Question about Lucent PARTNER18 Corded Phone
Dial code features for setting up extions buttons.
Recently an existing (preassigned) extension button is not working.
The extension button does not ring into the assigned extension, also
the extension button does not indicate that the extension is in use.
How can I fix this?
Please advise
  • Lucent Master
  • 2,460 Answers
Look around for a little red book about 4x6 inches. It has all of the feature access codes for a partner phone.
Feature buttons for intercom are programmed by FEAT 00
Press button to program
Press Intercom and dial ext
End by pressing FEAT 00
Posted on Sep 05, 2008
How to program feature buttons on meridian 7310?
Go to 7310 set you wish yo program leave handset on hook push feature star 3 then the button you wish to program then feature and
the code you want ex:feature 0 is speed dial that key will now be
programmed for speed dial. You cant program line keys or intercom keys.
Sep 02, 2014 | NorStar Meridian M7310 Phone
How to program speed dials on DTU-16D-2
If the button is programmed as a feature button, then Feature, Redial, press the button to program, dial 1 for typical feature, dial extension you want on it, press Feature to write and exit. If the button isn't assigned for features, this won't work until someone goes into system programming and does that.
Nov 22, 2013 | NEC Electra Elite DTU 16D-2 Corded Phone
Feature Button Not Working
Feature, Redial, press button to program, dial 1, dial the extension number, Feature to write and exit. ONLY IF the buttons are programmed as feature buttons, they may be just dead buttons, useless until they are assigned in system programming as feature buttons.
Nov 22, 2013 | NEC Lands Phones
How do i reprogram my speeddial numbers on jazz 4400?
From NorStar Support:
To Program Personal Speed Dial Numbers: (Numbers 71 - 94 only.
1. Press the Feature button, then * 4
2. Enter the 2 digit code (71 - 94). that you want to assign to that phone number
3. Enter the telephone number, then press the OK softkey
4. Display will show: "Entry xx stored"
If the above doesn't work, try:
  1. Press [Feature] [*] [4]
  2. Enter a two-digit code from 71 to 94.
  3. Specify the external line by pressing a line button, a line pool button, or the intercom button. If you don't specify the external line, the system automatically chooses a line for the call.
  4. Dial the telephone number you want to program (up to 24 digits).
  5. Press [Hold].
  6. Record the code and number you have just programmed.
Hope this helps.
Feb 02, 2011 | NorStar Jazz Plus 4400 Corded Phone
How do i forward my office calls to my cell phone
Go into programming, set #322, and your extension to have permissions for forwarding.
Then, set your cell number as a speed dial at your extension. Feature 00, then feature 80 and enter the number as you would dial it from your extension.
then press a button with lights, and press feature 11xx80. where xx is your extensoin number.
When done, press feature 00 to get out of programming.
To activate, press the button you programmed the forwarding on., then the green light will come on. To un forward, press the button again.
Sep 03, 2010 | Avaya Corded Phone avaparp18d
Program a new Nortel m7310 phone with an existing extension
If the extension was a swap of the old M7310 with a new(ish) M7310 no additional programming should be necessary. However if the phone was replaced with another type of nortel set(M7208, M7324,T7313 etc.) then the phone will default to its base features. To re-program the feature keys press feature *3, the button you wish to program, and the feature code for that button
Sep 28, 2009 | NorStar M7310 Corded Phone
To Program Buttons On Your Phone:
For External Numbers:
1. Press the Feature button, then * 1
2. Push the button you want to program
3. Display will read "Program and OK"
4. Enter the telephone number, then press the OK softkeyFor Internal Numbers (Extensions.:
1. Press the Feature button, then * 2
3. Display will read "Intercom #:__"
4. Enter the extension number
For Feature Codes:
1. Press the Feature button, then * 3
3. Press the Feature button then enter the Feature Code
Aug 12, 2009 | NorStar M7310 Corded Phone
Panasonic KX-T7730- assigning speed dialing/one touch. I tried to press prog button and the one touch button..but it gives me an error message "not stored". How to solve this? I have 12 buttons to assign...
It says "Not Stored" because you haven't stored anything in it. There are 12 buttons on the left side with lights and 12 buttons for feature dialing on the right. If you want to monitor extensions, the buttons on the left are the ones to use. If you want to store speed dial numbers and feature codes use the ones on the right.
Left button programming. Press PROGRAM and the button. For extensions, dial 1+ext and STORE. For CO's, press 0+line number, for inside codes press 2+code, for outside number press 2+9+number, all followed by STORE.
Right button programming. For inside codes dial the code, for outside number press 9+number followed by STORE.
Note that you could also dial "8x" or "80x" in place of "9" for specific line access. Also, you can store extension speed dial numbers on the right, you just won't get a light indication when they're busy.
Jun 04, 2009 | Panasonic KX-T7730 Corded Phone
I can't get the voicemail button to work
You are describing two different things. The "speaker 43" is the default code for Busy/No Anser Set. The correct syntax should be Speaker - 43 - 399 - Speaker. That should set CFWD B/NA to VM. Next, if you have a button programmed to call VM, it is probably a speed-dial or one-touch button. It would have to be programmed to dial 399. If that is not working, try calling VM (399) and make sure you can get into the box that way. If that works, but the button does not, press the Feature Key and the button for VM. It should display what is programmed for that button. If it needs to be changed to call VM, the syntax is: Feature - Redial - the button to program - "1" - "399" - Feature.
Feb 07, 2008 | NEC DTU 8D-2 Corded Phone
Programming the DSS/BLF
Need to login in system and program buttons from there.
Nov 07, 2007 | Inter-Tel Axxess Phone 5504400
Lucent PARTNER18 Corded Phone Logo
165 people viewed this question
Top Lucent Lands Phones Experts
Paul C.
Computer Repairing
Computer Repairing
Michael Galve
Michael Galve
Are you a Lucent Lands Phone Expert? Answer questions, earn points and help others
