Genset has none) is SO important!! Usually a common $2-3 item at any auto parts store. Once gas is added to the tank all this micro debris is set free to enter into the CARB FLOAT BOWL, and that is where Carb problems will start - even with a "brand new" never run before Genset!!
Posted on Sep 10, 2008
  • Frank JR
    Frank JR Sep 10, 2008
    PART 2
    7 - As dumb as this next ? is to ask I have
    to ask anyway -
    Are you
    getting GOOD spark at the spark plug? Again - see #3 AND check the
    engine OIL LEVEL as well. The LOW OIL sensor is actual another ON-OFF
    type switch and if the level Some units ship with the spark
    wire cap disconnected and it may look like it's on the plug, but in
    reality it really isn't fully connected! If you are getting a good
    spark then it's highly unlikely that the Maintenance-free
    Magnetron® electronic ignition would be bad. Fouled
    spark plug - YES - bad Maintenance-free Magnetron® electronic
    ignition - hardly.
    8 - If your Genset is used and said to be ? years old, and it just indeed
    might have some high RUNTIME HOURS on it - it just could very possibly
    be what sounds like to me (and I personally HAVE SEEN this
    happen myself firsthand) that the generator brushes are nearly shot
    - as in almost worn out. They may be getting too too hot - as from
    excessive current draw at point of contact, and thus the generator
    sensing circuitry itself is doing an electrical CUTOUT!!
    An added protective Genset "Control Board" circuit feature - that may
    or may not be built into your Genset - is one that is in the Generator
    Head circuitry itself and
    may indeed be linked to the engine as a type of REV LIMITER or CUTOUT
    on the Maintenance-free Magnetron® electronic ignition.
    Just depends on how sophisticated and expensive your Genset is? Thus
    protects by preventing RUNAWAY and OVER-VOLTAGE conditions rare as that
    may be by today's BETTER designed Gensets (DOES NOT include the cheap
    made in China junk). Again - read your operators or service manual as
    it should have a pretty good
    troubleshooting section in it unless you don't have that anymore or
    never got one if you bought it used to begin with.
    If you unscrew & remove the Generator brushes for servicing yourself, and they are indeed
    below the recommended length (or worse case they are indeed totally
    worn down) then that most likely is your starting or output problem right there. If you are having Output problems as well.
    If you choose to replace the old brushes with new ones yourself - be
    very careful when seating the new ones - as to their insertion and cap
    retainer tightening. Never over-tighten those black plastic-like brush
    retainer screw caps - for if you break one (hard to get immediate
    replacements is why), or fracture one it could cause the Genset to fail
    under LOAD, and that very well could do some severe damage to the
    generator part itself. Take your time doing it, and be patient!!
    It has to be one of the CHECK scenarios listed above, as I've covered every
    possible cause short of a broken wire somewhere - which in that case
    you will have to schematic trace and DVM or Ohm-meter out wire to wire contacts.
    This being the least likely scenario from experience.
    If you indeed find the Float Bowl assy to be the cause of dirt
    contamination or varnish build-up clogging the Carb, and you need a
    walk-through of taking it apart, cleaning it out, and then
    re-assembling it again - as well as re-adjusting the fuel mixture Adjustment Screws - just give me a shout here, and I'll walk you through it step by step.
    Final Note: For all older used Gensets - Are you starting and running
    the Gennie for at least 10 mins every month (30 days) as required by
    most all Mfrs? Are you also keeping & running a good FUEL
    PRESERVATIVE/STABILIZER (as required) in each tank of gas no matter how
    often you run it? BEFORE you totally shutdown your Genset after running
    it (even those short 10 required mins every month) - are you first
    shutting off the gas supply completely, and then running the Genset out
    DRY from as much gas from the Carb Bowl and gas line as you can? Even
    though some "so-called" experts tell you not to do this - if you are
    NOT going to be running the Genset every 30 days or plan to store it
    for more then say 6 months at a time - THEN DO IT RELIGIOUSLY -
    otherwise you will VARNISH the Carb with contaminated GUNK buildup from
    STALE GAS! Happens all the time! Changing the DIRTY OIL frequently and
    adding the proper level of 10-30 (recommended), or 10-40 oil is VERY
    important as well. Your engine will use OIL esp if it's older with
    "higher run hours" on it. Keeping a good Maintenance Log makes GOOD
    SENSE as well. You
    should be doing all of these things as well - if you want a smooth
    running Genset when that real emergency does come up, and that Genset
    absolutely has to work 100%!
    That's about all there is unless you got a truly Defective Genset right from the start. Next stop - Home Depot!
    Best regards to all with the same problems, and hope I helped you out 100% - all political humor/truth aside.
    Please post me a reply as to finding this solution being the best
    resolve to your Genset problem there by following my recommendations
    above. Also please rate my troubleshooting fix as well.
    Keep me posted and I'll follow up as well.
    Best regards,
    Frank
  • Frank JR
    FOLLOW-UP ON ALL POWERMATE GENSETS
    A follow-up to my original post here with some added Powermate info
    that hopefully will get you an Operator's Manual, service for your Genset, and more - for all your Powermate
    Gensets out there if you follow-up on the info here.
    As you are now hopefully but painfully aware - Powermate has gone
    totally Bankrupt, and is no longer in business as of this past year or
    so.
    There is hope though - as I state below in the previous Footnote I posted to many having similar problems.
    Previous Footnote: It's too late now for all those
    out there that
    unfortunately bought these now still Brand New "unserviceable"
    Powermate units that won't start for whatever, whether still Brand New
    "NIB", or whether taken out of the box and still not used, and are
    now seeking some kind of service on them (btw it's a sign of the
    present day GOP ran economic woes we are in AND it will only get worse
    - CHINA is going on the very same downward path right now thanks to you
    know who - W!). If you buy anything today "made in China" you better be
    making a GOOD buying decision - otherwise you will be in the very same situation
    you are in now with your Powermate Gensets - as China is starting to
    collapse from within just like this USA economy of ours has been doing for
    the last 5-6 years to no end! All politics aside as well - as blame is
    put where it is deserved in my books and we can only blame YOU KNOW
    WHO! Sorry but true!
    NOW -
    Any inventory stock of their (Powermate) Gensets - that were once formerly sold in the USA & Canada - have been
    totally liquidated out to a company in Georgia I was told, and it was said to be true.
    I was able to get this NEW added info through another source said to be VERY accurate btw - so hopefully it is.
    That Company's name is PRAMAC, and their address and phone # info is:
    PRAMAC INDUSTRIES, Inc.
    * Regional head office:
    1100 Cobb Parkway North C
    30062 Marietta, Georgia
    Phone: 770-218-5430
    Fax : 770 218 2810
    or:
    * International sales office:
    10100 NW 116 Way, Suite 10
    33178 Medley, Florida
    Phone: 305-888-9911
    Fax : 305-888-3711
    Site info:
    PRAMAC Global Gateway
    BUT -
    Before you blame me for any possible false Powermate info posted
    above in regards to that PRAMAC Co, or their contact info - read the
    GOOD NEWS below first.
    The GOOD NEWS is that I spoke with a very close contact inside Home
    Depot (not saying who so don't even ask), and that person gave me some
    very GOOD NEWS for those that act on it NOW!
    Not tomorrow - Not next week - Not next month - and certainly NOT NEXT YEAR!
    DO IT RIGHT NOW!!
    I spoke with my Home Depot Corp contact today (using your "not starting" dilemma - as
    my own - to get a response) to see if anything could be done from their
    point of view and here's what I was told to do.
    What I was told is that if I (you) bring in my (your) ORIGINAL HOME DEPOT CASH
    REGISTER DATED RECEIPT and speak to the (whichever Home Depot store
    applies here) Home Depot Store Manager there, and explain to them that
    the brand new never used Powermate Genset they sold me (you in this
    case) won't start - they would send your Genset out to their local
    Genset Service Vendor FREE OF CHARGE BTW, and hopefully get it started
    for you.
    Anything more then that - you would be on your own if it was damaged by you or someone else that tried using it improperly.
Why does it crank and almost start on 1st try?
Generac Generator Troubleshooting - YouTube
? 1:39
https://www.youtube.com/watch?v=AKN2dc59cxY
Dec 20, 2013 - Uploaded by Appliance Princess
I want to learn about Generac generator troubleshooting. ... I have a 16 kW propane fueled standby air-cooled generator. ... I have a brand new generac 20K guardian Evolution and the first time my power went out my generac ...
Generac Power Systems - ConsumerAffairs.com
www.consumeraffairs.com > Homeowners > Utilities
Rating: 1.3 - ‎26 votes
Hey, Generac, make a change and start making generators that work, don't cost .....Standby generators are not supposed to be used as a primary power source ... and three months ago, I spent $4,000 to have a Guardian generator installed at ...
Generac standby generator - Propane - wont start?? - DoItYourself ...
www.doityourself.com/.../487838-generac-standby-generator-propane-w...
Feb 4, 2013 - I have a Generac 4LM41A standby generator that I need help introubleshooting and repairing. It is about 12 years old and hasn't been used ...
141 GENERAC complaints and reviews @ P'ed Consumer
Dec 12, 2015 | Generac GUARDIAN Standby Generator 10 kW/9...
I purchased a Coleman Powermate 5000 6 years ago: Ser: 94411583. Never really used it for any length of time. Kept for emergency. An electrician checked it for voltage output a short time ago. 240V...
Voltage is adjusted by raising or lowering the engine speed (governor adjustment), however one must also pay attention to the rpm because your generator was designed to produce 120 volts at 60 cycles while turning 3600 rpm. Your electrician should have tested for htz while testing for voltage. I would recommend re-testing under load and adjust governor to turn 60 cycles to see resulting voltage.
Sep 30, 2010 | Coleman Powermate Powermate 5000W...
Homelite 6000 Generator running rough, now won't start
Sounds like the engine is not getting enough fuel. Two possible problems:
1) I know this is a dumb question, but did you turn the fuel back on?
2) If the answer to question 1 is yes, then the small fuel filter inbetween the gas tank and carburetor probably has hardened. The inside of the fuel filter is a piece of foam and it is really common for the in line fuel filters to harden when no fuel is present and cause a clog in the fuel line. Try replacing the inline fuel filter and life should be good!
Jan 27, 2010 | Homelite Consumer Products 9.0 Amp, 14 In....
Hotpoint GE Household Microwave
Well, I think you should get a brand new one.
They do not cost as much to replace these days and it might be safer.
May 11, 2017 | GE Microwave Ovens
5500 generator stopped producing eletric after
First check with the dealer and see if it is still under warranty. If it is not, make sure nothing is blocking the air flow around where the control modules are located. This could cause the voltage regulator and other electronic parts to overheat. Next check the brushes and make sure they are free of any dust or build up preventing them from making contact.
If everything is OK the next thing I would do is change the voltage regulator.
Nov 17, 2009 | Coleman Powermate Powermate 5000W...
Coleman Powermate Premium Plus 6250W Portable Generator Logo
3,276 people viewed this question
Top Coleman Electrical Supplies Experts
John Trevino
Phil Walker
Phil Walker
Tim Garcia
Tim Garcia
Are you a Coleman Electrical Supply Expert? Answer questions, earn points and help others
