Question about Briel Domus Due Espresso Machine & Coffee Maker
Briel Versatile Due Coffee Machine
Hi
Do you know of anywhere I can get a new handle (coffee holder/filter/handle) for the Briel Due machine please? alternative just the filters for same
Thanks
You can get it at the Briel service/distribution center at:
Electra-Craft
41 Woodbine St
Bergenfield NJ 07621
phone 201-439-1700
fax 201-439-1701
info@electra-craft.com
www.electra-craft.com
Posted on Sep 22, 2008
EXPRESSO MACHINE BRIEL ARTIMIS ES42F
i solved it by taking it all apart, then putting it back together, whoo hey it works
Aug 04, 2009 | Briel Artemis ES42 Espresso Machine
Where can i buy a filter holder for my briel chamonix coffee maker
Hello millerli,
I have found success finding unusual filters by going to Amazon and trying in the brand of coffee maker and filter you are trying to find. There you will likely find a number of sellers. Good luck. Hope this is helpful to you. NormanZ
Jul 08, 2009 | Briel Chamonix Espresso Machine
Brew head leaks at gasket,causing some water to bypass the coffee and leak around outside of brew head
The filter holder not pushed far enough ino lock position, also the basket doesn't quite hold 2 level spoons of coffee.
Thanks, David
Jun 18, 2009 | Briel Chamonix ES-35 Espresso Machine
Cleaning oils from briel domus
Yes, every pump driven machine has an over pressure discharge.
Jun 18, 2009 | Briel Domus Due Espresso Machine & Coffee...
Manual Briel ES161atb
Don't know about replacement parts but instruction manual can be downloaded from the website in PDF file.
Jun 13, 2009 | Briel Domus Due Espresso Machine & Coffee...
Spares for Briel Coffee Machine
You can obtain any part at:
Electra-Craft
41 Woodbine St
phone 201-439-1700
fax 201-439-1701
Nov 12, 2008 | Briel Domus Due Espresso Machine & Coffee...
Need to find replacement parts for Briel Chamonix
HI,
You can order any Briel part you need at:
Electra-Craft
41 Woodbine St
phone 201-439-1700
thank you.
May 05, 2008 | Briel Chamonix ES-35 Espresso Machine
Leaks From Filter Gasket
Sounds like you might have coffee oil build up. I would suggest soaking the Brew Head Screen and filter holder in a coffee oil remover by www.urnex.com or dezcal. Remove the screw if your filter basket has one. For home use it would be good to clean this every week or so. You can email me for more info: irene@smithagy.net. You also might just try purchasing a new filter basket (along with cleaning the Brew head screen and new basket).
Further technical info can be found at:
Electra-Craft
41 Woodbine St
phone 201-439-1700
fax 201-439-1701
Dec 20, 2007 | Briel Domus Due Espresso Machine & Coffee...
Espresso Machine
Possibly, if it is leaking from the bottom only, and if you have a Domus Due model, you might just need a new water reservoir as the water reservoirs are a different system than all of the other briel machines and a new reservoir will usually fix the problem of leaking on the bottom in the Domus Due machines. Something with the seal on the reservoir.
You can order just a water reservoir by contacting the service center at:
Electra-Craft
41 Woodbine St
ph 201-439-1700
If your machine is leaking over the filter handle, brew head etc, that could be the coffee oils have built up in the Brew Head Screen and/or filter basket itself. For that, remove the Brew Head Screen and soak along with the Filter Basket in a coffee oil remover (not descaler) you can get the Cafiza powder at www.urnex.com or any other brand and then use a brush to clean it after soaking. If you have the Briel filter basket with a screw in the middle, please remove the screw and clean in there as it tends to get clogged. Then just be sure not to screw it too tight again as this can cause leaking.
I hope the info was helpful.
Apr 16, 2007 | Briel Domus Due Espresso Machine & Coffee...
Briel Domus Due Espresso Machine & Coffee Maker Logo
355 people viewed this question
Top Briel Coffee Makers & Espresso Machines Experts
Dan Webster
Dan Webster
Henry  Thomas
Henry Thomas
Are you a Briel Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
