Question about Xerox Office Equipment & Supplies
Change the default settings on document centre 535
    President:
  • 2,072 Answers
You can press, its either login or access, then enter 1111 or 11111 depending which of the 2 passwords is set.
That will allow you to adjust or reset about anything on the machine.
Posted on Sep 05, 2008
Message centre number
The message centre number should not be set manually
Unless you have changed the correct settings
You can fix this problem by :
restoring your mobile settings to its factory default settings
Nov 01, 2013 | Samsung C3050 Cell Phone
Document centre 535
Are you trying to reset the fuser or the whole machine to factory defaults? Or other?
Jan 18, 2013 | Xerox Office Equipment & Supplies
I cannot figure out how to set the calculator to "degree" mode in order to use sin, cos, and tan. Help please!
In Scratchpad, how do I change the default angle settings from radians to degrees?
By default, your handheld's angle settings are in radian mode. If you want the default angle setting to be changed to degrees, please follow these steps:
  • Using a TI-Nspire Family Handheld with Touchpad, press [doc]. Using a TI-Nspire Family Handheld with Clickpad, press [ctrl] [home] while in an open Document or in Scratchpad. Both procedures will take you to the next screen, and the procedures can also be used on any TI-Nspire Family of Desktop Software.
  • Press the [7] key to select the option for 7: Settings and Status c27070ss1.jpg
  • Press the [2] key to choose the option 2: Settings c27070ss2.jpg
  • Press the [1] key to choose 1: General or press the [2] key for 2: Graphs and Geometry, depending upon which default angle settings you are looking to change. c27070ss3.jpg
  • Press [tab] key once to select Angle, next press the [down] on the touchpad or clickpad and select Degree from the list and press [Enter]
  • Press [enter] on "Make Default". When the handheld asks if you want to save the new settings as default for new documents and Scratchpad, press [enter] to accept the changes. c27070ss5.jpg
Choosing "Make Default" will save the settings as your default settings for both scratchpad, and any new documents you create after that point.
Please rate my post!
Cheers,
Sine Wave
Dec 08, 2010 | Texas Instruments TI-Nspire Graphic...
I have a zte r100 and can't restore default settings. It's asking me for handset lock code, which should be default 0000, but is indicating incorrect password. I want to restore default settings because...
Menu > Settings > tab right to Handset > Restore Default Settings ... The default. Handset Lock Code is 0000 (unless you changed it). .... If you can't change the message service centre number maybe you can ask for a swap ...
Jul 14, 2010 | Lands Phones
Internal DRS error when scanning
When you go to do the scan using the "HP Solutions Centre" "Scan Document" button (press this now).
Click on the "Change Settings" button (lower right side of scan window) in the window that opens. This opens the "Scan Document Button" window. Make sure the "Show a preview scan." box is ticked (In Button settings bottom right of window.
Click on the "Advanced Document Settings..." button (Right Hand side 2nd under "Scan Type)
Change the "Output Resolution (ppi) for Document as Image:" to 200. While here, check the correct language is selected. I also tried an Output Resolution of 600ppi. This seemed to make no difference as the system defaults back to 300ppi when the scan is carried out, regardless of what has been selected, but still scans as expected instead of erroring. For some reason I have yet to discover, simply changing the ppi removes the erroring!!
While here (in the "Advanced Document Settings..."), now would be a good time to change the scan to "Black & White" which in itself reduced my scan from 24.5MB to 1MB The only thing you'll need to do then is, after the scan, adjust the "Black and White" level manually for clearest picture. I got the best results this way. If you forget to select this at this point, don't worry, it can be done from the next window (HP Scanning)
Now click the "OK" button. This takes you back to the "Scanning from... Scan Document button (HP Solution Centre) window. Now click on the "Scan" button (in the "Scanning from...Scan Document Button (HP Solution Centre)" window.
Now you'll be in the "HP Scanning" window which is where you can make any final changes you deem neccessary. You can also see how big your file is and how each change makes a difference to the size of your file. Note that this is not the storage size. It is the size of the "working in ram" file.
When the document is the way you want it, then select finish. This time, it should go through to the final program as expected. Don't expect every character to be correctly recognised, especially with any hand written documents. Tables are especially notoriusly bad.
Hope this helps. Good luck and I'll let you know if I find anything else to help.
When it works, it works well. In the mean time......
May 28, 2010 | HP Officejet J5780 All-In-One InkJet...
Oil for 1995 virago 535
Hi, Anonymous for this scenario you will need your service/owners manual if you can't find the first and best tool you ever bought for your Yamaha, despair not, for a mere $0 you can download another one. For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
http://www.halfords.com/wcsstore/libraries/document/motorcycleoils.pdf
1995 Yamaha Virago oil change Part 1
Yamaha XV 535 DX Virago Service Manual
OEM parts for Yamaha
http://www.starmotorcycles.com/assets/service/manuals/2005/LIT-11626-18-21_1000.pdf
May 20, 2010 | 1996 Yamaha XV 535 Virago DX
Fuji xerox document centre C250
Press machine log in button, enter 11111 confirm, this will take you to sys admin mode, from here you can navigate into sys settings to configure network,copy and fax defaults, and also auditron admin if this is the password mentioned, if the 11111 password has been changed hold the zero button for a few seconds then press start while still holding zero enter 6789 to get into diagnostics, and you can navigate through to the above settings caution be careful what you change in this mode.
Aug 02, 2008 | Xerox WorkCentre M123 Copier
Word Document problem
Dear subhasish, you would like to check in your page border settings. Go to formatting and then border, you must've selected border by default on settings. Change it to none. It must be applied to whole document too.
Just change the default settings and you'd be able to print without it :)
please press fixya if that has helped you.
Nov 30, 2007 | Computers & Internet
180 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
