Question about Hitachi RAS-09UH Air Conditioner
Hitachi ras-5h gse
2 red led staying on in the indoor unit, fan not running on the indoor unit at all, out door unit compressor just starts and knocks of,no fault on control or out door unit.?????
    Problem Solver:
  • 5 Answers
First: The compressor is deffective
second: Fan capacitor is deffective
3rd: Running capacitor is deffective
Posted on Jan 26, 2009
Reverse cycle air conditioner cold winter
Slightly knock on the reversing valve, without breaking anything.
Dec 04, 2013 | Hitachi Heating & Cooling
Hitachi RAS-09UH Air Conditioner won't turn on
If you can access the pcb inside, check the mini glass fuse
May 18, 2012 | Hitachi RAS-09UH Air Conditioner
Hi, I have Hitachi model: RAS 63CHA4/RAC 63CHA4 The indoor unit looks working for the fan function, but not for the other function. The fan on the outdoor unit looks not working. What is the problem?
Is your compressor is working? If so, check motor to rotate manually. If hard to remove, replace bearings or motor. If easy to rotate, replace capacitor.
If your total out door is not working, check for power in out door unit. If not communication error between indoor and out door, provided you keep in right setting. If so, replace your indoor PCB.Helpful?
Jan 15, 2011 | Hitachi Heating & Cooling
My Hitachi indoor unit model RAS-26CHA1 is not giving out any cool air. The fan is working and have checked via manual. But manual does not have a trouble shooting section. Can you please assist me in...
To get cool keep temp setting 23 degree and mode in "cool" position. After compressor start, keep your hand on discharge pipe line (Smaller pipe), if it's warm your unit is starting cool. And also check with Amps meter for reading as per in name plate with the unit. If amps very less than specified, it's under gas leak.You have find out leak and arrest. Then charge gas.
Dec 28, 2010 | Hitachi Heating & Cooling
Instruction Manual need for a Hitachi DC Inverter room air conditioner model RAS-50YH4
http://www.hapm.hitachi-asia.com/index/techsupp/operationmanual/RAS_RAC-50YH4.pdf
Sep 08, 2010 | Heating & Cooling
Red blinking and ac not working
If the power "flickers" and unit fails but will restart once the breaker is reset, this sounds absolutley normal. It is a safety device that keeps the unit from burning up things due to improper power being supplied. As long as resetting puts it back into service with no issues, don't worry about it.
May 12, 2010 | Hitachi RAS-09UH Air Conditioner
Outdoor unit does not start. indoor unit fan does run.
by the sound of it the relay in the outdoor section is bad
May 31, 2009 | Heating & Cooling
Inverter unit fan and compressor wont run.
Sir/Maam,, Just Call or visit directly to your nearest service center, Thanx......
Jan 24, 2009 | Hitachi RAS-09UH Air Conditioner
Outdoor unit will not run
Some air conditioners have a thermostat that will not allow the compressor to run below a certain out side tempature as it will cause liquit to come back into the compressor(called slugging) and damage or destroy it.
http://www.hitachi.com.au/productsearch.aspx?pId=62&
Dec 14, 2008 | Hitachi RAS-09UH Air Conditioner
Mitshubishi split muh-18nvand inside msh-18nv
-Start the unit.
-Press EMERGENCY OPERATION switch.3-minute time delay works.Test run operation operates for 30 minutes.
-Check voltage to terminal block of outdoor unit.Is there 12V DC between 2-1?
-If voltage is presenet check the wiring, compressor contactor outdoor fan motor and compressor.
-If no voltage check voltage to terminal block of indoor unit.Is there 12V DC between 2-1?
-If if voltage is present re-connect the continuity of indoor and outdoor unit connection.
-If no voltage replace the indoor electronic control P.C.
board.
-But also check the coil thermistor sensor and room air thermistor if this two is out of range it can cause the tripping of out door unit. It has the resistance of 8 to 10 k ohms at 25 deg c temp.
Jan 04, 2008 | Heating & Cooling
Hitachi RAS-09UH Air Conditioner Logo
308 people viewed this question
Top Hitachi Heating & Cooling Experts
D. E. Hev
rugby prop
Are you a Hitachi Heating and Cooling Expert? Answer questions, earn points and help others
