Question about VeriFone Omni 3700
Our verifone omni 3750 credit card terminal started making a beeping sound and would not accept input. Sometimes you can unplug it and then it will work fine or you can press many different keys at the same time and this will stop the beeping. Our challenge is if it is acting up at closing we can't get a batch done. It almost seem it has key jamed but none appear to be. Any ideas?
Depending on the type of business you are, the terminal can get pretty dirty on the inside and not look it on the outside. I had a florist contact me about similar issues with his terminal and after a good cleaning of the contact points under the pin pad the Omni worked fine.
Good luck
Posted on Oct 29, 2008
How do i change the ink in my verifone omni 3750 credit card machine?
It does not use ink, it used a thermo printer, need th thermo paper.
Aug 23, 2010 | VeriFone Omni 3700
I have a verifone omni 3750 . It has a continuous
The continuous beep indicates a break in the PED (pin entry device) connections on the main board or the PED fence is bad. It will need repair by a reputable repair facility.
Oct 06, 2009 | VeriFone Omni 3700
Slow input on Omni 3750
it needs to reprogram again.
erase all of memory and caches and re-install fresh file
most cases are fixed in that way.
Sep 18, 2009 | VeriFone (M19755014US1) Magnetic Card...
Verifone OMNI 3750 gives error message: NO MASTER KEY
The no master key means that the terminal is missing a DEBIT encryption the debit encryption is needed to run PIN based debit cards. When you swipe it should say Credit F2 Debit F3. When you choose F3 it will say no master key. Whether you have an external pin pad or internal pin pad your credit card processor needs to inject with the encryption or take the debit prompt off.
If you have any other issues please don't hesitate to call me. ext 105
Jun 25, 2009 | VeriFone Omni 3700
Wanting to use the loyalty feature on the Omni 3750
The features in your terminal are run in conjunction with servers at your processor or gift card provider. You cannot use those features openly with your internal loyalty program. I could set it up for you give me a call and I will give you the details on it.
May 18, 2009 | VeriFone Omni 3700
Add Credit to Gift cards with Verifone Omni 3750?
Get in touch with a gift card company or you processor (as many have programs) they will set you up with a program and cards and put the program in the machine.
Mar 10, 2009 | VeriFone Omni 3700
Verifone omni 3750 ethernet problems...
chances are you would need to RAM FILES, FLASH FILES, DEFRAG FILES....this is like resetting and crashing the terminal, starting all over again.
Try this, press F2 & F4 together you should be on GO VARIABLES, enter password 1 alpha alpha 66831 use the down arrow locate RAM FILES, CLEAR ALL GROUPS, CONFIRM, FLASH FILES, CLEAR ALL GROUPS, CONFIRM, then DEFRAG, ALL GROUPS, CONFIRM
Plug in your DSL or cable line (the one you are using) locate the DOWNLOAD, do a FULL
this should pickup your new IP address and make sure you are on COMM SERVER not on DIAL
(dial is only for analog phone line)
Nov 11, 2008 | VeriFone (M19755014US1) Magnetic Card...
3750 fails to complete transaction
it needs to reprogram the machine
erase all of Memory and cache
ask your processing company, build NEW terminal file
and install fresh one.
Sep 25, 2008 | VeriFone Omni 3700
Verifone omni 3750
here's some passwords you can Try: 1, 0000, 1234, 1701, 1739, 000000, 12345, 998877, 123456, 752036, 23378463, 45803155, 53664337, 1[Alpha][Alpha]66831, 6[Alpha]78727[Alpha][Alpha], Hope this help if not call us @ 775- 358-2922 : - )
Jul 09, 2008 | VeriFone Omni 3700
Verifone omni 3750
Use this Master Password from the manufacture #23378463
May 02, 2008 | VeriFone Omni 3700
Retail Supplies Logo
362 people viewed this question
Top VeriFone Retail Supplies Experts
danielle yancer
danielle yancer
Are you a VeriFone Retail Supply Expert? Answer questions, earn points and help others
