Question about Acer Aspire E380 ASE380-UD500A PC Desktop
Install extra memory
I install the extra memory stick in the acer desktop, with no problem as you help me in the past. But the computer kept re booting in the middle of a task. I dont know if i did it correctly or not. Are you suppose to tell the pc that it has extra memory so it can update itself or does it do it on its own?
Scoobie
    Master:
  • 505 Answers
When you put new memory in the system automatically updates it for you right click on my computer and go to properties and it will tell you the total memory you have
Posted on Sep 05, 2008
1gb stick from compaq not working, 1beep then 2beeps, hangs on startup
more often than not when you install extra memory you have to reload computer.make sure that stick is inserted correctly. then do a reload.
hope this helps.
Apr 29, 2010 | Compaq Evo D500 PC Desktop
How to transfer a program using a memory stick to a netbook
Connect the memory stick (pen drive) to the computer. It would be detected as for eg. drive g,h, i. Please check it once and double click on it. You would be able to see the programs on the memory stick. Now, right click on the program you want to transfer from the memory stick to the computer and click on "send to".Now, you can click on Desktop. the program would be on the desktop.
Apr 18, 2010 | Acer Aspire One Netbook 8.9" Notebook
Iwant to install an extra 1GbRAM-what specs/Pt Nos do i req; For Acer Veriton 5100
Hello
Thank you for using
FixYa for your problem
Sorry but on there website max is 512MB of ram
Please rate our solutions and if you still have problems please call back for more ideas to help you
Thanks
Richard Scott
Technical Support
New Zealand
Nov 30, 2009 | Acer Veriton 5100 PC Desktop
Can I load drivers downloaded to a disc,and install on other pc
Yes, go to Acer site, locate your model for drivers. Download them into a folder on your other machine (the one with internet access). Then insert a USB stick and copy and paste the folder to the stick. Now just insert the stick in the Vista machine, drag the folder to your desktop and begin installing your drivers.
Here is a link to your drivers. Click on desktop / Aspire / M1640 then make sure to set the operating system to Vista Ultimate.
Hope this helps.
http://www.acer.ca/acer/service.do?LanguageISOCtxParam=en&miu10einu24.current.attN2B2F2EEF=3751&sp=page15e&ctx2.c2att1=27&miu10ekcond13.attN2B2F2EEF=3751&CountryISOCtxParam=CA&ctx1.att21k=1&CRC=719687231
Oct 21, 2009 | Acer Aspire M1640 Refurbished Intel...
I purchased two 1GB pc2-4200 memory sticks and my Acerr Aspire T180 wont recognize it. It starts beeping and wont Boot. The reason I bought them was that my computer was running very slow after I re...
Hello there:
first off you will need to ensure that the memory that you have purchased is fully inserted in the slots next ensure that the memory is compatable with the motherboard that you have and your system
go to the manufactures web site of the computer and there will be a technical support option there with phone numbers to help you.
Also you may also want to swap slots with the memory sticks and see if this helps ok so please try these ideas. ok
best regards mike
Jul 31, 2009 | Acer Aspire™ T180 PC Desktop
How do I transfer files from my old computer to my new computer using the memory stick I bought?
ok my friend its easy
just plug in the memory stick in the old computer and copy/paste files from the old computer to the memory stick (don't forget to look at the size the files might be over sized and the memory stick wont save them).
now after finishing the copy paste from the old computer to the memory stick, take the memory stick out and plug it in the new computer and copy/paste the files from the memory stick to the computer.
you may need to do these steps for few times if you have a large amount of data
cheers
Sep 11, 2008 | Computers & Internet
How to install extra memory to acer desk top?
It shouldnt be that difficult if your refering to extra Ram. Its just a stick, usually green with gold connectors on the bottom. If you remove the outer case or side of the pc (shutting it down and unplugging it first ofcourse) You can look in and should be able to see the original ram stick in the motherboard. Usually there are plastic clips on either end of the ram slot, push them all the way out, this opens the slot up, put the stick in with the metal parts down obviously, even apply pressure to both sides until the clips pop up locking the stick in place.
Aug 06, 2008 | Acer Computers & Internet
Compatability of Memory Upgrade
One or both of your RAMs have developed a fault. Change both RAM. After changing RAM pl format again and than try. Do not insert those faulty RAM again. Get your RAM tested by a software which is available on Microsoft site for free.
Thanks
Bhaskar
Jun 04, 2008 | Acer Aspire™ T180 PC Desktop
Increase Memory.
no u dont need look @ the bios>if u insert it properly that should display it if it is not then teh card is bad>or the slot on the board if the solt works with the other card then there is no issue with the slot so replace it rate me solved if its help full thx
Nov 05, 2007 | Acer Aspire™ T180 PC Desktop
Memory/Graphic problem
This might have something to do with DVMT or Digital Video Memory Technology. Basically, the amount of video memory is dependent on the amount of memory installed. I'm not very familiar with acer system BIOS but try to look for VIDEO under system BIOS and try to select any fixed video memory if possible. you can also try to disable DVMT.
Sep 30, 2007 | Acer Aspire 3680 Laptop
Acer Aspire  E380 ASE380-UD500A PC Desktop Logo
94 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
