Question about Yamaha RX-V995 Receiver
Yamaha RX-890 when I turn up the volume it turns off
  • Anonymous Feb 21, 2009
    same problem with 2095
I have the same problem with a RX-V995 Yamaha Reveiver.
Tim
Posted on Sep 06, 2008
No sound on left front speaker
you need to set up the individual volume levels for each speaker.
do a sound test tone which will check for a signal from each speaker.
if you hear the speakers at different volumes you know you need to adjust the ones that are too weak. hope this helps
Mar 27, 2014 | Yamaha RX-V420 Receiver
Need manufacturer's setup code for Yamaha AV Receiver RX-V373
Using 1056B03 universal remote from Time Warner. Several codes actually will turn the unit off and allow volume control. Or..I can turn on and volume control. Can't do both. I tried to use the receiver codes in the vcr mode, but the remote rejects receiver codes (i.e. only accepts vcr codes).
It looks like one or the other, not both.
Jun 16, 2012 | Yamaha Audio Players & Recorders
Yamaha receiver picture disappears and reappears when changing volume
I had the same problem with HDMI input to the RX-V373 from a DirecTV receiver. The RX-V373 volume display and menus on the screen are HD only, which forces the monitor to switch modes when viewing SD.
My solution was to turn off 480i and 480p signals from the DirecTV receiver, and also turn off its native output. The DirecTV receiver then upconverts SD signals to HD. Changing RX-V373 volume then doesn't affect monitor video mode.
May 10, 2012 | Yamaha Audio Players & Recorders
Dear Sirs, I have a Yamaha Rx- v363 receiver 2008 yr. model. I'm looking for help in programing the volume control on this unit. When I turn the unit off and then back on the volume it stuck on its highest...
Page 48 under Set Menu:
Initial volume INI.VOL.
Use this feature to set the volume level when the power of this unit is turned on.
Choices: Off, -80 dB to +16 dB
Control step: 1 dB
Feb 20, 2011 | Yamaha RX-V363 Receiver
Yamaha rx-v530 volume maxes out when turned on
If you are using the remote to raise the volume of the unit, my advice is to forget that function, and turn volume manually. I had a similar problem with a Sony receiver and the solution was simply to put aside the remote. Remotes are infra-red based, and if you have other components with infra-red this can cause undesired interference and malfunction. Good Luck.
Flavio/BRAZIL
Jul 26, 2010 | Yamaha RX-V530 Receiver
My Yamaha RX-V661 shuts off at moderate volumes.
Try to disconnect speakers one by one and see if any of them causes the problem.
Nov 05, 2009 | Yamaha RX-V661 Receiver
Logitech 890 remote quit working
It just started working again. Maybe it took the day off.
Jan 11, 2009 | Logitech Harmony 890 Universal Remote
Yamaha RX-V995 Receiver Logo
268 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
