Question about Magimix 5100 Cuisine Systeme Food Processor
Dough hook stuck
My dough hook appears to be "welded" onto the spindle. I cannot budge it. Is this a common problem? Can you suggest a solution?
Liz Stevenson
  • peter199 Sep 28, 2008
    We have just used the dough blade for the first time and seem to have the same problem - does anyone have a solution?
  • Sudha Aug 23, 2013
    My kitchen aid chopper gets stuck and does not come out. Ny solution
  • 99 Answers
New shaft cover req about £10.00 you will proberly have to replace any damaged blades aswell.
Posted on Oct 12, 2008
The extension post in my magimix 4200 is stuck on the motor shaft seems like It's welded on can anyone help
How to Change a Magimix Food processor plastic spindle.
This is meant as a guide only BBS ltd takes no responsibility for any damage done. We always advise that this should be done by a Magimix approved service agent.
The spindle is the part that sticks out of the motor this drives the blades, knifes, discs and cones for the food processor, this part may become worn after time or use.
Cover the main body with a cloth so as not to damage the look of the food processing machine.
Place two blocks of wood about 10cms either side of spindle cover. Then place two flat screwdrivers Horizontal either side of Magimix food processor spindle
Push down on handle of screwdrivers apply even pressure (keeping eyes well away from the spindle cover, they can fly off fast sometimes.)
The spindle will rise.
This will leave the metal centre shaft, Replace with a spindle cover bought from
www.magimix-spares.co.uk. Make sure you choose correct model, usually named on front of machine, or phone 01252 727755 for help.
When replacing, make sure that the New Food processor spindle is lined up and slide the spindle onto the centre shaft. Make sure this goes all the way down by gently tapping with a hammer.
All blades and attachments should be checked before placing back onto spindle cover, if the inside is damaged, this could damage the spindle cover again, any blade, dough blade , disc support that is marked should be replaced.
BBS Limited is the approved and dedicated supplier of Magimix parts & accessories for all Magimix products.
Please telephone +44 (0) 1252 727755 or fax +44 (0) 1252 727766 for help or advice. All images and text are Copyright (c) 2008 BBS Limited.
Magimix Spares Parts from BBS Ltd
Apr 03, 2014 | Food Processors
Spindle / shaft or mixer bowl?
if you say the motor is running but no blades moves in the cup.it means the shaft which is connected to the blades and the motors break down.
so i refer u to open it and check which shaft part is broken,or take it to the mechanic.
Jan 05, 2014 | KitchenAid KFP740 Food Processor
Unable to download Rhondo 2500 manual
the four pronged tool is a dough hook. Use this for kneading/mixing heavy dough, such as: white bread dough, pastry, etc.
Dec 19, 2013 | Food Processors
Kenwood a710a mixer suddenly lacks power
sounds like the motor armature is burn. Dissemble the unit, remove the motor. Loosen the bolts running from end to end of the motor and with emery cloth, clean the small metal plates on the ehd of the armature. They should be bright copper colour. I the armature is burnt, they will be dull brown. The other thing is to replace the brushes in the motor.
Feb 04, 2010 | Food Processors
The blade in my massive kitchenaid food processor appears to have welded itself into the bowl making removing it and getting the bowl with content off the spindle impossible. Can anyone help?
fill with hot water, see if that helps. You may end up losing the contents. Were you processing celery? If so, the blade is just bound up with the stringy stuff.. good luck-ned-
Sep 13, 2009 | Food Processors
Magimix blade is stuck
You need to replace the spindle i'm afraid which gets worn after a time. There a UK company that sells replacements and tells you how to replace it. Not a big job though a bit tricky. magimixspares.com
Jun 28, 2009 | Magimix 5100 Cuisine Systeme Food...
My disc stem is stuck and will not come out.
Without careful use and care, there is a possibility that the disc stem can become fused with the motor shaft. If excess pressure is being applied to the slicing or shredding disc, this can cause immense friction and cause the plastic disc stem to "weld" onto the motor base itself.
I would suggest calling Kitchenaid Customer Service to see what options are available.
Their toll-free number is: 1-800-541-6390.
Jun 06, 2009 | KitchenAid KFP740 Food Processor
Am I missing a part
I overlooked this too. Set into the foam packing material is a stem made just for the shredding disk. It's about 4" long and also has a hex shaft. This hex is just slightly smaller than the hex on the other shaft the drives the blades. The dough hook - Remove the blade assembly and put the dough hook in its place.
Apr 08, 2009 | Black & Decker Food Processors
Magimix sytem cuisine
Jul 02, 2008 | Magimix 5100 Cuisine Systeme Food...
Magimix 5100 Cuisine Systeme Food Processor Logo
728 people viewed this question
Top Magimix Food Processors Experts
Oloyede Monsuru
ray gallant
Are you a Magimix Food Processor Expert? Answer questions, earn points and help others
