Question about HP DeskJet F380 All-In-One Printer
Printer is totally jammed
Sir printer is totally jammed cartrige is not moving it is not scanning nothin is happening
    Scholar:
  • 116 Answers
Check whether any paper is jammed you can remove the jammed paper from the back of the printer .there is a assess door which can be easily removed and from there you can check if there is any paper jam and you can remove.if there is no paper jam and you still face the problem.it is necessary to open the printer and service the parts and oil the gears to make the printer move fluently.you can do it your self if you have proper screw driver it does not require any thing execpt a proper screw driver to disassemble the printer.or you can take it to any proper service center and it will work properly after it is serviced.
Posted on Oct 05, 2008
Epson Artisan 835. Just set up. Printed fine. Tried to eject DVD/CD tray. Did not eject. I turned off unit. Turned back on. Now constantly says I have a paper jam when there is none. Cannot use.
Hi. I Have an Epson printer too and become to send the paper jam error when there not a paper jam on the printer. Check the ink cartrige bay with the printer off. The ink cartrige bay have to stay all the way to the right. If not push carefully to the right. Start again the printer and see what happens. This cause in certain ocassions the paper jam error. I hope this tip can help.
Aug 13, 2013 | Office Equipment & Supplies
Hp photosmart 7760 print cartrige cradle is stuck.this happened after i ripped a paper jam out
try to move the cartrige cradle to left and right for about 10 to 11 times. if the issue still persist you may need to service you printer
Sep 27, 2009 | HP PhotoSmart 7760 InkJet Printer
It starts printing, then stops, the printer cartrige is jammed
Try emoving the duplex cartridge on the back (return printer to it's original configuration) and try printing. If the printer prints OK, then re-attach the duplexer checking for anything that could interfere with the print cartridge.
If the printer doesn't print, then I suspect something has fell into the printer and is creating enough resistance for the printer to detect and report. Turn the printer off, Remove all the cables from it. Try inverting the printer and gently shake it to see if anything falls out that could be jamming the printer cartridge.
Jun 02, 2009 | HP OfficeJet Pro K8600 Printer
False jamming at duplex unit in 6050
Hello sir; Pull out duplex unit check all the sensor, see does it on right positon and moving freely total about 4 or 5 sensors.
Feb 21, 2009 | Canon NP 6050 Copier
Error with Konica Minolta 2300W
Seems like when you changed the toner cartridge, that the cartridge is NOT SEATED PROPERLY when put back in the printer.
Take the cartridge back out and see if the side cover (held in place with one screw) is able to move freely on the cartridge, sometimes it sticks and won't allow the cartridge to run freely in the printer, thus this beeping noise and jamming of cartridge. there is also some small holes (three in total) on the inner side of cartridge (the side that goes in first) sometimes small bits of plastic are still stuck on the holes from manufacturing and you can remove this plastic around the holes with a knife, and give a free path for the cartridge to rotate.
Jan 27, 2009 | Minolta magicolor 2300W Laser Printer
Printer makes all the moves,but the paper comes out blank.
my usb epson cx5800f won't scan because the scan goes off before scanner
Oct 11, 2008 | Epson Stylus CX5800F All-In-One InkJet...
Paper jam
well..you may need to remove the software, and re install it...
and also, unplug the printer for around 5 min
May 30, 2008 | HP PSC 1210 All-In-One InkJet Printer
Cartrdge Jam
I would like to provide you a weblink of a document which is related to the issue that you are experiencing which would help you in this regard.
Here is the weblink:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00577763&cc=us&lc=en&dlc=en&product=441125&dlc=en&lang=en
Please revert me with the results..
With regards,
Ashesburn.
Nov 30, 2007 | HP Officejet 5610 All-In-One InkJet...
Carrier jam
Two solutions for you: 1)There seems to be a coating on the metal rod that the cartridges travel on. See it back there? With the power disconnected, wipe this rod with a kleenex and the problem seems to go away. It presents a drag on the cartridges and causes the problem. You might have to GENTLY forcibly slide the cartridge a bit to each side to finish cleaning the rod. ONLY DO THIS WITH THE POWER OFF!! 2) Or you can also turn off your printer, then slide the cartriges all the way to the left, and GENTLY wipe the encoding strip running right behind the cartrige carrier.(it will look like a translucent piece of plastic strip in most printers). Wipe it down with a soft cloth gently, then slide the cartriges all the way to the right, and repeat this process. When you are done, simply close the cover, power back up, and see if it will print a test page for you. ZT3000 "Beta tester of "0"s and "1's"
Aug 18, 2007 | Dell 922 All-In-One InkJet Printer
HP DeskJet F380 All-In-One Printer Logo
49 people viewed this question
Ben Johnson
