Question about Tao XM2go Satellite Radio Receiver
Antenna Connection Problem
I have used my XM2Go in my office with an Altec-Lansing base and window antenna for several years and I occassionally use the unit in my car with a roof magnetic antenna. Recently the unit has experienced weak signal at the desk and then swithces back to channel 1. Over the weekend I tried to use it in my car and it could not find a signal when connected to the cupholder base. All connections seemed tight and the unit showed a signal before I set it into the base, but once in the base it lost all signal and displayed a message indicating no antenna connection. I am wondering if the tuner or antenna connection are going bad as electronics are wont to do. Is there a way to check or have it repaired? If the cost of repair is high, is there another unit which will utilize all of the accessories (desk speakers and car connections) that I already own?
Thanks for any helpful hints as I like the potential portability and feel frustrated.
Digitally,
  • dcgibbski Nov 19, 2008
    I am experiencing the same problem with my Sportster replay unit.
    I have replaced antennas but still have the same problem.
    The unit says aquiring signal.
    When a friend of mi9ne plays his unit beside mine, his works fine.
    Is there a way to have the receiver serviced and is it expensive?
    Thanks
  • ck48t Nov 21, 2008
    Dear dcgibbski,
    I finally heard from XM about service possibilities: None available. They referred me to another manufacturer who's tech support stated that for discontinued items no services are available. I did some more digging and found that, in my case, the Delphi MiFi radio appears to use the same interface and be virtually identical to the Tao unit in all of its features, AND it is still available for sale. So the only solution I have found is to replace the unit with one having an identical interface. See here for a display of the interface (page 10) http://file.xm411.com/manuals/MyFiUserGu... . Perhaps you can find a similar unit to your own. It is mighty frustrating! I will be going to CES and I will give an earful to XM and Tao about maintainability and service.
    Digitally,
I have the same exact problem. I took a small needle nose pliers and pressed the antenna connection on the TAO radio. I put it back into the cradle of my Altec Lansing amplified speakers. It works again. For how long we will see.
Posted on Dec 30, 2009
The radio will not turn on ,not manually and not with remote
power suplay Transformer dies...
Try to find another suitable transformer and try running it
Nov 24, 2013 | Delphi Myfi Xm2go Portable Satellite Radio...
How do I open the altec lansing inMotion im600? I
There is a button on the front of the unit that is just below the LCD readout that shows FM / iPod status. Press the button. If it does not open the unit, you may need to tap the back of the unit when doing this or else get something to gently pry open the unfolding section WHILE THE BUTTON IS PRESSED (otherwise you'll break the mechanism and won't be able to lock it again. It sounds like whatever you put in to create the connection may be jamming up your opening.
The unit comes with several adapters for different iPod models, you may want to try a different adapter; you shouldn't need to put anything else in it to maintain a connection. If you don't have those adapters anymore, you can probably get them off the altec lansing web site.
Jan 12, 2011 | Altec Lansing Inmotion-IM600...
I'm looking for a replacement antenna for the IM600. The original snapped in the middle.
I had the same problem, email altec Lansing and they will send you one out. It took a few weeks but I got one.
Sep 09, 2010 | Altec Lansing Inmotion-IM600...
I would like to connect my antenna directly to my XM2GO unit without the docking station. Where can I find an adapter?
Simple. Go to http://xmfanstore.com , click on "Antennas and Extensions" under "Shop Categories" on the left most side of the site; there you will find "XMFanStore XM2go Direct Connect Antenna Adapter" .
It plugs into the SIDE antenna port of your XM unit and you plug the antenna into that.
This URL MAY be a shortcut:
http://store.xmfanstore.com/directconnect.html
May 27, 2010 | Pioneer AirWave XM2Go Satellite Radio...
No reception
your antenna connection inside the unit is broken on the circuit board,i had one of these and repaired it numerous times by taking the unit apart and resoldering the connection at the board,also their antennas don't last long as far as the antenna plug end is concerned
Apr 30, 2010 | Delphi MyFi SA10113 XM Radio Receiver with...
Need the pairing code for bluetooth device to my Altec Lansing
Hi if your intentions are too connect your Phone to that bluetooth device , The paring code is what you make it , when you connect the two device's together , When you search for devices it will ask you to pair with that device , and you make the code anything you wish....Otherwise have a look at the manual under connection , it should have .
I hope this helped bud
Happy new year
Dec 24, 2009 | Altec Lansing iMT525
Fm stereo
FM radio reception relies on a very good working antenna and cable, AM reception much less so. Unfortunately, the problem could be in the radio itself as there are separate signal processors in it for FM and AM. However, the most common problem is a bad cable connection at the antenna or the radio, or a bad cable itself (corroded, pinched, broken wire inside).
A couple of simple things to check: if the antenna is in the window, it may have become disconnected from the cable at the window. If the antenna is body mounted, could be a bad cable connection at the base of the antenna, and in this case, the base of the antenna could be very corroded.
You could also check the antenna cable from end to end using a continuity checker. If you can't figure that out, you could just try replacing the cable (or body mounted antenna in that case).
Dec 19, 2017 | 1997 Jeep Grand Cherokee
Atenna connection when using Altec Speaker or Car Kit
Dear xm2go,
I could not find any service options for my own Tao XM2go unit. The only option appears to be the Delphi MyFi unit which appears to be identical (see page 10 here: http://file.xm411.com/manuals/MyFiUserGuide411.pdf )
digitally,
(/\/\<erwin
Oct 07, 2008 | Tao XM2go Satellite Radio Receiver
Delphi xm2go internal antenna
Don't use the wearable antenna - reputed to not work well - was not a good design idea - I don't think any of the other receivers have this feature if that tells you anything. Record music you like on the myXM feature, and play that when you would otherwise want to receive on the antenna. If you are listening to live news, etc, there may be no good solution. (I have read there is an antenna headset, but don't know much about it, but some reports that it works.)
Jul 23, 2008 | Delphi MyFi SA10113 XM Radio Receiver with...
Air ware xm2go
The unit has an internal antenna (that is really poor) that is activated when you unplug the external antenna. This is why you get some signal when you unplug the unit.
I assume the problem is the antenna itself.
My suggesion is that you charge up the unit, take it to a place that sells XM equipment AND has a demo unit working. Be sure to take your docking station with you (it has the plug in for an external antenna). Ask the sales rep to please connect your unit to an external antenna to test your unit as you are trying to determine if your antenna is bad. If it works, you need a new antenna (cable may be cut on the inside or antenna may have water/weather damage). If it does not, then there is an electrical issue inside the unit and the unit itelf will need replacement/repair.
Jul 03, 2008 | Pioneer AirWave XM2Go Satellite Radio...
Tao XM2go Satellite Radio Receiver Logo
224 people viewed this question
Top Tao Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Tao Audio Player and Recorder Expert? Answer questions, earn points and help others
