Question about JVC RX-D201 Receiver
Not getting digital sound from dbs or dvd
I have the appropriate cables connected (optical for my motorola dvr box, and the digital coax for my dvd player). I have the dvr connected to the dbs in on my receiver with component cables. I have my dvd player connected to the dvr/dvd in on my receiver with component cables as well. When i first hooked everything up, i was getting the digital sound, but no video. I am now able to get the video after i switched what inputs were coming in on the appropriate channels, but I can not get the digital sound signal. Is this automatically picked up by the receiver when something if connected? Like i said, when it was first hooked up my display said digital for the sound on the receiver, but then i had to struggle with getting the video to show. What can i try in order to get this to work? Thanks in advance for any help someone might be able to give me.
    Champion:
  • 277 Answers
Try all the possibilitys of connecting cables between the outputs & inputs exept the ones that r allready working maybe theres a wrong connection inside the reciver windman
Posted on Jan 31, 2006
SOURCE:
How to Connect VCR directly to the TV without problemd
The VCR is today old technology that doesn't marry well with the latest tv sets and accessories. The best way is to connect via a scart lead.
There have been so few digital vcr's produced few households have them - most are analogue format and must either record from a set-top box, from some tv sets while watching the programme, from a dvd or dvr or anything with a scart socket...
Mostly the in-built uhf modulator is redundant and generally the machines are now only suitable for playback of previously recorded tapes, though I still find them useful for recording.
Jul 23, 2016 | Televison & Video
Problem with video signals through AVR-4800
Pic of product.
Owners manual
I'll be back after I study it, if problem persisit
Check monitor 1 settings in the on screen display on tv for me
Cheers
S.
Jan 13, 2008 | Denon AVR-4800 Receiver
I have a SA 8300HD cable box connected to Yamaha RX-V2500 receiver using Digital Audio Out from cable box to DVR/VCR2 on the receiver. It had been working for 2 years. Then this past weekend it stopped...
Pretty good problem description.
Make sure the DVR/VCR2 digital input is assigned to the Cable box.
When the DVR/VCR2 input is selected do you get any front panel indicators on the Yamaha that indicate a good digital bitstream?
Try swapping the cable box output to the working DVD In connection to isolate it to either the source or the receiver's ability to decode it.
Check the audio output settings for the Cable Box, too. Sometimes their outputs are adjustable. It may be muted or set too low.
Mar 31, 2010 | Audio Players & Recorders
Problems with optical input. I am having intermittent problems with the optical sound input on my Onkyo. I am using a DVR with optical output for the source. Sometimes when I turn the DVR and Onkyo on I...
sometimes with cable, satellite, or any dvr, the digital signal actually is intermittent and there is little we can do about it but add an analog audio connection for each device as a backup. per se, and put the receiver in auto input mode. the receiver will utilize the analog signal to fill in where the digital signal fails
good luck
Dec 07, 2009 | Onkyo TX-DS747
Sony DG510 - Not Getting surround sound out of Cable
Did you try it on BOTH the SAT and Video 2 optical ports? Still not working? Could be the Optical cable is bad.
Does your Cable Box also have a coaxial digital ouput? It looks just like a standard RCA connector but says Digital somewhere near it. Try one conductor of a standard audio cable from it to the "DVD" coax connector. Select DVD to hear it.
If it still doesn't work jump into the Cable Box setup to make sure it's output is set up properly.
I would recommend using the coaxial digital option if you have it.
1) The cable isn't special or expensive like the optical cable is; a garden-variety RCA cable works just fine.
2) You have virtually unlimited distance to work with in the house.
3) You don't have to be so darned careful with it as with optical.
Mar 06, 2009 | Sony STR-DG510 Receiver
TV has no picture but has sound
Did you say you went in to DVR set-up and checked the component out audio option? I have had similiar problems with motorola dvr boxes and once I was able to enable audio output option the dvr digital output was fine. Find the manual for the model dvd and this may cure.
Jan 31, 2009 | Denon Audio Players & Recorders
Set up
The specs I am reading online are saying that it has digital coax connection. If your hooking up hd cable or hd satellite box some of those have a digital coax output on them. If your hd cable/satellite box only has optical out the system you have says it comes with a optical to coax converter which is pretty cool. So you should definately be able to hook up that sound system to your cable/sat box digitally for best sound. The only other way would be to run stereo red,white cables from your cable/sat box to your stereo as a last resort.
I’m happy to help further over the phone at https://www.6ya.com/expert/brandon_60dfebff379d64bd
Nov 09, 2008 | Philips LX3950W System
Connecting new tv to DRA-685
you can use the headphone jack just get an adaptor to change from the headphone type to RCA type. adjust the volume of the tv to 3/4 of the way to give line level to the stereo, use an aux input on the stereo. if you had a suround sound dolby digital / DTS receiver then use the digital coax out to that type of receiver, but since you have an anolog 2 channel receiver you must use the only anolog source (the headphone).
May 21, 2008 | Denon DRA-685 Receiver
Need diagram to connect Motorola DVR, Panasonic DMR-E recorder, A/V Receiver, and HDTV
Your not going to be able to connect in series (not sure if thats your goal) since your limited by the type of connections you can use. Your receiver is going to have to be switched depeneding on what source you want to listen too. DVR, DVD, etc. HDMI is going to important for your TV connection. Radio Shack has cheap HDMI cables.
So... connect HDMI from DVR to HDTV this will give you sound and picture to TV. Connect DVR optical or coaxial ( RCA if you dont care about surround) to Receiver to give you DVR sound thru Receiver input.
Connect DVD to receiver via optical/coaxial/rca for DVD sound thru receiver (again RCA is not recommended for surround).
Connect Component video to HDTV(or HDMI if TV has second HDMI input) to give you video from DVD.
Connect Yellow video or S-video from DVR to DVD recorder input to allow recording from DVR. Also connect red/white audio to (same) DVD input.
That should cover it.
Apr 09, 2008 | Arris DCT2608
Getting no audio to game systems, pc connect won't connect
I also had the same problem when using my optical output for DBS and DIGITAL DVR/DVD.. you need to change the setting for this by on the remote changing to either analouge..rca sound input or Digital...for Optical input. The same problem cuaght me oput for a long time as well. The button is when you slide down the remote cover and the button is called analoug /digital
Dec 30, 2007 | JVC RX-D301S Receiver
JVC RX-D201 Receiver Logo
161 people viewed this question
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
stynger007
Level 1 Expert
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
