Question about Texas Instruments TI-84 Plus Calculator
Will not turn on
I've put new batteries in and still will not turn on
  • 3 more comments
  • riversfamily Sep 06, 2008
    replaced all the AAA batteries and the dot battery...still won't turn on
  • Anonymous Sep 08, 2008
    Mine won't turn on, I've replaced batteries, but it gave just a short message that the calculator had resetted, but then it turned off again...
  • john909 Sep 11, 2008
    power comes on for a couple seconds...flashing square does not flash.
    I put new batteries in
  • jurasek-park Dec 09, 2008
    I had a trouble with my graphing capabilities, i have since figured them out but when i was messing with it i was at the y = screen and hit the 2nd button then pressed down. the screen started fading and now it will not turn on.
  • firedragon33 Feb 01, 2009
    i did the exact same thing and it wont work now.
What i ended up doing was i kept messing with it and adding new batteries untill i accidentally cleared the ram, but in doing so, i figured out what i did. we must have set the brightness up too much, and so the whole screen is white, so it looks like it is off. just press the on button and press second and hold the up arrow untill you can see something on your screen again.
Posted on Feb 01, 2009
It may be that your contrast is too light. turn the calculator on (it will not seem like it) then proceed to press the 2nd button then click the up button a few times to return to normal contrast.
Posted on Dec 09, 2008
  • 9 Answers
Mine was acting up to. I found somewhere that the no/slow key response could be due to a short in the I/O socket. I blew into it really hard, and it worked perfectly after that. I hope this helps.
Posted on Sep 09, 2008
CX7300 Digital camera won't turn on. New batteries get hot after being put in the camera after a few minutes.
No. This camera requires service/repairs, the repairs will be more than this model camera is worth !!!!
Nov 12, 2012 | Kodak EasyShare CX7300 Digital Camera
Htc chacha wont turn on and orange light flashing
The battery is completely dead, charge for about 1 hour; if flashing light continues then you need a new battery, I've just done this to my phone..
Mar 29, 2012 | HTC Chacha Smartphone
MTG 900 SAYING "CHARGE" AND I'VE BEEN PUTTING
I am assuming you are reading the battery charge correctly. If so you need a new rechargable battery. Special battery so it is a little expensive. Make sure the person knows it is a "rechargable battery" you want. A regular battery will not work properly or recharge.
Nov 02, 2011 | Casio Atomic-Solar MTG900 Watch
Car would not start. we put a new battery in it worked then after a 100 mile trip we parked it at home and now it won't start. The lights all light up no clicking just silence
there 2 things that could possibly causing your problem either the battery you just bought isn't good aare you've got and alternator problem... Are you've been leaving something turned on, on the car that runs down the battery. let me know what happens.. Most of the Lexus have those problems.
Apr 30, 2011 | 2002 Lexus ES 300
My 2007 corolla won't start. When I turn the key in the ignition the starter makes a rapid clicking noise. I?ve tried putting the car in neutral and starting it that way, but had no luck. I?ve also tried...
1st check the main cable to the starter make sure it is clean and tight, disconnect battery first, after that there should be a small wire going to the starter jump that small connector to the main battery cable on the starter (IGNITION OFF) if it cranks you have a wiring or ignition switch problem if not Starter time just make sure you get a very good quality starter some cheap and even lifetime starters are so poorly made that even after you replace them you still have a problem only a bad noise coming from the new starter you just put in.
Oct 14, 2010 | Toyota Corolla Cars & Trucks
Dell Inspiron 531 (desktop) won?t turn on/boot
You've either got a bad motherboard or a bad processor (I'd lean to the motherboard being bad). I would honestly take this into a computer repair shop and have them check both.
Oct 22, 2009 | Dell Computers & Internet
I ve just opened the box and turned on phone.Nothing on screen!
send it back. It sounds like even if your were to fix this by taking out the battery and putting it back in, it should not do that new. Get it replaced ASAP
Aug 29, 2009 | LG Prada KE850 Cellular Phone
Texas Instruments TI-84 Plus Calculator Logo
133 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
