Laptop won't shut down. It goes through the motions, I press start, shutdown, shut down and it tells me windows is shutting down, screen goes black, then it reboots and wont turn off. I have to pull the plug out (if wired) or remove battery.
    Master:
  • 505 Answers
Hold down the power button for 10 seconds
Posted on Sep 05, 2008
Computer does not shutdown
You have programs running that aren't shutting down, you can choose the force shutdown option to solve your problem.
Jul 27, 2014 | Computers & Internet
Hp P6653 won't shut down properly after clicking shutdown
Open Control Panel, select Power Options, select High Performance, Use this procedure to set the Advanced power settings: http://www.makeuseof.com/tag/windows-7-power-options-sleep-modes-explained/ Use these tip to speedup starts and shut downs: http://www.techrepublic.com/blog/10things/10-ways-to-speed-up-windows-7/3332 Try Freeware MALWAREBYTES at : http://www.filehippo.com/download_malwarebytes_anti_malware/ In the install UNCHECK the TRIAL PRO version, you want the freeware version, Run a FULL scan, delete ALL results, reboot.
Mar 09, 2013 | HEWLETT-PACKARD Pavilion p6653w...
When I goto shut down the computer it goes through the motions but then it restarts and goes back into windows. In order to shut it down I have to go through and when it starts to boot I have press the...
Try this, go to control panel, select Power Options, make sure the section that says "When I press the power button" it says shut down the computer.
You may also want to check in the BIOS where it says what do you want to do when you press the power button, you want both to say to shut off the PC.
I hope this helps.
Good Luck and have a pleasent day.
May 24, 2011 | E-Machines etower 466is PC Desktop
Screen goes black when turned down and it does
try removing suspend on lid close .. refer to your laptop manual .. try this too disable herbernation also ..if nothing works check if you have latest graphic driver !! it might be a problem with ACPI .. but my two solutions should work !!!
Mar 10, 2010 | ASUS W7S-3P100E T7500 PC Desktop
My Gateway 700X PC (Windows XP) will not Shutdown/Will not Start.
Best to format and reinstall a fresh copy of your operation system.
Regards
Feb 24, 2010 | Gateway 700 X PC Desktop
I just bought a sony VIAIO today and dont knoiw hoiw to shut it down
1. Normal shutdown: select Start - Shut Down - Shut Down
2. System hangs: select Alt-Ctrl-Del and then Shutdown
3. If #2 doesn't work - hold the power button until the screen is dark
Hope this helps.
Aug 17, 2009 | Sony VIAO P4 PCV-RS712 3.0GHz 512MB 200GB...
Laptop not goes shutdown
get a program called tweakui and tell it to shut down you computer faster.
Apr 21, 2009 | Computers & Internet
Wont shutdown when shutdown butten is pressed shuts windows well i have to cut off power to shutdown.
Go to Start > Run and type services.msc. Locate the nVidia Driver Helper item and right click it. Select Properties. Set the startup value of the service to “Manual” or “Disabled”.
Your computer should shut down normally now.
Apr 18, 2009 | Computers & Internet
Computer won't shut down or restart
chak the ram or fan of prossor
Nov 12, 2008 | Computers & Internet
I am 56 years old computers are not my generation. just got a new computer. and am trying to close it but it would not close . what I did is close the the monitor. and then pressed the button off of the...
You have to click the Start button and choose "Shut Down " and click the mouse on that. If that does not work, try pressing Ctrl + Alt+ delete simultaneously. What they call the task manager will come up. choose Shut down and click on it. It should shut down
Nov 08, 2008 | Acer Computers & Internet
Computers & Internet Logo
177 people viewed this question
Brian Sullivan
Brian Sullivan
joecoolvette
joecoolvette
