Question about Sport & Outdoor - Others
Yamaha vino 50 cc scooter
My scooter will not start either by electronic ignition or by kick start. I charged the battery and now the turn signals work, etc but scooter will not start. Should I check spark plug. The horn works, the signal lights work but when I push the electric ignition, not even a sound.
  • 8 more comments
  • trungcphan Nov 23, 2008
    I have the same problem. What was the solution?
  • Anonymous Jan 19, 2009
    I also have a 2006 vespa and it was working fine during the summer and
    fall but I did not use it in December. January I tried to start it just
    to get it started and let it run for a while. When I tried to use the
    push button start it would start making noise but never turn over, the
    same with the kick start. I believe that something may be wrong with
    the fuel pump or something with the fuel line since everything lights
    up and I know the battery is fine. The nearest vespa dealer/mechanic is
    almost 2 hours away so getting it to a mechanic that will know what to
    do is very hard. If you get a different answer let me know I am going to try and get a manual and fix it but if that is not the problem then I will be waising my time
  • italiaroma Jan 19, 2009
    do is very hard. If you get a different answer let me know so I can try that first
  • Anonymous Mar 02, 2009
    I have the same porblem but I haven't tried kick starting it. I'm going to get a full tune up and i'll let you guys know.
  • mjc25 Mar 19, 2009
    My 06 Genuine Buddy is doing the same thing. Has anyone found a solution? Please advise. I'm not finding a lot of information on this anywhere else online.
  • Anonymous Apr 25, 2009
    i have the same problem! i changed the spark plugs and recharged the battery. it won't start by kick starting it or by the electric switch. the lights come on but it won't turn over.
  • Anonymous May 04, 2009
    I have a 1989 yamaha zuma - -same problem. turnsignals and brake lights work, but not will not electric start.
  • jesse
    jesse Apr 16, 2014
    I have the same problem. too What was the solution?
  • jesse
    jesse Apr 16, 2014
    I have the same problem TOO . What was the problem WITH IT
  • dezrtstar
    dezrtstar Jun 27, 2014
    I have a 2004 vino classic i have the same problem
    New Friend:
  • 41 Answers
Hello, check to see if it is a switch (pull hand brake back when starting
Posted on Nov 25, 2008
  • Donnie Allen Jul 14, 2012
    I have tried this, did not work, It does not work even when I try to kick start. When I try this all I here is an occasional click. Any answers or solutions?
  • r lot Oct 04, 2013
    You MUST pull in left brake handle when trying to start. Have you done this?
2007 Yamaha Vino 50 not charging
If the problem is in the battery you better change it.You may find OEM or less expensive variant - replacement battery - this is the correct replacement Yamaha 50CC XC50 Vino Classic 2006 2012 Motorcycle Battery 12V 4 5Ah . Here are some helpful videos about how to access and replace the battery (the place of the battery depends on the scooter's model).
Oct 15, 2017 | 2007 Yamaha Vino Classic
Why does my 2005 Yamaha Vino Classic 50 Died at stoplight and wont start now.
Hi, Rose and the usual suspects are:
1. Severely discharged or a damaged battery, should have 12.5 volts or better and be able to pass a load test if necessary.
2. Failed alternator/generator and or voltage regulator.
3. Loose or corroded battery terminals and or cables especially the "NEGATIVE" cable, look for loose, corroded, or broken connectors inside the cable harness at "BOTH" ends.
4. Failed main circuit breaker or ignition switch, check for loose connections and continuity.
5. Failed system and or ignition relay, check for continuity.
6. Failed ignition coil, ignition/electronic module.
7. Failed CKP, CPS, CMP, MAP, TPS, or BAS sensor, corroded, loose or broken wire connector pins/sockets.
8. Throttle cables and or idle speed improperly adjusted hot idle speed should be 950 RPM to 1000 RPM.
9. Air/fuel mixture screw improperly adjusted.
10. Accelerator pump damaged or not working.
11. Water or dirt in the fuel system, carburetor or filter.
12. Restricted, blocked or kinked fuel line.
13. Fuel tank empty.
14. The gas cap is not venting properly or fuel tank venting system blocked.
15. A failed fuel pump, pressure regulator and or fuel injectors.
16. Vacuum line from intake manifold to petcock broken, cracked, or not attached, carburetor vent line plugged.
17. Needle and seat stuck closed in the float bowl.
For more information about your issue and valuable "FREE" downloads that you need please click on the links below. Good luck and have a nice day.
Scooter Questions Get Answers to Your Scooter Starting Question
2004 Yamaha Vino 50cc won start Help Please
http://www.49ccscoot.com/manuals/Yamaha_BWS_Zuma_50_2T_Service_Manual.pdf
OEM parts for Yamaha
http://www.yamaha-motor.com/assets/service/manuals/2007/lit-11626-20-36_vino_1551.pdf
Jul 04, 2014 | 2005 Yamaha Vino Classic
Why would a 2005 Yamaha Vino Classic 50 engine die at stoplight and wont start
Hi, Anonymous and the usual suspects are:
Tips Tricks
Yamaha vino125 will kick start but electric start doesn't work. when you turn key on lights do not come on. battery is good
1. Ignition Switch not in the "ON" position.
2. Engine Run Switch in the "OFF" position.
3. Discharged battery, needs to be 12.5 volts or better and be able to pass a load test if necessary.
4. Check the battery terminals for damage or corrosion check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
5. Tip over sensor needs a reset.
6. Faulty ignition switch.
7. Faulty starter button.
8. Faulty kickstand or clutch pull in switch/sensor.
9. Starter control circuit, relay, or solenoid faulty.
10. Main fuse or circuit breaker may be blown or faulty.
11. Check for engine trouble codes.
For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have nice a day.
2006 08 Yamaha Vino 125cc Won start Seat Latch Scooter Doc Forum
Scooter won start
Yamaha XC125 Service Manual
Yamaha Cygnus XC125 Owner Manual
Sep 23, 2013 | 2005 Yamaha Vino 125
How do i install a new battery in a benelli pepe scooter?
Hi Anonymous, I am sorry you can't find the first and best tool you ever bought for your Benelli but despair not for a mere $0 you can download another one. For more information about your issue, please visit the websites below. Good luck and have a nice day.
How to charge scooter battery Yamaha Vino 125 Battery Tender Jr Guide How To Install Your Battery On Your Moped scooter madness motorbike...
How to Fill and install new battery in GY6 Moped
here your service manual for free
Benelli Pepe 50 2011 service manual DOWNLOAD FREE FULLMANUALS COM
Dec 22, 2012 | 2011 Benelli Pepe 50
2006 Yamaha Vino 125 scooter turns but doesn't start
1. Fuel tank empty.
2. Fuel supply valve/petcock turned off.
3. Fouled spark plugs.
4. Engine flooded as a result of overuse of the enricher.
5. Vacuum hose to the fuel supply valve/petcock disconnected, broken, cracked, or pinched.
6. Fuel valve/petcock or filter clogged.
7. Fuel line to the carburetor or throttle body pinched or kinked.
8. Carburetor float stuck.
9. Fuel injectors clogged.
10. Severely discharged or damaged battery you need 12.5 volts or better and be able to pass a load test if necessary.
11. Check battery terminals for damage or corrosion, check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
12. Loose or corroded wire connection at the coil, battery or plug between ignition sensor and CDI box.
Spark plug cables in bad condition and shorting check for leakage in the dark, cable connections loose, or connected to the wrong cylinders.
13. Ignition timing incorrect due to a faulty MAP, CKP, O2, TPS, sensors.
14. Faulty neutral, clutch lever, or kickstand safety switch.
15. Faulty fuel pump or fuse or relay.
16. Faulty CDI box.
17. A stuck bent or burnt valve.
18. Tip over sensor needs a reset.
19. Check for engine trouble codes.
For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
Scooter Troubleshooting Scooter won start All about Scooters
Scooter won start
Yamaha YJ125S Service Manual
Yamaha VINO 125 Owner Manual
Oct 03, 2012 | 2006 Yamaha Vino 125
On a Yamaha Why Scooter how do I open up seat with a flat battery
Hi, Ian for this scenario you will need your service/owners manual if you can't find the first and best tool you ever bought for your Yamaha, despair not, for a mere zero $ you can download another one. For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
How to access the battery and main fuse on Yamaha Vino Scooter
How to charge scooter battery Yamaha Vino 125 Battery Tender Jr HD
Yamaha XC50V Service Manual
Yamaha XC50W Owner Manual
Jun 05, 2012 | 2007 Yamaha Why
What type of coolant mix is needed for an 06' 50cc Vino? It has been sitting and is not starting. The coolant is low. Could that be the problem. The battery is new and I just changed the oil. The...
Hi, Pharismj and the usual suspects are:
Aug 11, 2011 | 2006 Yamaha Vino Classic
Yamaha 50 vino - starting problem
If it sat for a year without Sta-bil in the gas it is probably gummed up and you will have to remove the carb and clean the gunk out of the inside of it and check out all the passageways to make sure they are clean and open
Aug 16, 2009 | kawasaki Full Suspension Mountain Bike Men
Sport & Outdoor - Others Logo
3,783 people viewed this question
Top Sport & Outdoor - Others Experts
Bill Eager
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
