Question about HHB BurnIt CDR830 CD Recorder
HHB 830 Repair manual
Hi do you still have the service manual?
  • mb388 Sep 22, 2008
    hhb 830 service manual
5 Suggested Answers
SOURCE: HHB 850 needs repair
You can contact HHB service team on 020 8962 5000. Or visit their web site and go to support and complete an equipment repair form and they'l get back to you. You can also email the engineers whose names are listed in the contact section. Web site is http://www.hhb.co.uk/hhb/uk/support. Hope it helps
Posted on Feb 05, 2009
  • 713 Answers
SOURCE: User manual
You can get it at www.manualsonline.com,www.manualnguide.com or at their website.
thanks and good luck
Posted on Jun 04, 2010
dunnbiker
  • 8546 Answers
SOURCE: what does pma rec mean on the hhb cbr 830 ? it
The recorder is writing TOC data to the disc's PMA (Program Memory Area). Never turn off the power while this display is
showing.
http://www.retrevo.com/support/HHB-CDR830-CD-Players-manual/id/3875ci874/t/2/
Posted on Jan 23, 2011
SuperTech-11
  • 1591 Answers
SOURCE: Live kick drum causes HHB 830 Burnit Plus to stop
Absolutely. You are going to have to isolate the drummer from the writer somehow.
We used to put the drummer in an isolation booth.
You can also try building a "foamy box" for the CD writer. The kind of foam you want looks flat on one side, and sine wave like on the other. Put the flat sides out.
Build it with just the front open, and run the cables under the recorder and out the front if length allows.
CAUTION: I recommend using this enclosure ONLY when there is a live drum being recorded live.
This is because prolonged enclosure like this may cause heat issues.
TIP: which ever side faces the drummer, the writer should not be touching that foam wall.
IE - if the rear faces the drummer, the box should be big enough that the rear wall doesn't touch the writer.
Good luck, and let me know how that all works out for you!
(hey, it's easier than suspending the writer with elastic or bungee cords!)
[subnote - yes, that works too, but it's a pain in the **** building the metal frame!]
Posted on Feb 25, 2011
Need to download a free repair/service manual for a Bernia 830
Request the repair/service manual directly from Bernia (Bernina?). It may or may not be downloadable.
Jan 04, 2015 | Sewing Machines
Hi, I have an HHB Burn-It CDR 830. Whenever I'm recording, along about the 5th track in- the player starts to fuzz out. The time stutters/freezes momentarily, and then continues normally for a while...
If it's always around the same physical location on a given CD it would have to be a physical problem with the transport, not the lens.
Esoteric but comprehensive advice....
http://www.repairfaq.org/sam/cdfaq.htm
Sep 20, 2011 | HHB BurnIt CDR830 CD Recorder
Hi there, when recording analogue from mixer to HHB Burner 830 the blank cd does not read properly, and records blank even thou the connections are in the right ins and out (phono to phono) And the input...
I can only assume that it's not changing the analogue signal into a format suitable for transferring to a CD. Check the recording settings. Make certain the signal is being converted to say a WAV format or MP3 etc.
May 01, 2017 | HHB BurnIt CDR830 CD Recorder
What does pma rec mean on the hhb cbr 830 ? it just stops recording
showing.
Aug 13, 2010 | HHB BurnIt CDR830 CD Recorder
User manual
Jun 04, 2010 | HHB 830 Plus CD Recorder CD Player
Pause/resume function in analogue, manual recording mode
This player has essentially the same guts as my Pioneer PDR-509, so this is what it means...
'Repair' means the player lost power in mid-recording without commiting the track memory to a table of contents. It would likely take up to 40 minutes for the player to reconstruct it from the disk.
There is NO reason the player need be turned off (if that's where it took you) for a track pause.
Just press Pause, flip the LP over and hit Play or Pause again when you wish to continue recording.
Perhaps you don't know how to Finalize the disc either. It's not that intuitive. Press Finalize, after a while it will display a time, like 4:07. That means how long it will take to do the operation. Now press Pause and it will count down to 0:00 and be done. Then you can play it on any other CD player.
Feb 14, 2010 | HHB 830 Plus CD Recorder CD Player
Cannot use the finalize function anymore
they wear out have it serviced and cleaned
Nov 05, 2009 | HHB BurnIt CDR830 CD Recorder
Dec 26, 2008 | HHB CDR850 CD Recorder
HHB-830 CD TRAY does NOT open.
It's made for HHB by Pioneer, you could try one of their agents?. Opening up is fairly straightforward if you are methodical and take your time if you need to. There is a test mode sequence you can try - hold down the 'menu/delete' and 'auto/manual' keys together for 5 seconds until the display blinks all the lights then press the stop button. Now ONLY press the open / close button - pressing any other keys will change settings and without the service manual you won't know what you're changing. Press stop then power it off to exit.
I can email you the service manual if you need it. It sounds like a gear has come loose inside to me. I strip these machines for parts quite regularly so may be able to help you out if you're able to work out what if anything is broken but I'm in the UK. It may be as simple as a belt has come loose :-)
Feb 28, 2008 | HHB 830 Plus CD Recorder CD Player
HHB 850 CD Burner - lockup problem
I did find out how to do the manual eject, for a stuck cd. Open up the machine, looking at the front/top, on the lower left side of the cd transport there is a white plastic gear that can be turned with your finger, ejecting the cd.
Oct 30, 2007 | HHB CDR850 CD Recorder
HHB BurnIt CDR830 CD Recorder Logo
173 people viewed this question
Top HHB Audio Players & Recorders Experts
John
John
darren dillon
Level 1 Expert
Are you a HHB Audio Player and Recorder Expert? Answer questions, earn points and help others
