Question about Zenith IQB64W10W 64" Rear Projection Television
IQB64W10W high-def problem
I can no longer use my IQB64W10W to watch any high-def programming. Unless the camera isn't moving, the image washes out and gets very dark, like the contrast can't keep up. Regular low-def stuff and DVD's still look OK, but this TV wants high-def and nothing else, lets face it. Also, when any channel banner comes up, it is shifted left about 2" from where it should normally be. I had a qualified repair place look at it over a year ago, at the time they could get the module to fix it but it was outrageously expensive. I checked about 6 months ago and now they say Zenith isn't making repair parts for this TV anymore. I've got to have my high-def fix again, I just hate dropping thousands on a new set when I remember just how good this thing once was. Has anyone ever had this problem, and if so, what exact module fixed it...the digital module?
  • 1,476 Answers
Your problem sounds like the digital board and probably was what the repair people said. I would suggest telling them about Tri-State Module, Inc in Evansville, IN. 800.203.7484. They have a good selection of modules for about any set and most are under $150.00 with the average being $100. They rebuild boards and all boards carry a 12 month warranty. You can also access them at www.tristatemodule.com. If they can't help try PTS in Bloomington Indiana. I use them for alot of replacement modules. Same deal as tristate. www.ptscorp.com
Posted on Jun 22, 2006
SOURCE:
IMAGE STAYS ON FOR AN LONG TIME
Sounds possibly like image retention. If you watch the same channels often any recurring text, logos, or graphics, especially white colored, can ghost on the screen.(playing the same videogame for a long period can also have the same effect) Watching other programs or channels will cause the ghosting to disappear.
To prevent image retention you need to activate the TVs anti image retention mode(Called ISM Method). On Zenith and LG (the manufacturer of Zenith T
s) plasma TVs open the TVs menu, select the Option section (picture of a briefcase with a wrench). Select ISM Method and change it to Orbiter, this is reccomended if you watch programs or channels (or play videogames) that have still images for long periods of time. It moves the image a little every couple minutes.
If watching others channels or programs doesn't make the image disappear, change the ISM Method to either Color Wash or White Wash (don't use White Wash frequently, it over excites the plasma gas and can shorten the life of your TV if overused) for a few minutes and then return to Orbiter.
Oct 23, 2013 | Zenith Z60PV220 60-inch Plasma TV
Band of dot's(millions) across screen only whilst watching in hd mode and whilst using any menu option such as volume etc. dot's not there whilst watching any sd programes
I think I have a good idea of what you're experiencing.
Our minds are so set in the low-def mode that when those extra lines are filled in for high-def it looks like a bunch of dots. Notice everything is so much more clear? I thought the same thing when I watched my first blu-ray disc.
Watch something in high-def and then go back to standard immediately after. You'll notice that you can't get near as much detail off of the low-def.
Those dots are your mind trying to put high-def into low def.
Hope this helps; please rate my solution accordingly
Respectfully,
Don
Feb 05, 2010 | Samsung LE26R74BDX 26 in. HD-Ready LCD...
Will set be campatable after June with the new high def?
Your set is HDTV-ready....
With an HDTV-ready set you’ll need an external digital tuner to watch HDTV programming.
However, if you have high-definition cable or satellite service you can watch those HDTV stations right now on your HDTV-ready set, no extra tuner needed.
which means you will still need a converter box if you use an antenna signal.
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
Apr 26, 2009 | Televison & Video
Camcorder Connect live with USB
My knowledge in video editing is limited, but here's what I could dig up.
m2ts is also referred to as AVCHD, (MPEG4) a high-def Interlaced format which most computers cant render properly since most computers render in progressive format. You have to convert it to MPEG2, AVI, WMV, MOV or other movie file types in Progressive mode, a process known as "Deinterlacing" in order to edit it. Depending on how big the file is and how fast your computer is this could take several hours. Also, you cant view AVCHD files on normal televisions, you need a high-def TV.
If you want to edit high-def videos with post-effects and music etc, for dvd or blue-ray, you'll need a more powerful computer. The "recommended" minimum is a 64bit dual core processor, windows vista 64 bit, a seperate 500Gb or bigger hard drive and at minimum, 3-4Gbs of RAM with a high-def TV monitor. (1080i) Rendering High-Def videos is process heavy and can take up to 12+ hours to render a single 30-60 minute video with post-fx like music, logo's etc. The reason you need a 64bit processor and 64bit windows is because regular XP and Vista wont recognize more than 3Gb of RAM.
You could get by with a 32bit dual core processor and 2 gigs of RAM on windows XP, it's just going to be slower. You will still probably need a high def monitor if your going to edit in high-def mode.
High-def is new technology to mainstream consumers. Supporting technology hasnt caught up yet including most software--however most of what I read stated that Sony Vegas Platinum can do this pretty well.
Your camera is capeable of recording in progressive mode. You'll have to read the manual on how to do this. This will record it in standard mode which is not high-def. (For future reference)
To sum it all up, the camera's technology is more advanced than most PCs. I downloaded AVS Video Converter and converted the AVCHD, (MPEG4) a high-def Interlaced format to HD Video 720p: WMV9, 7000 kbps....... on the drop down screen of the AVS program. I now can view my videos in Progressive Standard mode with NO choppy play back or problems. Please note that 720p is a non digital standard Television view.
Hope this helps.
Jan 30, 2009 | Canon VIXIA HV30 DV Camcorder
Picture format
The HD reciever shouldn't be the problem.
If you recieve an image with a 4:3 aspect ratio, the image will be displayed at that ratio on your HDTV unless you specify otherwise. To do so go to your TV's Setup screen
setup
Choose picture formats
select smooth wide as your default
***Some digital (ATSC format) stations may transmit 4:3 images in a way that will not allow expansion. You will be unable to adjust the picture format.
Hope this helps!!!
J
Nov 17, 2008 | Hitachi 53SWX10B 53" Rear Projection...
Hig Definition
Sorry, no high-definition 1080 I........if you have RGB component
video input on your TV the best you can do is 480P or I from
component out on back of DVD..............T.
Dec 08, 2007 | Sanyo DS27820 27" TV
No Picture
1. If you are using TIFF mode for uncompressed images, the camera takes much longer to process the image because of the very large file size. It takes longer between shots and longer to play back a TIFF image. The TIFF setting on the camera Top LCD Display is 'No Stars' (One Star = Basic, Two Stars = Normal, Three Stars = High Resolution, No Stars = be patient for TIFF). Unless you are doing professional images, we suggest that you use the normal or high resolution JPG settings (Two or Three Stars / FULL) for good results. 2. If the camera can not focus on a subject, or can not determine the appropriate exposure setting, the camera will beep and disable the shutter button. This is to avoid improper processing of the image. This is usually due to either poor lighting conditions or movement. 3. The camera Flash Element requires ten seconds to recharge between images. Although the camera is ready to continue capturing images almost immediately in bright (daylight) settings, if you are using Flash photography the Flash element will need to charge between shots. 4. The batteries may be running low. LCD Display, Flash, and Playback use much more power than taking pictures. It is possible to quickly consume battery power, even if you are not taking many pictures. Try turning the Mode Dial to the OFF position to recycle power. If the camera beeps and will not take a picture under normal conditions, you may need to change batteries.
Sep 15, 2005 | Toshiba PDR-M11 Digital Camera
No Picture
Sep 15, 2005 | Toshiba PDR-M21 Digital Camera
Zenith IQB64W10W 64" Rear Projection Television Logo
160 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
