Question about Sony Playstation 3 (PS3) Console
Hello can you help with this error!
One day I was playing my PS3 over a friends house and he had his PS3 attached to a HDMI cord. When we decided to switch and play on my system with the HDMI cord, it worked fine, but when I got home to plug the AV cable back to my PS3 it did not work.
The Audio and Video no longer was able to work. But, when I went to the story to buy a HDMI cable it worked fine.
Since I have a TV without the HDMI capabilities in my apartment I need to use the AV cable.
I went out and bought a new av cable from game stop and it still does not work. What should I do?
  • 23 Answers
When you switch from one cable connection to another (Hdmi to AV etc) you need to reset the PS3 to its default settings. Basically what is happening is, your PS3 is set to HDMI, so when you plug in AV cables it doesn't know it. So you have to reset it. Hook your PS3 up to whatever cables (make sure system is fully off) then hold the front power button down for a few seconds.
Doing this will reset the display settings. You can then go into the XMB (main menu) and choose your connection. Although the PS3 should do this during the start up on its own.
Hope this helps.
Posted on Sep 14, 2008
My ps3 was recently connected to a hdmi cord at my friends house now im back home nd i plug the av cords in and nothing is coming up its still connected to the hdmi
Hello. Sounds like you need to adjust the video output setting back to component. Go to settings, display settings, then video output setting. you may need to do this under an hdmi connection in order to see it. Once you change it to component then it will switch over to a standard AV connection.
Apr 05, 2011 | Sony Playstation 3 (PS3) Console
My ps3 was working fine four days ago. I took it to my brother-in-laws two nights ago and hooked it up. We played it on his tv with an xbox hdmi cord and it was fine. I took it home and plugged it up to...
Ok you must be using a a/v cable at your house? And the hdmi cable at your brother in laws? If this is the problem its not the xbox hdmi cable. It doesnt matter all hdmi cables work the same. Its your settings. You need to hold you power button down and it should come on and beep twice then release it and a settings menu should pop up if it doesnt hold the power button down until it comes on and shuts off then hold the power button down again until it beeps twice. Hope this helps.
Nov 29, 2010 | Sony Playstation 3 (PS3) Console
I have a HDMI problem with my PS3. I have it
Try entering Recovery Mode and choose "Restore Default Settings".
If that doesn't help, you may have an HDMI port failure - which will require returning the unit to Sony or sending it to a third-party PS3 repair shop.
Mar 25, 2010 | Sony Playstation 3 (PS3) Console
HDMI cable vs non
With your PS3 turned off, press and hold the Power button on the front of the PS3 for about 10 seconds (the system will beep as normal as it starts up but after 7-10 seconds it will beep again). The video settings should now be reverted. Doing this will also reset any theme settings.
I use this method to revert from HDMI 1080p to Composite 576p, without having to swap cables and change settings.
Jan 23, 2010 | Sony Playstation 3 (PS3) Console
I bought a hdmi cord so my son can play ps3 we
Hi:
Check the video connector on the PS3 for a switch to switch from composit video to HD video.
Dec 26, 2009 | Vizio VW32L 32 in. LCD HDTV
Ps3 times out "invalid format" using hdmi cable
its the game in the game there is a trade mark thing and it thinks u are copying so it does any thing to stop u by doing a error382
or
its your cords and your useing a really cheap brand the does not sut your tv and it is does not sut your ps3 so it will cut out and make errors
Jan 12, 2009 | Sony Playstation 3 (PS3) Console
Getting the TV to play through the HDMI cord
First, you need to set the playstation to display on HDMI out.
Plug the HDMI cable into the TV and into the PS3.
Use the PS3 to setup the video settings to 720p which every HDTV can display. Then switch the TV-out to HDMI and it should display.
Also consult your televisions manual to set it up for HDMI input as well. Make sure that the TV allows sound through the HDMI port as some older HDTV's didn't have that ability.
If you still have a problem; please let me know! I hope it helps you out
Aug 08, 2008 | Samsung LN-T4061F 40 in. LCD HDTV
Playstation 3
try using the composite cables as well.....with your tv set to the composite input go back into the settings and select the HDMI output switch your tv's input back to your HDMI input and remove the composite cables....it should work fine...
Jan 11, 2008 | Sony Playstation 3 (PS3) Console
Hi I recently played my ps3 on my friends tv using an hdmi lead and all was fine. Now i have returned home and tried to play my ps3 without the hdmi lead and it wont work can you help please.
go back to your friends with your ps3 and change the tv settings on the ps3 back to scart output but also take your scart lead and have it plugged in at the same time. once you have selected scart output unplug the hdmi cable to make sure the settings are right. hope this helps you.
Dec 26, 2007 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
167 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
