Question about Hoover Washing Machines
I have a top loader hoover 800EL,cold and hot water is coming very slow , I am suspecting the solinoid valves is it easy to replace them ?
    Genius:
  • 1,122 Answers
When you put it on warm does it do the same thing?see if you can hear the solinoids ,they sould not be loud if they are they are bad,is your water presure ok?the valve is easy to replace it has to leads and alittle feed hose,just remove from back of water,(2 screws and replace)mike
Posted on Sep 05, 2008
My Hoover Galaxy is not filling up,only the Hot water tap works.
sounds like the cold water intake valve has failed and will need replaced
its solinoid coil is prob open circuit
Dec 14, 2014 | Hoover Washing Machines
Problem with my Whirlpool Calypso top-loader: when I push Start, no water comes into the machine. This is a sudden problem - it worked fine a few days ago. I verified the water is coming out of the hoses...
I would normally suggest a water control valve malfunction but you are experiencing NO water at all and I would doubt both valves would fail at the same time. So we need to diagnose further. Put it direct onto a (cold) rinse and see if water goes in then. If it does then it's the hot water control valve which needs replacing and a Service call ;-0(
If there still is no water going in at all I would suspect the control PCB which needs replacing or a wiring problem - and a Service call ;-0(;-0(
Good luck,
John C
Mar 06, 2011 | Whirlpool Calypso GVW9959K Top Load Washer
Cold water won't flow fast. Hot water only is fine warm water is slow and cold water almost nothing. Cleaned filter etc Thank you
Hello there and thank you for choosing fixya
The best way is to explain this is like this the washing machines water inlet valve has a solinoid for the hot and a solinoid for the cold and when one of these start to fail the will slowly close untill the solinoid will no longer allow the valve to open so this is why your water pressure is getting low going into the machine for the cold side ok?
So what you are going to have to do is to replace the faulty water valve solinoid.
I would really suggest to replace the valve as a whole it ensures that you have a new part.ok?
Hope this helps if yo need any further dissassembly help let me know and i can assist you if needed
Best regards Mike..
Mar 01, 2011 | Washing Machines
Hot water filling is slow
If you swap the hot and cold water supply and the hot wash has low cold water pressure then suspect the water inlet valve. Unplug the unit and turn off the water to disconnect the water hoses. Pull out the washer and remove the back of the unit by the water hose inlet. The new valve is on connectors, which makes it an easy fix. The valve could cost $18.00 to $60.00 depending on the model.
Feb 23, 2011 | Kenmore Washing Machines
The cold water inlet is slow to fill machine but the hot water inlet works fine
Hi just read your posting.Could you please supply the model of your hoover and tell me if it is a front or top loader.The fault on your machine is due to a faulty cold water valve or dirty inlet filter.Turn the cold tap off and remove the cold water hose from the tap end and check to see if the little filter at the end of the hose is blocked.If it is, clean it and put back the hose to the tap and try a wash cycle.Please reply with additional information and to tell me how you got on with the filter.
Jun 29, 2010 | Washing Machines
Hot water will not enter machine. Screen filter is clean. Cold is OK.
There's no hot water Some washing machines allow hot water to enter only during certain cycles. Others intermittently allow hot and cold to enter, to temper the temperature of the water. Consult your owner's manual if you are unsure about whether the machine is acting abnormally. If you're sure the machine isn't working the way it used to--or should--try these tests: Is the hot water turned on? If not, turn it on. Is the washer getting cold water but no hot water? If so, check to see if the control panel settings are correct. Is there hot water coming through the proper hose? If not, check to see if the screen inside the water-inlet valve is clean. (The water-inlet valve is the device on the washing machine that the fill hoses are attached to.) If it's clean, you probably have a defective water-inlet valve. If so, completely replace it.
Feb 04, 2010 | GE WDSR2080D Top Load Washer
Kenmore front loader washing machine very long wash cycle
You need to replace your cold water, inlet valve.
Unplug the machine from the power source. Disconnect cold water hose. remove the top cover of the machine. You will see the cold inlet valve/solenoide where the hose fits.
Take note of where the wiring goes. You can get the part from your appliance parts outlet.
Refit, and you should be right to go.
Good Luck.
Ash
Oct 22, 2009 | Kenmore Washing Machines
WASHER WON`T FILL FULLY WITHOUT RE OPENING TOPLID SEVERAL TIMES?
water valve should be a single unit consisting of a hot and cold solinoid assembly. This whole valve assembly should be replaced.
Jul 20, 2008 | Washing Machines
Roper washer: Slow fill on hot setting
You can really thank the government for this- your washer has a 75/25 split valve (75 cold 25 hot--- so warm is mostly cold) which they mandated for all standard top load machines. In 2010 they are banning manufacting of all standard top loaders. The thermistor is because your machine has a ATC (automatic temperature control) system. It has a computer which monitors water temp for better laundry care. You could possibly have a repairman (this wouldnt be covered under warrany) try to retrofit a older service valve in your machine.
Jan 13, 2008 | Washing Machines
Hoover 750L top loader washing machine
I had this problem. I alternated the hot and cold water valves (changing over the wiring) and then hot tap then dribbled instead of the cold. Replacement part i believe is around $35AU
Dec 29, 2007 | Washing Machines
Washing Machines Logo
85 people viewed this question
Top Hoover Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hoover Washing Machine Expert? Answer questions, earn points and help others
