Bose RC-25 Remote control
How can one identify whether the fault is on the remote control or the HiFi system since the remote control is not Infra Red. Will appreciate your help.
Many thanks.
Regards,
Hasnain Molu
SOURCE: bose p1 touchscreen remote
press and hold the mute key for about 5 seconds until you hear a beep, then wait about ten seconds
Posted on Aug 14, 2007
PaulTulsa
  • 14 Answers
SOURCE: matsui 4in1 remote control instructions
1) Turn on TV;
2) Press TV on the remote control;
3) Press and hold SETUP, until the red LED indicator blinks twice;
4) Enter 9-9-1-1 on the numeric keypad;
5) Press POWER on the remote;
6) If the TV doesn't respond, repeat #3, #4, #5.
Posted on Feb 17, 2008
SOURCE: My bose 321 system remote control sometime works and sometime doesn't.
I had a similiar problem with the Bose Remote for Lifestyle 3. The Remote Just didnt work ,other than on/off.I had to stand infront of the system to make it work. Solution:- "Turn Off" all the electronic equipment near your bose system or connected to your bose ( TV, Hifi, Iphone , wifi ,xbox, Wii etc ) and then just "TURN ON" the Bose alone and try the remote...it should work fine. Then start each device one at a time followed by testing the bose remote the same time. I found out that once i "Turned On" the TV the Bose Remote failed to work. The TV was inteferring with the remote as both of them work on around 40Hz...Try it ...it just might solve your problem
cheers Boss
Posted on Sep 01, 2009
SOURCE: Code for sky + remote to operate bose cinemate volume via the sky remote ?
1356 something like that ;)
Posted on Sep 25, 2009
rodseesqi
SOURCE: Harmony 900 to control Bose Lifestyle problem.
Press the system button on the Lifestyle remote control. Move right to see a preview of the remote control. Press the down button to move into the submenus. Go down to IR Control. Select "on" System receives IR commands from another remote that has been taught to operate this system. Press exit and take a breath and try your Harmony remote. It should work. I had the same problem and this fixed it after hours of screwing around. Good Luck
Posted on Dec 23, 2009
Purchased 1 year ago and was working fine then this week no longer working. Changed batteries in remote but still not working ie does not turn on.
Check the remote control for its infra-red emission. Check it with fresh batteries. Check by pressing all the buttons on it; and see whether all of it generates infrared signal while pressing. If it is found OK, check and replace the infrared sensor inside the TV. If you wish to get some details; check the site linked here. It has details about how to check a remote control; by one among the post. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ If the remote control is found OK; check and replace the infra-red sensor inside the TV. Contact any service technician.
Mar 13, 2015 | Bose Solo TV sound system - Black
How to check my bose rc-9 remote whether its working or not?
Put batteries in it and point it at the electronics unit and press some buttons
Dec 27, 2014 | Bose New Original RC9 Remote Control
Where is the Bose 25 infrared sensor on the
hellllllo..........RC 25 is not infrared red its radio frequency.........tkx......g.scott
Jun 05, 2014 | Bose RC-25A Remote Control for Lifestyle...
Program bose remote control rc 25
Hi Francis Jeremy Nicholas,
looks like your volume up key is stuck on your remote.
You have two choices. One is to open it yourself and clean the surface the button sits, or if its on warranty you can call them
Mar 02, 2014 | Televison & Video
Remote rc25 not working
Check its infrared emission first. As it is new, the only possibility is with the failure of infrared LED inside it. If you wish to get more details about how to check a remote control, check this link, and pull up older posts there.
Feb 24, 2013 | Bose RC-18S Remote Control
Bose remote RC-25 won't work anymore
Check the remote control for its infrared emission. Check it with fresh batteries. Check it battery contacts, inside its battery compartment for any rust or dust accumulated, which prevents the electrical contacts. If all are found OK, you remote control need cleaning. To clean it, you have to open it. If you wish to know more details about how to clean and check a remote control, check this link.
Feb 17, 2013 | Bose RC-25A Remote Control for Lifestyle...
Remote wont operate sound dock.
hi , To check wether the remote is outputting a infra red signal when a button is pressed try viewing the little LED at the top of the remote through your mobile phones camera , these little cameras pick up a fuller spectrum of light and you should see if flickering. IF you dont then check the batterys/. then the connectors for acid errosion from previous leaking batterys./pull the remote apart and with a pencil rubber clean the contacts on the surface of the circuit board/.The rubber membrain that has the buttons on wash it with warm soapy water , dry thouroughly.last test --go to mapplins and buy a replacement infra red led and change that? , see haow you go whith these tips and report back
Mar 20, 2009 | Bose RC-18S Remote Control
Code to control my Viewsat9000HD on Bose remote not working at all
Have you tried changing the codes in the system setting?
Sep 02, 2008 | Bose RC-18S Remote Control
When we try to use the remote the red light glows which I never saw glowing when it was working properly.What could be the problem?
Jan 03, 2008 | Bose RC-18S Remote Control
Televison & Video Logo
1,073 people viewed this question
Top Televison & Video Experts
