Question about Tomtom GO 300 GPS Receiver
My tomtom300 it not coming on,not even with car battery,please can u help please,its not swithing on.
  • patandsandra Sep 06, 2008
    my tomtom doesnt go on when starting car engine,it does go off when car is turned off.
  • neofitos Sep 14, 2008
    My tom-tom300 is not working not even when i try to reset it.Can any look at it and tell me that is blown or sent me to a shop so an engineer can tell me the problem.Thank you.
    Novelist:
  • 158 Answers
Try resetting the tomtom by inserting a small pin through the reset hole. look underneath. if it still won't come on then it's most likely 2 IC's are blown inside .... U24 and U25 .
Posted on Sep 13, 2008
  • Ken Roberts
    Ken Roberts Sep 15, 2008
    Take a look inside your tomtom go . The photo's uploaded are of the GO and Go 300 / 500 series so yours might not look exactly the same but will be similar to these. SEE PHOTO of the IC's highlighted RED. U24 is on the same side of the circuit board as the card reader. U25 is on the same side of the board as the power socket. These are the 2 chips / IC's that will be blown if reversed supply or more than about 6 volts has been applied. The blown components are usually blown due to attaching the WRONG charger or a faulty charger. ( the tomtom cigarette lighter leads often go faulty ) These IC's are very very small ( just 3.5mm across ) and the 10 pins ( 5 on each side ) are even smaller and very close together therefore normal soldering ability will not allow a novice to replace them. Special soldering irons are needed , magnifying glass or special microscope for electronics + a steady hand and good light. Its highly unlikely that a home repair is possible. Besides that , even engineers with years of soldering experience have great difficulty replacing these components and it often takes me 30 minutes just to replace one of these IC's and I have a steady hand. Most normal electronics repair companys cannot repair this type of component as they will normally deal with bigger things. So unfortunatly, your "corner of the street" TV repair shop won't be able to fix it for ya either. As far as I know TomTom don't repair these IC's either as its too fiddly and time consuming and for them not worth the effort. Your only hope is one of the repair people offering this service on online . Try a look on ebay under "faulty tomtom" .
I want info on a isuzu 1996 mod for alternator wiring on alternator
I looked at info for rodeo 2.6L engine. You didn't state the model or engine size. Isuzu is the make. The battery and sense at the generator. You can see the splice for the two solid hot wires.
Jul 17, 2017 | Isuzu Cars & Trucks
Audio window comes on and off on its own
problem with moniter front panel MENU swithes.Replace all the swithes on the front panel.
If one swith is problem, automatically on or off will happen on its own.
This solution wil be the same even if brightness or contrast control will vary on its own!
Dec 10, 2010 | HP W19b LCD Monitor
I have a 1997 jeep grand cherokee laredo 4.0 that will not start, it wont even crank at all!! This jeep is becoming a real pain in the ****. It has been driven every day and has driven normal like always...
Okay, headlights are nice and bright and battery is still fully charged, if theres no dash lights and doesnt start and you have replaced the ignition swith, this switch is the elctrical switch not the key part correct, then the onlt other thing i can think off that ive run into on these wranglers is a wiring harness that supplies power to ignition system, this wiring comes throught the firewall into cab at the center area of the dash there it has a connector that connects it together, the wires heat up and melt in the connector this is a main power wire in this harness that melts, this harness contains about 4 to 7 wires,hold the key in the crank postion and start moving wire harnesses around under the dash, you will need to look closely ther are not that many harness under that dash, it will be in the center and toward driverside. hope this helps.
Sep 13, 2010 | 1997 Jeep Wrangler
Starter wont crank new battery lights come on bright not even a clicking noise
not sure year you have but, the ignition swith under the dash usually dies on these.
Mar 13, 2010 | Ford Contour Cars & Trucks
Couldn't Turn off my 96 Grand Marquis
Seems your ignition swith has come disconected from the key switch. The actual swith is not the key. The key links to a switch on top of the steering column down around the pedals. Or the switch itself is broken free. The switch is replaceable although a pain to access. No need to pull out the steering column. Good luck.
Jun 02, 2009 | 1996 Mercury Grand Marquis
How do I charge the TomTom XL 330
Hi There!
You Can charge your Tomtom when you drive, or you can charge it with a USB port on your computer.
I don't think they come with a mains charger anymore?
Toby
Dec 26, 2008 | Tomtom XL 330 Car GPS Receiver
Compaq Presario 700 Series Laptop wont turn on
Please first make sure that your adaptor is working.
Try to remove the battery and connect your laptop to the adaptor. Swith on. If nothing chages, then there is good chance that you have a motherboard related problem.
Nov 23, 2008 | Compaq Presario 700 470024-192 Notebook
Tomtom300 gps mains charging +
1= My battery is flat, but when i put it on charge in the house it doesnt charge and no green light comes on, on my sat nav why would this be?
Could be your house charger is bad or the power connector on the back of the Tomtom is bad.
2= But when i put it in car charge it works perfect 'Y'?
You are using the "power shoe" to charge the battery. For a test unplug the power cord from the power shoe and hook it to the back of the Tomtom. If this work then the house charger is bad. If this doesn't work then the Tomtom rear power connector is bad
3= If ever i have to change battery how is this done?
You will have to remove the faceplate and disassemble the Tomtom in order to get to the battery. Or you can find a shop that repairs small electronic. Find the battery on Ebay.
Jan 12, 2008 | Tomtom GO 300 GPS Receiver
Tomtom GO 300 GPS Receiver Logo
249 people viewed this question
Top Tomtom GPS Experts
Martin Murray
Will Halftowaite
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
