Question about Zenith XBV443 DVD Player/VCR
TURN OFF PROGRESSINE SCAN ON ZENITH XBV443
I need to know how to turn off the progressive scan. I turned it on trying to correct the static that I got while trying to play an animated dvd.
  • smileyobrien Dec 25, 2007
    the progressive scan text appears across the screen when set on DVD and will not show the menu when I press the menu button so I can't change the progressive scan menu to no. So what should I do?
    Novelist:
    Champion:
  • 277 Answers
Cause: DVD+VCR was turned off while setting the Progressive scan mode. Correction: Keep pressing the STOP button for more than 5 seconds.
Posted on Oct 19, 2005
Since you can't get to the setup menu, the "keep pressing stop" worked fine. You need to stop the dvd first and see stop on the display. Then hold it down for more than 5 seconds. thanks!
Posted on Feb 19, 2008
Thank you this solution worked great! Pressing the power button for 5 sec. is what worked for me.
Actually, I have the solution. Press and hold the stop button on the dvd side, (left side), for 10 to 20 seconds.
Posted on Feb 27, 2008
If that doesn't work, try removing the DVD and holding down the stop button for 6-8 seconds.
Posted on Aug 31, 2008
Worked for me as well. Thanks
Posted on Jul 24, 2008
    Problem Solver:
  • 16 Answers
Press SETUP. The Setup menu appears. Select option (use arrows) Press ENTER to confirm the 'NO' selection.
Posted on Jan 19, 2006
    Novelist:
    Champion:
  • 277 Answers
Press SETUP. The Setup menu appears. Select the 'PROGRESSIVE SCAN' option (use arrows) Press ENTER to confirm the 'NO' selection. Have fun!
Posted on Oct 17, 2005
Stuck on progressive scan
This is a common issue with this brand of player. While the unit is on, and without any discs inserted, press and hold STOP button on the front panel (not the remote) for 10 seconds, then release. This should turn the progressive scan function off and revert the video output of the player back to normal interlace.
Zenith, Samsung, Magnavox, and Goldstar DVD players are notorious for progressive scan headaches, but it's easy to correct.
Apr 16, 2011 | Zenith Televison & Video
DVD/VCR stuck in Progressive scan mode
Hi jjbitt.
I found this in another post. This is what another expert say
"With NO DISK in the DVD player PRESS PLAY, (display will say "no disk" or something similar) then PRESS STOP AND HOLD FOR 5-10 SECS.."
http://www.fixya.com/support/t123076-dvd_vcr_stuck_in_progressive_scan_mode
Let me know if you still have the problem
Jan 12, 2008 | Zenith XBV442 DVD Player/VCR
How do I exit progressive scan mode?
hold stop button down on remote for 5 to 10 seconds this resets progressive scan
Jan 10, 2011 | Zenith XBV443 DVD Player/VCR
DVD/VCR Combo - Zenith XBV342 Stuck In Progressive Scan
mi zenith xbv342 solo queda la pantalla azul y dice progressive scan mode como salgo de hay
Jun 14, 2009 | Zenith XBV442 DVD Player/VCR
Can't turn off progressive scan on my dvd/vcr player.
Page 18 of the operating manual cites this, to reset to default viewing mode:
1) Remove any disc from the unit and close the disc
tray. See that “dISC” is displayed on the display
window.
2) Press STOP and hold it for more then five
seconds before releasing it. The video output will be
restored to the standard setting and a picture will
once again be visible on a conventional analog TV or
monitor.
If that doesn't work, please let me know.
Mar 19, 2009 | Zenith XBV443 DVD Player/VCR
Hearing static while the dvd is playing how would i go about cleaning it
I have the Zenith XBV410 (combo dvd/vcr). I cleaned the lens using the Maxell Lens cleaner kit but nothing happened. Then I ran the Progressive Scan Mode and that seemed to do the trick. Word of caution: Progressive Scam Mode is difficult to turn off so would recommend you remove dvd from player, then press and hold the stop button for a min of 5 seconds up until whatever it takes to disablel PSM (Progressive Scan Mode)
Dec 27, 2008 | Zenith XBV443 DVD Player/VCR
Progressive scan mode will not go away.
Depending on the model or version, normally Progressive Scan Mode maybe enabled/disabled by:
  • PScan or PS button on the original remote or front control panel;
  • a slide switch at the rear.
Hope that this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Oct 24, 2008 | Zenith XBV443 DVD Player/VCR
With NO DISK in the DVD player PRESS PLAY, (display will say "no disk" or something similar) then PRESS STOP AND HOLD FOR 5-10 SECS. Our DVD was stuck on Progressive Scan Mode for over 1 year, this fixed it. I had tried the press stop, press stop and hold while playing a movie, but not while there was no disk. Try it & Good Luck!!!!!!!!
Nov 02, 2006 | Zenith XBV442 DVD Player/VCR
Turn off progressive scan mode
If you set progressive scant On by accident,you must reset the unit. Remove any disc from the unit and close the disc tray. See that "disc" is displayed on the display window. Now press STOP and hold it for more than 5 seconds before releasing it. The video output will be restored to the standard setting and picture will once again be visible on a conventional analog TV or monitor.
Sep 05, 2006 | Zenith XBV443 DVD Player/VCR
PROGRESSIVE SCAN STILL ON- BLUE SCREEN ONLY
Oct 17, 2005 | Zenith XBV443 DVD Player/VCR
Zenith XBV443 DVD Player/VCR Logo
502 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
