Question about Philips bSure SV1 Multimedia Projector
Displays desktop background but nothing else
I have hired a projector for a talk I'm giving, have connected the laptop to the projector and I get the desktop background displayed or the screensaver, but nothing else. Pictures as a slide show do nothing.
I have a hp dv9000 laptop and i am trying to connect to a toshiba tdp-xp1 projector. only get screen background. help!
Posted on Apr 30, 2009
I discovered that my laptop supports two monitors and the projector was acting as monitor #2. By changing the priority of the monitors I have got the information I need on the screen, but now not on the laptop. However, I can work the two from the screen and that will suffice for the moment, until I can find a way of getting the information on both!
Posted on Sep 06, 2008
I changed my desktop background and now my projector will not display
I would start by cycling this through the f4 option again first. Next I would connect the projector to the computer and then booting up the computer. Next I would disconnect the projector...turn it off, connect the projector again and then power up the projector. Try every combination of sequencing to get the computer and projector to talk to each other. It would not be a bad idea to change out the cable and try a new one as well. If it is a ceiling mounted projector then connect straight to the projector and try that.
Jan 07, 2013 | Hitachi Office Equipment & Supplies
HELP PLEASE!!! NEC NP-V260 Computer In can not detect signal from the Computer
Which connection type are you trying to use (VGA, HDMI, etc). It would help to know what kind of computer you are using and whether you are using the projector as the only display or trying to do multiple displays.</br>
If using a laptop then check and see if you have a key to switch displays. It will usually be one of the function keys (F4, F5, etc) and will most likely be a secondary action of the key requiring you to hold down your FN key then push the function key. This will switch between your laptop's outputs.</br>
If using a desktop you need to go to your display properties. Win7 right click the desktop and go to Screen Resolution. You need to make sure that the Multiple Displays setting is set to Duplicate These Displays or Extend These Displays to make sure that the display adapter is sending a signal to the projector.
Jun 28, 2012 | NEC V260 DLP SVGA Projector
I HAVE A DELL INSPIRON M501R, IT FAILS TO CONNECT TO EXTERNAL DISPLAYS LIKE PROJECTORS
Hi
You don't say which operating system you are using.
You don't describe what steps you have tried.
Therefore, the advice I give can only be general, rather than the specific advice I might be able to give if I had more background information.
To send the screen image from the laptop to an External LCD TV, Desktop PC Monitor or a Projector with a VGA or HDMI Cable:
Connect the cable to both devices > power up the laptop > simultaneously press the Fn key + a function key with the picture of 2 monitors (usually F5, F6 or F7) after the computer has booted into the Operating System's desktop and settled down.
I hope this helps.
If this answer does help you, please take the time to rate it. This helps answerers better understand the needs and the point of view of the asker and guides us in exploring the best ways to provide useful, high quality answers.
If you need further help, please feel free to post another question or add a comment to this question.
Thanks for using FixYa.
Sep 02, 2011 | Computers & Internet
We can't seem to get the picture from the laptop to the projector
For Windows 7 and Vista- Close or minimise all windows, right click on the desktop and select "Screen Resolution". Press the "Detect" button and if another display comes up, on the dropdown menu labelled "Multiple displays" select either:
"Duplicate these Displays" to show the same image on both screens
or
"Extend these displays" to have 2 separate displays (the position of the second display can be changed by dragging the box labelled "2"
For Windows XP - Close or minimise all windows, right click on the desktop and select "Properties" and then the "settings" tab. Click on the greyed out box labelled "2" and Tick the box labelled "Extend my desktop onto this display". click apply.
May 04, 2011 | ViewSonic Office Equipment & Supplies
I can see my background but cannot see anything else
The Fn+F8 in some laptops or Fn+ KEYS WHICH HAS MONITOR ICON OVER FUNCTION KEY) command tyically runs through 3 modes: Extend desktop, Laptop only, Projector only.
Mirroring displays (meaning you see the exact same thing on both screens) is not always on option on a PC; the ability to do that is dependent on the graphics card and drivers in the laptop.
Not seeing the exact same thing on both screens is often the preferred way, but when you don't see all your desktop icons it can be a bit confusing.
The trick here is that when you want something to show on the projector, you grab the window you're working with and drag it over to the other monitor. Why this is preferred is because you can be showing a powerpoint presentation on the projector, while you have a script or notes open in Word on your laptop display to read from. You see, you don't see anything but the desktop background on the projector because you haven't moved anything over there yet.
Your laptop is in extended mode, try changing to Laptop mode, should solve your problem or try dragging the required file to that monitor as said above
Please leave me comment, if you need further assistance
RNJ VINODKUMAR
Oct 24, 2009 | Acer Office Equipment & Supplies
Projector only displays desktop wall paper not laptop images
stop the dual monitor moded and it will project what is on the Desktop screen
for this right click on desktop -> properties -> (on the window) Settings here take away the check box for "Extend my Windows desktop to this monitor" and you can have what ever is displayed on your desktop on the screen
but if you keep the the existing setup then you can just drag the windows to the right or left edges and it will move on to the screen and you can use the projector image as an extended monitor, this will be useful when you want to have your presentation and your background work/ Document seperate from the viewing audience, try it you may like it
cheers
Aug 14, 2009 | Computers & Internet
MacBook connected Hitachi CP x301 Icons do not appear
Ok what's happening is that you have it set up as an extension of your desktop, you need to mirror the displays. when your projector is plugged in and it is showing only the desktop background, open "System Preferences," click "Displays," click "Positioning" and check the box that says "Mirror Displays." This should do the trick.
Mar 28, 2009 | Hitachi CP-X301 Projector
Laptop computer connected to projector.
When the projector displays the background image and the lcd displays the desktop as normal you can drag the open windows to the left or right and display them on the projector. it sounds like this laptop has an internal video card. If you right click on the desktop it might give you options to configure the display settings for the video card. Not sure how you will get to it if it does not show up on the right click menu. Probably through the start menu or in the control panel there should be somewhere to change the settings for the video card. This will no be under the display settings though.
But once you find your dual display options you will be able to change it to make both displays the same
Jan 21, 2009 | Dell Latitude D600 Notebook
HP Pavilion Dv2000
on your display properties, switch windows to appear on your laptop. and do not connect your LCD when booting your PC. there is an option in display property that says extened your windows to this display... that is your LCD.
Apr 10, 2008 | Acer TravelMate 2300 Notebook
No live picture on Benq digital projector
seems to me like your acer laptop's display is configured " extend my desktop to this monitor", that's why you can only see the desktop background. Go to your display properties and change it to clone display or uncheck the extend display option.
Mar 04, 2008 | Computers & Internet
Philips bSure SV1 Multimedia Projector Logo
562 people viewed this question
Top Philips Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Philips Office Equipment and Supply Expert? Answer questions, earn points and help others
