Question about Dell OptiPlex 170L PC Desktop
Hard drive I need to increase the GB what hard drive do i need is it IDE or SATA in my Dell Optiplex170L
  • Dell Master
  • 998 Answers
If you look at the hard drive inside your computer, there will be 2 cables plugged into it. If one of the cables is a flat cable about 2 inches wide, then its IDE interface type.
Your responses are intended to improve the level of service provided. Please rate your experience.
Thank You.
Posted on Oct 20, 2008
How can i to connect a hard drive sata with sata to ide adapter on biostar u8668d motherboard?
you will need to purchase a serial ata adaptor card for pci slot with support for sata 1/2/3 I believe. Try ebuyer.com
Mar 31, 2015 | Seagate Barracuda 7200.10 (ST3750640AS)...
Sata pata ide hard
A sata drive doesn't need jumpers. The jumpers were only required when 2 drives used the same cable.
Nov 28, 2013 | Dell Dimension 3000 PC Desktop
Turn into usb drive
USB 2.0 To SATA IDE 3.5 2.5 Hard Drive with an Adapter Cable http://www.youtube.com/watch?v=iE8t5IGr0e4
http://www.ebay.com.au/itm/USB-2-0-to-SATA-IDE-2-5-3-5-Hard-Drive-HDD-Adapter-/330612048804?pt=AU_Laptop_Accessories&hash=item4cfa0383a4
USB 2.0 to SATA IDE 2.5 3.5 Hard Drive HDD Adapter Kit
AU $8.09 free postage worldwide
You would have to remove the hard drive and use a usb sata ide kit
you will then have to connect it to your computer using a usb port
Aug 13, 2013 | Western Digital Caviar SE16 WD5000AAKB -...
HDD Upgrade
That model has standard IDE interface for hard drive. Don't think 500 GB or higher comes with that interface. The standard now is SATA interface for hard drives. Here is a lnk to the owner's manual for you model:
ftp://ftp.dell.com/Manuals/all-products/esuprt_desktop/esuprt_optiplex_desktop/optiplex-gx60_user%27s%20guide_en-us.pdf
You tell the difference between standard IDE and SATA in that the standard IDE interface uses a wide flat ribbon cable to connect to the drive. SATA uses a small thin cable as shon in the following link:
http://www.google.com/imgres?imgurl=http://www.cooldrives.com/lib/cooldrives/ultraflex-sata-cable-2.jpg&imgrefurl=http://www.cooldrives.com/24seatsaiiul.html&h=514&w=600&sz=35&tbnid=wGLj8F1otpnJYM:&tbnh=97&tbnw=113&prev=/search%3Fq%3Dwhat%2Bdoes%2Ba%2Bsata%2Bcable%2Blook%2Blike%26tbm%3Disch%26tbo%3Du&zoom=1&q=what+does+a+sata+cable+look+like&usg=__57zU4K_H2rpvq5AyZ41v_Ag4RTk=&docid=m3f9D21nEcMb3M&hl=en&sa=X&ei=NZQVUbrfDJD49gSd44CAAg&sqi=2&ved=0CFkQ9QEwBA&dur=81
Feb 07, 2013 | Dell Optiplex GX60 PC Desktop
Hi i bought WD 320 gb sata /8mb hard drive - the cable ribbon on my dell 4600 does not plug into it! do i need a different cable yes
Generally speaking, we have two types of hard disk interface. IDE (the old one with ribbon cable) and SATA (with a 1cm strip like cable).
As your new hard disk is SATA, you need a SATA cable to connect it to you PC.
Below are a few images which would help you.
Hope it helps! Good Luck! Thanks for using Fixya!
CreativeTECH
Sep 23, 2011 | Western Digital WD Caviar Blue WD3200AAJS...
I want buying the extension of lace hard drive 160 g between the adapter and the hard drive.
this will depend on HARD DRIVE whether ide the ide will have 40 pins or sata the sata will have 8 copper slat type also PSU power supply unit ide or sata power connecters these days they usually supply both next MOTHERBOARD if has ide and sata plugs the ide will be a flat ribbon type with 40 pin plug ends the sata will be 8 copper slat type usually a bit thicker
hope this helps
May 27, 2011 | LaCie Design by F. A. Porsche 160 GB Hard...
500gb hard disk supported by intel D101GGC
Hey ROY_GV,
This D101GGC Motherboard supports both IDE and SATA.
Regards,
InfDev
Mar 05, 2010 | Intel D101GGC Motherboard
Ilooked up the spec on my computer from dell (that
u need a SATA (serial ATA) drive, buy a SATA drive and its compatible with most of the computers today.
u can read about SATA drive by clicking this link i am giving:
http://en.wikipedia.org/wiki/Serial_ATA
plz do not forget to vote and click yes if i solved your problem,thank u! :)
Sep 05, 2009 | Hitachi TravelStar DK23FB (08K1427) 40 GB...
Hard drive installation
You should be able to install that drive. The biggest variable is if it is a SATA or PATA drive. This model was built for SATA drives, but I think you may be able to get a PATA drive to work with the right adapters.
For the step by stem directions see the link below. It will take you right to the Dell support page. Refer to the "Adding a Second Hard Drive" section.
https://support.dell.com/support/edocs/systems/dim5150/en/sm/parts1.htm#wp1366406
Feb 21, 2008 | Dell Dimension E510 Dual Core 2.8 Ghz...
Dell OptiPlex 170L PC Desktop Logo
97 people viewed this question
Alun Cox
