Question about Lowrance GlobalMap 3500C GPS Receiver
Will not recognise navionics chart
I recently had a problem with an alarm that would not go off.I played around with the settings,and now the unit starts up with the pre-installed map of the world,but does not recognise the navionics chart that has been working o.k.How do I programme the unit to read the navionics charts??
Many thanks.
  • Anonymous Sep 28, 2008
    can not activatemap card
Take the chip out and put it back in why the unit is on
Posted on Sep 14, 2008
Lowrance elite 5 HDI cHart is not accurate. When I am at my dock the cursor shows I am in a cove about a mile away. I also don't know how to set the scale of the chart view.
Its not the scale,, its the settings.. are you using a Navionics card or the built in map... there is a setting to tell the unit which one you are using.. the navionics card needs to be told what section of the USA you are in. Sometimes mine decides I am in North Georgia..(never been fishing there!?).. I have to set it back to sweet home Alabama.
Hope this helps..
Jun 10, 2017 | Lowrance Boating
How do I get my lake map chip to come on
With your card in your unit follow these steps it should accomplish letting you view your map data.
push MENU twice
Highlight CHART push ENTER
Highlight CHART DATA push ENTER
Highlight LOWRANCE push ENTER.
You will note there is an option for Lowrance and Navionics, if you select Navionics you will see a distinct difference in the way the base map displays on your unit.
Hope this helps.
Feb 11, 2015 | Lowrance HDS 5 Fishfinder GPS Chart...
Navionics maps don't seem to work on my lowrance elite 5 chirp
In your menu under CHARTS there is a choice for either LOWRANCE or NAVIONICS. Select NAVIONICS and you should be able to see your chart maps.
Jan 20, 2015 | Lowrance Boating
Navionics Gold charts will not display on a Lowrance Endura
i have lost my maps on the gold card Australia e&n i have not taken the card out of my lowrance gps sounder lms 339c since new some three & a half years can they be restored i have had no luck trying to contact navionics australia
Jun 07, 2010 | Navionics Gold United States East...
Hi,when i switch on my lms-332c the map does not come up on the screen.If I remove and replace the map card it works perfectly. Can I fix this? regards nigel
I am guessing that the card you are using is a NAVIONICS chart? There have been some Lowrance units that were made around the same time that have had problems recognizing a Navionics chart right from power up.
Make sure the LMS-332 has the latest firmware version which can be downloaded from http://www.lowrance.com/en/Products/Marine/Full-Size-SonarGPS-Chartplotter-Combos/LMS-332C/Downloads/LMS-332C-Software-Update/
If the update doesn't help, this is going to be a compatibility problem with the LMS-332 and that particular card. You will need to replace the card or upgrade to a newer unit...but probably can just get used to removing and replacing the card when you turn the unit on.
Jul 08, 2009 | Lowrance LMS 332c Mapping Sonar/GPS...
How do you activate the fishfinder for the furuno 1650 WF
pressing the "SNDR" button activates the sounder press"ALARM" tyo acces alarm menu, turn them on or off there, look "NEXT PAGE" for alarm 2 847-746-0100
Apr 16, 2009 | Furuno 1850WF Gps Fish Finder Combo...
Installed chip on hummingbird 787c2 but there's no detailed map
Low detail charts included. You have to buy high detail charts!
Apr 10, 2009 | Navionics: Gold+ Chart Cartridge
Lowrance not reading navionic
Make sure that the 5200c is set to read the Navionic card. You can set that under Map Data.
Mar 08, 2009 | Lowrance GlobalMap 3500C GPS Receiver
Color definition
Hello bidder42955. I suggest you check your controls for a brightness or contrast adjustment. An X-ray should not have an effect on the LCD display.
Sep 22, 2008 | Navionics: Gold+ Chart Cartridge
Navionics gold card & humminbird 78c2
Hi!
You NEED to have a gps lock in order for the card to show it's true potential.
Also check in the menu for a setting that says "Map detail" and change it to all available. It could be the setting is on a lesser choice (like the internal mapping and not the new sd card)
Hope this helps!
Mike
Aug 06, 2008 | Navionics: Gold+ Chart Cartridge
Lowrance GlobalMap 3500C GPS Receiver Logo
548 people viewed this question
Top Lowrance GPS Experts
Andrew Taylor
Andrew Taylor
Are you a Lowrance GPS Expert? Answer questions, earn points and help others
