Question about AT&T 1738 Digital Answering Machine
Number of rings before recording answers
How do I change the number of rings before it answers?
  • Anonymous Mar 14, 2014
    change number of rings before answering
    Problem Solver:
  • 13 Answers
Choose how many times the line will
RINGS IS...” ring before the system answers a call.
• Set for 2 to 7 rings, or choose
Toll Saver 2/4 or Toll Saver 4/6.
• When set to Toll Saver 2/4, the system
answers after four rings when you have
no new messages and after two rings
when you do. Toll Saver 4/6 causes the
system to answer after six rings when
you have no new messages and after
four rings when you do.
• During setup, the Message Window will
display the number of rings (8 for Toll
Saver 2/4, or 9 for Toll Saver 4/6).
Posted on Nov 01, 2008
2 Suggested Answers
pgh_pa_guy
  • 2992 Answers
SOURCE: How do you set the number of rings before the answering machine picks up?
Here's a link to the manual on AT&T's site:
http://telephones.att.com/telephones_ui/support/dsp_manual.cfm?manualID=284
Posted on Nov 19, 2008
Re phone BT6500, how does one increase the number of rings before it goes to answerphone?
Hi
I give below the step by step procedure for changing the number of rings the phone will sound.
1. Select Menu, Answer Phone is displayed, press
Select.
2. Press until Settings is displayed, press Select.
3. Press to highlight either Ans. & record or
Answer only and press Select.
4. Answer delay is displayed, use or to display
the number of rings you want (0-9 rings or Time
saver) and select Save. Saved will be displayed.
Be aware though that the number of rings needs to be less than your ansaphone service, for BT 1571 this is 5 rings, although more may be possible if you can get BT to change their 1571 for your line.
For more information about your phone you can download a pdf format manual from here:
https://www.shop.bt.com/content/uni2/documentation/8h3j/bt6500_user_guide.pdf
This can be saved to hard disk for future reference.
Hope this is helpful, if so would you please register that with Fixya
Cheers
Dec 11, 2014 | Honeywell DOLPHIN 6500:5300SR IMGR/28KY...
Panasonic number ring
Answering system settings
Number of rings before the unit answers a call.You can change the number of times the phone rings "Ring count"before the unit answers calls. You can select 2 to 7 rings, or "Toll saver".The default setting is "4 rings"."Toll saver": The unit's answering system answers at the end of the 2nd ring when new messages have been recorded, or at the end of the 5th ring when there are no new messages. If you call your phone from outside to listen to new messages (page 34), you know that there are no new messages when the phone rings for the 3rd time. You can then hang up without being charged for the call.
Jan 16, 2014 | Lands Phones
I can not locate how to limit the number of rings; and the answering machine does not come on even after 20 rings; I can hear my message recording- when I play it back; but it does not come on for incoming...
Ring count You can change the number of times the phone rings before the unit answers calls. The default setting is "4 rings". "Toll saver": The unit answers on the 2nd ring when new messages have been recorded, and on the 4th ring when there are no new messages. If you call your phone from outside to listen to new messages, you will know that there are no new messages when the phone rings for the 3rd time. You can then hang up without being charged for the call.
1 {MENU} 2 {V}/{^}: "Answering device" i {OK} 3 {V}/{^}: "Settings" i {OK} 4 {V}/{^}: "Ring count" i {OK} 5 {V}/{^}: Select the desired setting. 6 {OK} i {OFF}
MANUAL http://service.us.panasonic.com/OPERMANPDF/KXTG1032.pdf
HOPE IT HELPS GILES102
Jun 27, 2011 | Panasonic KX-TG1033S Cordless Phone
THE ANSWERING SYSTEM WON'T RECORD MESSAGES,ALL MESSAGES GOES INTO POOVIDERS VOICE MAILE, AS IF MY PHONE IS BUSSEY?????? I CHECKED AND RECORD TIME IS NOT SET TO ANNOUNCE ONLY ANS ALL MESSAGES HAVE BEEN...
This happens when the number of rings to answer of the provider voicemail is less than the number of rings to answer that the answer machine is set for. For example: if your provider voicemail rings to answer is set for 3 rings and the answer machine is set for 4 rings then the voicemail answers before the 4th ring, therefore the answer machine will never get a message. I would call the service provider's customer service number and request they increase the rings to answer above the number of rings to answer that the answer machine is set for. If you don't want voicemail to answer any calls(when your line is busy or when the answer machine is turned off) ask your service provider to disable voicemail.
Mar 30, 2011 | Uniden Cordless Phone
HP L7650 will not auto answer incoming faxes
To set the answer mode to manual or automatic via the control panel
? Press Auto Answer to turn the light on or off, as appropriate for your setup.
When the Auto Answer light is on, the device answers calls automatically. When
the light is off, the it does not answer calls.
To set the answer mode to manual or automatic via the embedded Web server
1. Open the embedded Web server, click the Settings tab, click Fax in the left pane,
and then click the Basic sub-tab.
2. Select On or Off in the Auto Answer drop-down menu in the Other Basic Fax
Settings section.
Set the number of rings before answering
If you turn on the Auto Answer setting, you can specify how many rings occur before
incoming calls are automatically answered.
The Rings to Answer setting is important if you have an answering machine on the
same phone line as the device, because you want the answering machine to answer
the phone before the device does. The number of rings to answer for the device
should be greater than the number of rings to answer for the answering machine.
For example, set your answering machine to a low number of rings and the device to
answer in the maximum number of rings. (The maximum number of rings varies by
country/region.) In this setup, the answering machine answers the call and the device
monitors the line. If the device detects fax tones, it receives the fax. If the call is a
voice call, the answering machine records the incoming message.
To set the number of rings before answering via the control panel
1. Press Setup.
2. Press Basic Fax Setup, and then press Rings to Answer.
3. Enter the appropriate number of rings by using the keypad, or press the left or right
arrow button to change the number of rings.
4. Press OK to accept the setting.
To set the number of rings before answering via the embedded Web server
2. Select a number in the Rings-to-answer drop-down menu in the Other Basic Fax
Settings
section.
Dec 02, 2010 | HP Officejet Pro L7650 Printer
To many rings for the machine to pick up
Unfortunately this machine does not have the facility to change the number of rings before it answers. The following extract from the manual describes how the number of rings is controlled:
Toll Saver Facility
Your unit has a Toll Saver Facility. This means your unit will answer call on the 4th rings if there are no new messages, or on the 2nd ring if new messages have been record. Therefore when you are calling your unit remotely you will know by the 3rd ring if there are no new messages. So you can hang up saving the cost of the call.
You can download the manual from here:
http://www.memorexelectronics.com/manuals/mph-1089.pdf
Apr 19, 2010 | Memorex MPH1089 Digital Answering Machine
How do I change the number of rings before the answering machine kicks in on a Casio machine?
Some of the older models have a slide switch on the side or bottom of the machine that could change from 1 to 3 rings. If you have a set up menu for greetings the number of rings to choose may be there when you go to record your announcement. Do you have the Model number?
Aug 20, 2008 | Lands Phones
Hangs up after 2 seconds into recording message
SETTING THE RINGS TO ANSWER
This setting allows you to select the number of rings before the answering system answers a call.
At idle status, hold down the volume "UP" button over two seconds to enter the ring times setting of answering. The answering system announces, "ring time two" (the default is 2).
To change the rings to answer, press and release the "PREVIOUS" button (<<) or the "NEXT" button (>>) and the answering system announces a number such as "2, 1, toll save, 9...” OR "2, 3, 4...", if you select the toll save and the digit LED light shows a “γ”, the answering system announces “toll save”.
After choosing a number, press the “PLAY/STOP” button one time to store the rings to answer, and the answering system confirms the setting and returns to the idle status.
NOTE: when the machine fails to operate properly, just unplug the power for 10 seconds, and redo the settings.
Aug 03, 2008 | Emerson Em1200 Answering Machine
How can I change the Rings to Answer setting to one ring?
1.
Press Setup.
Get manual at http://h10032.www1.hp.com/ctg/Manual/c00863866.pdf
Jul 07, 2008 | HP Officejet Pro L7680 All-In-One Printer
NUMBER OF RINGS TO ANSWER FAX
same phone line as the HP All-in-One, because you want the answering machine to
answer the phone before the HP All-in-One does. The number of rings to answer for
the HP All-in-One should be greater than the number of rings to answer for the
answering machine.
For example, set your answering machine to a low number of rings and the HP All-in-
One to answer in the maximum number of rings. (The maximum number of rings
varies by country/region.) In this setup, the answering machine will answer the call
and the HP All-in-One will monitor the line. If the HP All-in-One detects fax tones, the
HP All-in-One will receive the fax. If the call is a voice call, the answering machine will
record the incoming message.
To set the number of rings before answering from the control panel
1. Press Setup.
2. Press 4, and then press 2.
This selects Basic Fax Setup and then selects Rings to Answer.
3. Enter the appropriate number of rings by using the keypad, or press or to
May 14, 2008 | HP Officejet 4315v All-In-One InkJet...
AT&T 1738 Digital Answering Machine Logo
1,179 people viewed this question
Top AT&T Lands Phones Experts
Paul C.
Are you an AT&T Lands Phone Expert? Answer questions, earn points and help others
