Canon PowerShot A520 Digital Camera Logo
Posted on Aug 14, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
When I snapshot i do not have date and time stamp on the pictures why?
Anonymous
Level 2:
  • Expert 155 Answers
  • Posted on Aug 14, 2011
Anonymous
Expert
Level 2:
Answers
155
Questions
0
Helped
37946
Points
523
Hi ,your problem is setting of time and date. you can find the answer in this link http://usa.canon.com/cusa/support/consumer/digital_cameras/powershot_a_series/powershot_a520#ServiceAndSupport
Is it possible to stamp date and time on pictures using a kodak cd82 camera?
To set the date and time on your camera, follow these steps:
Turn on the camera and set the language and date/time by following the instructions in the Extended User Manual.
Once you have set the date and time, you can turn on the Date Stamp feature by following the instructions in the User Manual . The date and time will be stamped on all pictures taken with this feature enabled.
KODAK CD82 - EXTENDED GUIDE EXTENDED USER MANUAL Pdf Download ' ManualsLib
KODAK EASYSHARE CD82 USER MANUAL Pdf Download ' ManualsLib
How do I put the date stamp on my pictures?
Camera records the date and time each picture is taken, storing this information somewhere in the JPG file, so you can stamp photos after uploading them on a PC. You can use Time To Photo software. It can stamp photos automatically in a batch.
1helpful
How do i turn off the date/time stamp on my camera?
If you do not want the date and time stamp on future pictures, turn it off:
  1. Press the Menu button.
  2. Use the arrows to:
    1. Select the Setup menu.
    2. Select the Date/Time Stamp feature.
    3. Turn off the Date/Time Stamp feature.
  3. When you are finished, press the OK button.
Apr 02, 2015 • Cameras
6helpful
Need to email pictures showing the date and time stamp on panasonic dmc fh27
Turn on the [Date Stamp] setting in the [Rec] menu. See page 83 of this manual.
Date/time stamped
The date and time (and a lot more) are stored with every picture in its EXIF metadata. Any photo viewing/editing program should be able to display this data. To print this data, please consult the documentation for whatever program you're using to print your pictures. Depending on the program and printer you may print the date on the image, in the margins, or on the back.
If you want the date stamped on the picture, obscuring what lies underneath, set the "Date Stamp" option as described on this page of the user guide.
2helpful
I want to switch off the date stamp in my pictures taken with A480, please.
Press Menu, scroll down to "Date stamp" and across to select off, date or date and time, then press menu again. The date stamp only works in Postcard mode, so if you set a different picture resolution, that will also stop the pictures being date stamped.
4helpful
How can I take off the date stamp on pictures? my
Follow these steps:
  2. Select the Setup menu.
  3. Select the Date/Time Stamp feature.
  4. Turn off the Date/Time Stamp feature.
  5. Press the OK button.
If you find my solution helpful, you're kindly requested to rate it. Thanks!
13helpful
2answers
Canon sd 750 how to put the date in the picture?
here is the solution:
The date and time can be included on the pictures taken only with the camera in postcard mode. You must also activate the date stamp option in the menu.
To set the camera into postcard mode, press the [Func.] button on the camera, then use the [arrow down] key to go down to the last option in the menu, and there you can choose the [Postcard mode]. Press [Func.] again to exit the function menu.
To set the date and time stamp, press the [Menu] button and then use the [arrow down] button to go to the [Date stamp] option in the menu. You can set this to "Date" or "Date & Time". Press the [Menu] button again to exit the menu.
dsc_include_date02_tcm14-520511.jpgyour date and time are set now
congratulations!
Rate this answer if it is working with you
thank you
with all my best regards
[email protected]
Date and/or time stamp
date and time are already imbeaded in each picture.
for you to print it with the date and rime stamped on it......you'll ned a software to enable it before printing. The software that came with the camera have that feature.check print settings.
27helpful
3answers
Date stamp
To get the date/time to be on your photos while taking the picture so you don't have to use the software later do this:
When in the mode to take pictures, press the round "Function Set" button and change the recording pixels to "Postcard 1600 X 1200". "Postcard" is the only setting that will allow the time/date stamp to be recorded on the picture.
Then press the "Menu" button and scroll down to "Date Stamp". You can select "Date", "Date & Time" or "Off". You can only do this when your pictures are set to the "Postcard" mode.
Top Canon Cameras Experts
old marine
old marine
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Canon Camera Expert? Answer questions, earn points and help others
