Question about Maytag MMV1153A Microwave Oven
No heating runs louder won't heat everything works
  • michaudkofc Sep 27, 2008
    Everything works on the microwave, but it does not heat. Although it runs no louder than when I first installed it.
  • Maytag Master
  • 9,098 Answers
In most cases, with a louder noise and no heat (if the turntable and light come on) then you have a shorted high voltage rectifier diode or a bad magnetron.
Here are some links you or a friend can use for test help, but read the safety warnings first:
http://www.gallawa.com/microtech/diode.html
http://www.gallawa.com/microtech/mag_test.html
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
Posted on Sep 06, 2008
My Neff microwave H5470NOG/03 has stopped heating food, any ideas?
It has a internal Dio fuse..You have to take cover off to see it.. Warning...High Voltage...There pretty cheap...
Oct 04, 2017 | Neff Microwave Ovens
Microwave won't heat
This is very likely a faulty Magnetron especially as there is not heat. To repair this would mean replacing the Magnetron which is a fairly standard repair for a Microwave oven
Nov 26, 2012 | Microwave Ovens
I have the danby designer Mod DMW162W-ORT that won`t heat at all but everything else works. Hums a bit louder but will not warm.
The Magnetron in your unit is no longer resonating properly. The Magnetron produces the microwave frequencies and when it resonates properly, it will provide the excitation to heat your item(s). As well, the diode that accompanies the magnetron needs to be replaced as well. Should it be under warranty, take it back. Out of warranty? Have an appliance tech repair it (usually around $175) or get a new microwave.
This is typical for most microwaves. No such thing as quality any more.
Apr 12, 2011 | Danby Microwave Ovens
Less than 5 years old - Microwave Panel lights up, turntable turns, fan works - everything works except it doesn't heat food. Heard a pop, and now it runs louder than before but doesn't heat. Any ideas?
That pop was the magnetron frying. This is a repairable problem, but feirly expensive, around $300 if you have it done by a professional.
Please rate my response if it was helpful to you.
Thanks, Repairman45.
Dec 02, 2010 | Frigidaire PLMV169DC Microwave Oven
Microwave model MV-1510M is not heating, also sounds louder. Everything else is working, fan, lights, turntable etc..
If everything is working normally, except for heating, the likely cause is the magnetron.  Microwaves can be dangerous to work on, as the site below points out.  If you have an ohmmeter, it is possible to check the magnetron, but be certain to follow the precautions outlined at the webpage:
Oct 08, 2010 | LG LMV1680ST Microwave Oven
My goldstar mv1501B won't heat anything. What' wrong?
everything works except the heating system what shell i do?
Mar 25, 2009 | Goldstar MV-1501 Microwave Oven
Everything works but no heating?
With inside light and turntable on, louder sound, and no heat, this is usually a shorted high voltage rectifier diode or a bad magnetron.
Here are some links you or someone you know can use for test help, but read their safety warnings first:
Aug 14, 2008 | Jenn-Air JMV8196 Microwave Oven
Heard a loud glass breaking noise, now micro-wave will not heat anything. Turntable works, everything looks fine but no heating. Model#R-1505LK
Does it seems to run louder?
I would suspect a shorted high voltage rectifier diode.
We have the full service manual and have uploaded it to our site here.
Please feel free to contact me directly if you need more help.
We're happy to help and we appreciate your thoughtful rating of our answer.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
May 19, 2008 | Sharp Microwave Ovens
Maytag MMV1153A Microwave Oven Logo
37 people viewed this question
Top Maytag Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Maytag Microwave Oven Expert? Answer questions, earn points and help others
