Aficio 3235 toner being dumped
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 1,362 Answers
Depends on where and how it is dumping toner??/
but it comes from two sources
a)drum: which has the waste toner drive system, it may be full or not working properly
b) developper : bad toner/ developper- mag roller or seals going bad-
Posted on Sep 05, 2008
The ir 3235 is displaying E000280 - 003 i want to know the cause of this fault
ricoh aficio 2105 error code 32836 the scanner is not working please help soon
Sep 06, 2011 | Ricoh Aficio 2015 Copier
How to clear toner collection bottle sign for Ricoh_Aficio_SPC232DN
replace the waste toner bottle (toner collection bottle)
Or dump the waste toner from it and clean it thourghly.
Mar 10, 2011 | Ricoh Aficio SP C232DN Laser Printer
How to replace waste toner bottle for Ricoh Aficio w3600
1. Lift the original feed unit.
2. Lift the upper unit.
3. Right upper cover
4. Right cover [
5. Loosen the leaf spring and lift it.
6. Toner overflow sensor
7. Toner collection bottle
Once you have it out jsut dump it out (carefully) remove the sensor on the bottle and wipe clean reinstall the sensor re install the bottle and you should be good to go
Jan 21, 2010 | Ricoh CL3000E Laser Printer
I need to empty or repalce the used toner bottle
Hello sir; You may open side door, you will find out a retangle plastic box that is the waste toner bottle, on the top of waste toner bottle have a green knob, just slide it to right, you can remved it and dump it out.
May 18, 2009 | Ricoh Aficio CL3500N Laser Printer
USED TONER CASE IS NEARLY FULL
Hello sir; There have no waste tone bottle for this machine, but waste toner all stuck in the imaging transfer belt unit, on the right hand side door,pull it out dump the toner out and vaccumn it.
May 06, 2009 | Ricoh Aficio 450 Copier
Used Toner Bottle Full Ricoh Aficio 1035P
The used toner is stored in the Transfer Belt assembly on the right door that you open to remove a jam. Remove one spring on each side and release the catch while gently lifting up on the belt and roller assembly. It swings 90 degrees up from the rest of the assembly. There are 6 screws that hold a cover on the lower assembly. remove it and dump the waste toner. *** VERY MESSY*** have a vac on hand. Not a shop vac unless you want toner clouds floating around the office. If the six screws aren't present, dump the toner out of the **** between the mylar-rubber blade and the lower assembly. once this is done, the message will clear.
Apr 08, 2009 | Ricoh Office Equipment & Supplies
How to Solve Error code SC496 for Aficio 551
hello Sir; You have to empty the waste toner bottle it located right hand side bottom, open the doorlook at "A" area you will see a big narrow plastic bottle pull out a black buckle slide out the bottle, dump the toner,the code will be disappear!
Jan 06, 2009 | Ricoh Aficio 450 Copier
Waste toner
open the front cover , the transfer belt runs diagonally from top left to right. towards the left below this transfer unit is a waste oil bottle, pivot this to the left and behind it is the waste tonet bottle. You dont need a new one you can just empty the old one and reinstall it. be careful dumping the toner it is actually lighter than air. Hope this helps.
Oct 15, 2008 | Ricoh Aficio CL7000 Laser Printer
Afico 3235
SC Waste toner full
Empty the waste toner, it shoukd go away. Look on the right rear side there should be a door, inside should be a big white plastic container 3/4 full of toner.
Sep 05, 2008 | Office Equipment & Supplies
71 people viewed this question
jasbo
jasbo
