FixYa.com
Tags:
IBM TravelStar 60GH 60 GB Hard Drive
Disk crash data recovery (by 8 users)
posted by yish on Oct 20, 2005
At first my system was slow, then I got endless error messages on delayed write. When I tried to run scandisk it failed several times, but eventualy when I rebooted in went into scandisk automaticaly. Scandisk reported many bad sectory, bad file descriptors, etc. Eventualy it hung, and when I tried to reboot, the system went into a reboot loop.
I tried connecting an USB-IDE convertor to the disk and reading the files, but it hangs my computer.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
7 Other Users Have The Same Problem
Comment by gary5944, posted on Jun 28, 2008
getting read/write error. sometimes my system recognizes it as an external usb device (I''ve got it hooked up as such) and sometimes it doesn't.
Comment by Guest, posted on Jun 11, 2008
I cant read all cd-isand dvd-is, and when I burning it burns at 2x
Comment by arose2424, posted on Mar 30, 2008
external hard drive crashed and will not reconnect with the computer, have tried all usb ports nothing works, any other idea's?
Comment by Guest, posted on Jan 06, 2008
sir i have purchased a 300 gb seagate hdd. on 5th march 2006.from that day till now i have changed my hdd upto 6 th times....the problem is sometimes my system being slow,sometimes hanger,sometimes it comes like explorer error,sometimes disk error.but every times when disk error occures the common problem is that i formats the system through windows xp bootable disk but it is not done booting prperly then i go for patition magic bootable disk for formatting the partion.but it is not done then also.then a messege comes "# 701 ERROR". then the hdd is being damaged............I CANT UNDERSTAND WHY THE SAME THING OCCURING WITH THAT 300-400 GB HDD.FPR THAT I CANT DO ANY WORK & STORE ANYTHING IN MY SYSTEM..........PLZ SEND THE SOLUTION FOR THIS.....IN THIS EMAIL: dutta86@gmail.com THANK YOU.................
Comment by markoandme, posted on Nov 28, 2007
cannot retrive files on key. unknown hardware. key will not open or be recognized by my computer
Best Solution
posted on Oct 20, 2005
Helpful (85)
Kimi
Rank:Wiz Wiz
Rating: 80%, 608 votes
Try SPINRITE its the best software for recovery anf HD fixes.
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
posted on Feb 04, 2007
Thanks for Trying (70)
Good User
Rank:Apprentice Apprentice
Rating: 85%, 2 votes
try norton disk doctor under dos, it's a very good utility program and can fix your data problem it fronts.
Solution #3
posted on Jul 25, 2008
Not Rated (0)
anaesarora
Rank:Master Master
Rating: 98%, 7 votes
first do a fdisk
see if your drive is detected and what partitions does it show.
, then check if you can see on setup bios options.
if there on bios options.... lucky .... drive can be retrived of data.... and may be restored too.. but any clicks and sounds mean drive is ready to crash ,,back up data as it can go crash any time. more assistance 0-9-3-2-1-1-0-1-7-1-7-
s-k-y-p-e- a-n-a-e-s-a-r-o-r-a
Solution #4
posted on Sep 24, 2007
Not Rated (0)
datarecovery
Rating: 92%, 11 votes
To recover your data, please connect your failed hard drive to some other computer and then try using data recovery software to get back your inaccessible files. You can get the software from http://www.windowsrecovery.net
Solution #5
posted on Sep 23, 2007
Not Rated (0)
VMCOMPUTERS
Rank:Master Master
Rating: 87%, 18 votes
Unfortunally the only solution to your problem is to replace the hard drive. To recover your files i would recomend the following software in this website: http://www.unistal.com/prevent-data-loss...
Please let me know how it went,
Vincent
Solution #6
posted on Aug 30, 2007
Not Rated (0)
zulfiqar
Rating: 0%, 0 votes
u fix this hard disk to other computer and when
he doing scaning press any key to chancel and start in safe mode or copy your backup to other harddisk
Solution #7
posted on Aug 17, 2007
Not Rated (0)
benerjee
Rating: 0%, 0 votes
these are very common problem faced by todays people. I mean the hard disk crashed by various reason. Moun stated above comments about hdrc and yes , i'm agree with her that HDRC is the best solution for such problem. I'm a big fan of HDRC coz they always saved me from a big lost. Loosing all the important data is indeed a big lost. So , i must suggest you to visit their site www.hdrconline.com and i'm sure you'll enjoy too.
Regards
Ben
Solution #8
posted on Aug 16, 2007
Not Rated (0)
moun
Rating: 0%, 0 votes
Your hard drive have some bad sector problem.Dont do anything more with your hard drive otherwise your HDD go down into a physical condition. Try HDRC recovery centre is the best all over the world. If you need more details check the website:www.hdrconline.com.
Solution #9
posted on Jul 11, 2007
Not Rated (0)
TheRealHack
Rank:Master Master
Rating: 81%, 20 votes
Spinrite is OK but the HDD regenerator that the foreign guy made that is included on Hiren's boot disk has fixed drives that spinrite wouldn't.
Download a copy of the current Hiren's boot disk and run the HDD regenerator. It also includes spinrite.
Hack
This Problem Also Relates To: Acer (91.AB033.041) 73 GB Hard Drive Apple (M9741GA) 400 GB Hard Drive Buffalo Technology 250GB USB SATA 2.0 HD 250 GB Hard Drive HP (EK423AA) 300 GB Hard Drive Fujitsu (MHV2120AH) 120 GB Hard Drive Fujitsu 160GB MHY2160BH 2.5" SATA 5400 RPM 160 GB SATA Hard Drive Fujitsu Siemens (MHV2060AH) 60 GB Hard Drive
Can you Help with these Hard Drives problems?
Hard Drives
I/O error
Then it says Device [1:0:0]... Answer This...
Hard Drives
USB Plug and Play stopped...
My Beyond Micro 250GB Mobile... Answer This...
Hard Drives
necesito driver de sonido
sony vaio instal? windows vista... Answer This...
Hard Drives
drive not detected in Mac
I had used the Maxtor OneTouch... Answer This...
Hard Drives
My external hard Drive DIGITAL...
My computer doesn,t noticed it... Answer This...
7 Other Users Have The Same Problem - Continued
Comment by 25176122, posted on Nov 21, 2007
mine is a verbatim 1gb. i attemptemt toput a pass word on it. it then said i need to format it which i did. now the computer is not recognising it. i dont know what have happend
Comment by hameed504103, posted on Nov 15, 2007
my system is fast but my open mouse right button system load is very slow
Repair Service
Find Hard Drive Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
