Question about HP LaserJet 4250dtn Printer
Hp laserjet 4250
Receiving an error on the control panel Processing duplex job do not grab until job completes. never processes. this only happens with letter size paper.
  • trojan160 May 08, 2009
    Tested the unit as described and it was ok, then it failed so changed DC controller and problem appear to be fixed but has now returned
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 87 Answers
This happens when the printer is printing duplex job. i.e. trying to print the other side of the page.
However check the functionality of the printer by performing Paper path test.
This would help us to know whether the printer as a stand alone ... is fine or not.
From the control panel of the printer, scroll to Diagnostic > paper path test.
Select the following in sequence.
Source: All trays
Copies: 10
Duplex: ON
Print Test Page
Check if you get the same error.
If yes, upgrade teh firmware of the printer.
Let me know the end result. We still have more depending on the above test.
- Nikhil
Posted on Nov 04, 2008
My 1300 hp printer still all lights on how to resolve problem
HP LaserJet 1150 and 1300 Series Printers - Understanding and Troubleshooting Control Panel Light Patterns This document explains how to interpret the light patterns on the HP LaserJet 1150 or 1300 series printer control panel. It lists the error conditions, describes the possible causes, and provides steps to resolve the conditions. Description of the control panel The control panel contains two lights and one lighted button. Patterns of light indicate printer status.Figure 1: Location of control panel c00007297.jpg 1 - Ready light 2 - Go button and light 3 - Attention light Figure 2: Light conditions c00007298.jpg 1 - Light off 2 - Light on 3 - Light blinking The following table explains the lights on the control panel. See "Status light patterns " below for an explanation of the light patterns.Light or button Description Ready light Indicates that the printer is ready to print. Go button and light To print a demo page or to continue printing while in manual feed mode, press and release the GO button. Attention light Indicates that a printer media input tray is empty, a print cartridge door is open, a print cartridge is missing, or other errors. Status light patterns This section describes the meaning of the light patterns. If a problem persists, see the flyer that came in the printer box for contact information, or click here to go to "Contacting HP support" below . Ready Light pattern c00007299.jpg Description The printer is ready to print. Action No action is necessary. To print a demo page, press and release the GO button on the control panel. Processing Light pattern c00007300.jpg Description The printer is receiving or processing data. Action Wait for the job to print. Continuable error Light pattern c00007301.jpg Description The printer is in manual feed mode. OR The printer is out of memory. Action The software controls manual feed. If manual feed mode is not wanted, change the setting from the printer properties. See the User Guide for information about changing printer properties. OR Take one of the following actions:
  • The page being printed might be too complex for the printer memory capacity. To continue printing, press and release the GO button. The printer might print a partial page, or the quality might be lower than normal.
  • Lower the resolution. See the User Guide for information about understanding print quality settings and changing print quality settings.
  • Add more memory. See the User Guide for information about installing DIMMs (HP LaserJet 1300 series only).
If the problem persists: Attention state Light pattern c00007302.jpg Description The printer is in an error state that requires operator intervention or help. The door is open, the media is out, the printer cartridge is installed incorrectly, or the media is jammed. Action
  1. Check that the printer cartridge door is completely closed.
  2. Load media into the correct input tray.
  3. Check that the print cartridge is correctly installed in the printer. (See the user guide for information about changing the print cartridge.)
  4. Check for any media jams and clear them. (See the user guide for information about clearing jams.
  5. Check that the left side panel is completely closed. If the left side panel is completely closed, open the left side panel and push the door sensor. Occassionally, if the left side panel appears closed, the sensor will still remain in the open position, generating this error. Pushing the sensor will shut the door tight, returning the printer to the normal mode.
Mar 19, 2013 | Office Equipment & Supplies
Tip
HP LaserJet LJ 4350 locks up when duplexing
Symptom: Your LaserJet 4350 prints just fine until you try to print a double-sided page. Then you see the page start to exit, pull back in, then stop. The Data light continues flashing green, and the display reads, "Processing..." There is no error indication, but the machine won't print the second side and continues to hold the half-printed paper in the duplexer. If you open the top cover and close it again, the printer will eject the page, then try to print the whole thing again, unless you're quick enough to cancel the job first.
Cause: The printer is expecting a different sized paper than what it's running. Often it's not the menu settings, but a little lever in the paper tray itself. Pull out the paper tray you're trying to print from and look for a little blue lever on top of its right-hand side. The lever is labeled "Standard/Custom." Flip it to Standard (parallel to the tray side) and your problem should go away.
on Mar 17, 2010 | HP LaserJet 4350dtn Printer
Printing is always blair and i cant view what is printer
Here is a full story
HP LaserJet Professional M1130/M1210 MFP - Interpret control-panel light patterns (M1130 Series only) Interpret control-panel light patterns (M1130 Series only) If the product requires attention, an error code appears on the control-panel display. Status-light legend c01993382.gif Symbol for "light off" c01993383.gif Symbol for "light on" c01993381.gif Symbol for "light blinking" Control-panel light patterns Light status Error code State of the product Action All lights are off.
c01993373.gif The product is turned off. Press the power button to turn on the product. Ready and attention lights blink.
c01993380.gif The status lights cycle during the formatter initialization period or when the product is processing a cleaning page. No action is required. Wait for the initialization period to end. The product should enter the ready state when the initialization period is finished. Ready light is on.
c01993421.gif The product is in the ready state. No action is required. The product is ready to receive a print job. Ready light is blinking.
c01993420.gif The product is receiving or processing data. No action is required. The product is receiving or processing a print job. Ready light is blinking slowly.
c01993420.gif The product is in low power mode. No action is required. Attention light is blinking.
c01993418.gif E0 Paper is jammed in the product. Clear the jam. E1 The input tray is empty. Load the tray. E2 A door is open Verify that the print-cartridge door is fully closed. E4 The product memory is full The job is too complex for the product to print. Simplify the job, or divide it into multiple files. E5 The product did not pick up paper from the tray. You might need to clean or replace the pickup roller. H0 The product is in manual-feed mode. Load the correct paper type and size into the input tray. H1 The product is processing a manual duplex job. Load the pages into the input tray to print the second sides. The attention and toner lights are blinking.
c01993375.gif E3 The print cartridge is missing or is not installed correctly. Install the print cartridge. The toner light is on.
c01993429.gif The print cartridge has reached the end of its estimated useful life. When the supply has reached this condition, the HP Premium Protection warranty for that supply has ended. You do not need to replace the print cartridge at this time unless print quality is no longer acceptable. Attention light is blinking, and ready light is on.
c01993379.gif The product has experienced a continual error from which it will recover on its own. If the recovery is successful, the product continues to the processing data state and completes the job.
If the recovery is unsuccessful, the product continues to the continuable error state. Try removing any media from the media path and turning the product power off, and then on again. The attention and ready lights are on.
c01993388.gif E6
E7
E8
E9 The product has experienced a fatal error from which it cannot recover.
  1. Turn off the product or disconnect the power cord from the product.
  2. Wait 30 seconds, and then turn on the product or reconnect the power cord to the product.
  3. Wait for the product to initialize.
If the error persists, contact HP customer support
Mar 01, 2013 | HP LASERJET PRO M1132 MFP
Need to perfrom nvram init on HP 4250
To initialize NVRAM, turn the printer power off. Remove any installed accessories (for example, a stapler/stacker). Turn the printer power on, and then hold down (SELECT button) when the memory count begins. Continue holding down until all three printer control-panel lights flash once and then remain on. This might take up to 10 seconds. Press (UP ARROW button). Press the PAUSE/RESUME button (LJ 4200/4300) or the MENU button (LJ 4250/4350). The display should show SKIP DISK LOAD. Press (UP ARROW button) until NVRAM INIT is highlighted. Press (SELECT button) the printer initializes NVRAM and then continues its power-on sequence.
Nov 07, 2012 | HP Laserjet 4250dn Network Laser Printer...
HP LaserJet 4250 PCL 6 - Cannot get Duplex disabled
Try turning Duplex off at the printer. See if that does what you want.
Jun 23, 2010 | HP LaserJet 4250dtn Printer
LaserJet 4350 Printer: HP 4350 printer, 49.2F9D service error...
1st thing to do is upgrade the firmware. Go to hp.com and look for the software and drivers. Drill down to the firmware and read the instructions.
May 16, 2010 | HP LaserJet 4350 Printer
Solid orange light and blinking green lights
To check the light Pattern of your printer
Click on Light and Error HP Laser jet 1012 Printer
Check the error details from the above link
Condition of the printer Action/Description Ready
The printer is ready to print. No action is necessary. Processing
The printer is receiving or processing data. Wait for the job to print. Processing...(job name) Ready LED is blinking.
This message is displayed while the printer is processing a current job, but has not begun to pick pages. Processing...(job name) From Tray XX Ready LED is blinking.
This message comes up for any job, once the printer starts to pick paper. Manual Feed or Continuable Error
The printer is attempting to Manual feed, media is not loaded in the paper tray, media loaded is the wrong size or type. Verify that the correct media is loaded.
Press and release the GO button to continue printing. Out of memory
The printer is out of memory. The page you are printing might be too complex for the printers memory capacity. Try lowering the resolution. See Understanding print quality settings for more information. Door open, media out, no print cartridge, or media jam
The printer is in an error state that requires operator intervention or help. Check the following:
  • The print cartridge door is completely closed.
  • Media is loaded.
  • The print cartridge is correctly installed in the printer.
  • There is no media jam.
Printer initialization
A printer initialization is taking place. No action is necessary. Fatal error
All lights are on.
  • Unplug the printer for 30 minutes, and then plug it back in.
  • If the printer still has an error, contact HP Support.
All lights are off.
  • Verify that the printer is turned on.
  • Make sure that there is power.
  • Unplug both ends of the power cord, and plug them back in.
Job Cancel
All the LEDs cycle. Canceling...(job name)
The Job Cancel button was pressed and the job is aborted. Power ON
All the LEDs cycle. Checking Paper Path and Checking Printer
This only occurs at power up. Cleaning mode/Engine test
A cleaning page or engine test page is printing.
All the LEDs cycle. Cleaning Page prints
Wait until the cleaning page is finished printing and the printer is in Ready mode. This could take up to two minutes.
Wait until the engine test page is finished printing and the printer is in Ready mode. Clearing Event Log
All the LEDs cycle.
This will happen automatically during an NVRAM Init and a cold reset. No message will be displayed. No Action is Necessary. Power On
Initializing
This occurs when the product is powered on and coming out of EDOS. No Action is Necessary.
Jan 03, 2010 | HP LaserJet 1012 Printer
HP LaserJet 1220: all lights are on
Hi
The complete list of the light patterns, causes and what should you do, are there on this link
http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?lang=en&cc=us&taskId=110&prodSeriesId=29789&prodTypeId=18972&prodSeriesId=29789&objectID=bpl10633
it looks like this
Type of error Light pattern Recommended action No power - The printer is not connected to a power supply. c00031238.jpg Plug the printer into a power supply.
If the printer lights do not turn on, contact HP. Ready - The printer is ready to print. c00031239.jpg No action is necessary.
To print a configuration/self-test page, press and release the GObutton on the printer control panel. Processing - The printer is receiving or processing data. c00031240.jpg Wait for the job to print.
Oct 20, 2009 | HP LaserJet 1220 Printer
My green light is blinking and will not print
blinking green light -> Processing Data The printer is processing or receiving data - > To cancel the current job, press the CANCEL button
Oct 01, 2009 | HP LaserJet 1320 Printer
Trouble with duplex printing
I think your problem is that the 5550 supports manual duplex printing. Print every other page then feed them through again. Never tried it though. Dave Reed
May 23, 2008 | HP LaserJet 5550 Printer
HP LaserJet 4250dtn Printer Logo
1,000 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
