Question about Microsoft Xbox 360 Console
2 red rings of light appear on my 360 every time I turn it on. I am aware this is an overheating problem but what should I do to stop it?
    Problem Solver:
  • 9 Answers
This means your xbox has overheated and must cool down. just leave alone for a while.
Posted on Dec 31, 2008
    Scholar:
  • 125 Answers
THINGS TO TRY loadTOCNode(1, 'whattotry'); 1. Let your Xbox 360 console cool. You may have to wait several hours for your Xbox 360 console to cool enough. Don't turn on your Xbox 360 console when the console is hot. 2. Verify that your Xbox 360 console has enough ventilation and that the fans are operating. For more information about ventilation, see the "More Information" section. 3. If the two lights continue to flash red after you try steps 1 and 2, contact Xbox Customer Support. For more information about how to contact Xbox Customer Support, please visit the Xbox Support (http://www.xbox.com/support/) Web site. 2 red rings of light - uparrow.gifBack to the top
MORE INFORMATION loadTOCNode(1, 'moreinformation'); To try to prevent this problem, use the following precautions: • Don't block any ventilation openings on your Xbox 360 console. • Don't put your Xbox 360 console on a bed, on a sofa, on a carpet floor, or on any other soft surface that may block ventilation openings. • Don't put your Xbox 360 console in a confined space, such as a bookcase, a rack, or a stereo cabinet, unless the space is well ventilated. • Don't put your Xbox 360 console near any heat source, such as a radiator, a heat register, a stove, or an amplifier. If these solutions do not work for you, best to contact Xbox support at http://xbox.agent.asahost.com/ to talk to a live agent. :)
Posted on Sep 05, 2008
  • Mighty B
    Mighty B Sep 17, 2008
    All the geniune help I give you and you rate INAPPROPRIATE? Don't ya think that itself IS inappropriate?? You ****.
  • Mighty B
    (They put stars like I said a naughty word, not the case)
Has 3 red blinking lights
Red Ring of Death: Red Flashing XBOX 360 Lights Explained Common Xbox 360 Red Ring Errors The XBOX has a reported 54.2% failure rate which makes the XBOX 360 gaming consoles' worst "lemon" to date. If you find yourself with the red flashing lights error, --> lg.php?category_id=15&content_type=article&content_type_id=2663399&key_page=682482001924178892&site_id=1&bannerid=11791&campaignid=3153&zoneid=23&loc=1&referer=http%3a%2f%2fwww.associatedcontent.com%2farticle%2f2663399%2fred_ring_of_death_red_flashing_xbox.html%3fcontent_type%3darticle%26content_type_id%3d2663399&cb=8da55f49a0 follow this guide to try and pinpoint the problem with your XBOX 360.
1 Red Ring = Serious Hardware Failure
I f your XBOX 360 has a 1 red flashing light error, you're more than likely in big trouble. The 1 flashing red ring of light can be due to GPU or CPU failure, RAM overheating, a DVD drive error, or some serious problem with your Xbox 360's internal components. The most common 1 flashing red ring lights error is the E74 error. The E74 error is no easy fix for the Xbox 360 and usually has to be repaired by the manufacturer [though some have managed to repair it with the heat gun trick - but be careful]
2 Red Rings = Overheating
Mostly all red flashing lights on the Xbox 360 rings are due to overheating in some way or other, but the 2 red rings singles out overheating as the main issue. When doing the X-Clamp fix the 2 red rings are required to fix the Xbox 360 by overheating the CPU. If you get this Xbox 360 error without doing the X-Clamp fix, you probably just need to let your Xbox 360 cool down for a few hours. Make sure that all vents aren't blocked off and that your Xbox fans are working properly in order to repair this problem.
3 Red Rings = Basic Hardware Failure
The most common error on the Xbox 360 is the 3 red rings - also known as the Red Rings of Death (RRoD). This flashing lights problem is the main cause of Xbox 360's 54.2% failure rate. The 3 red flashing lights can be due to lots of different errors but is mainly due to the X-Clamps in your Xbox 360 and overheating. Fortunately, lots of people were able to fix this issue using the X-Clamp and heat gun fix. Follow this list of error codes to find out the real issue with the 3 red rings because there are quite a few of them.
Jan 07, 2011 | Microsoft Xbox 360 Console
Upon turning on xbox 360 power light has a red circle
on the ring of light there are 4 lights
1 light = hardware malfunction
2 lights = overheating
3 light = RROD (red ring of death) your GPU has come loose
4 lights = a/v cable is loose/bad
Oct 22, 2010 | Microsoft Xbox 360 Console
Three flashing red lights
3 red lights is the gpu and the cpu overheating if you stop the heat build up getting to the chips it will work for you you can do this at home or you can use a good guide to fix this error.
Jul 23, 2010 | Microsoft Xbox 360 Console
What would cause a 2 ring malfunction?
2 red lights is overheating, try giving it a dust out and if this does not work you will need to stop the heat build up inside.
To do this you can send it in or use a good Xbox 360 Repair guide to fix it.
2 red lights is purely overheating.
Feb 22, 2010 | Microsoft Xbox 360 Console
My xbox 360 freezes after being on for a couple of minutes. How do i stop this
If it freezes and then the next time you turn it on has red lights on the console display check out the corresponding Microsoft articles for the number of red rings on the display. They appear in quadrants on it.
1 red ring
2 red rings
3 red rings
4 red rings
If you do not have any rings, your console may just be overheating. Give it a while to cool down and if that doesn't work, give Microsoft a call: 1-800-4MYXBOX. Good Luck!
Jan 05, 2010 | Microsoft Xbox 360 Console
My son's xbox 360 has 3 red lights how to fix it.
type in fix red ring of death on youtube it will teach you.
Jan 01, 2010 | Microsoft Xbox 360 Console
Xbox360 show 2 rings
2 rings means overheat
leave it in a cold place for some hours and it should be ok
Oct 21, 2009 | Microsoft Xbox 360 Console
My xbox360 will not stop flashing red
Sorry, only answer is to phone xbox and arrange to have repaired. Good news is its all free and should be back with you in 2 weeks.
Sep 20, 2009 | Microsoft Xbox 360 Console
Game freezes after playing for a while but no red rings appear
Games freeze for two reasons. Overheating and the hard drive locking up. If you have your games installed, you most likely eliminated the overheating problem.
Since you are not getting Red Ring, it probably isn't overheating. That leaves the hard drive. Turn of the console and unplug it. Remove the hard drive. Now is a good time to clean any dust from the connectors or vents. Reattach and play. Some games like Fable 2, Fallout 3, and others are more prone to freezing when accessing the hard drive that others. If it is freezing more times than not, you have an issue with the hard drive.
Jun 09, 2009 | Microsoft Xbox 360 Console
Two red rings
The 2 flashing red lights may indicate that there is a hardware problem with your Xbox 360 console. The main thing that causes the 2 red lights to start flashing is because of overheating and as the motherboard within the console takes more heat it actually warps and bends until the solders become loose.
Once this happens you will receive the 2 red lights. Even before you get the 2 red lights you may have noticed your games freezing and this is caused in the same way, by overheating. As the chips take more heat they shut off to prevent lasting damage, although they can only do this a number of times until you get the Xbox 360 2 Red Lights.
To fix the problem you need to stop the level of heat the motherboard takes and you can do this in a number of ways, but it will involve opening up your Xbox and working on it. In addition, you could always send your Xbox back to Microsoft as they are offering free repair for this error, you will just need to wait 3-4 weeks that's all.
There is one more option available in the form of DIY Video Guide, that will explain you step by step approach to fix red ring of death within one hour without any technical knowledge.
Jul 18, 2008 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
102 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Martin Murray
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
