Question about LG LS-K1830CL Cool Mini Split Air Conditioner
Price I want the price for LG LS-K1830cl 18000 btu
    Prodigy:
    An expert who has answered 500 questions.
  • 540 Answers
What do i look like I'm running , a TACO STAND? different companies charge different prices!
Posted on Sep 05, 2008
The control card is displaying error ch-01
PDF]SERVICE MANUAL R?410A Ductless Split System Air ...
dms.hvacpartners.com/docs/1011/Public/.../42108920400_ICP_26610.p...
421 01 9204 00 1/03/13. SERVICE MANUAL ... Consult local building codes and National Electrical Code. (NEC) for special ..... 18000 (5970-22350). Heating Capacity (Min. - Max). Btu/h. N/A ..... Error Messages Displayed Front Panel. S.
Oct 08, 2015 | LG 18000 BTU Dual Zone Mini-Split Heat...
I am looking for0.8 tons a c of price 10000
This is a fix it site. check your local kijiji or craigslist.
Jan 06, 2015 | LG Window Ac Unit 18000 Btu, Energy Star...
Gree 18000 Btu Air Conditioner , f2 appears on display
F2 is an indoor pipe sensor fault. You will need an air con tech or electrician to do this as the sensor is wired into the indoor board. Gree parts can be a bit difficult to obtain but a similar sized pipe sensor from an LG or Teco unit will work. You may have to "splice" the new sensor onto the existing pipe sensor wiring as the connection to the indoor board will likely be different. Contact LG or Teco for your colsest parts outlet or buy direct from them.
Sep 07, 2013 | Gree 18000 Btu 20 Seer Ductless Mini Split...
Lg aircon splitape p/no:3854A90006F how much the price
Hi.
The price for the model listed is not available. Please select a different model from LG website: LG Air Conditioners
Feb 15, 2011 | LG LS-J0910HL Heat & Cool Mini Split Air...
I have two senville mini split 18000 and they both frost up with in 1 Hr. of use both have been pumped out and recharged
Dear Friend! Before recharging gas.did you check leak testing? If not, again you will same problem.
And some more reasons for frost up:
1. Indoor coil & air filter dust blocked-clean it. 2.Less rpm of indoor fan motor- replace capacitor or motor.
Thanks, it's helpful to you.
Jan 10, 2011 | LG LS-K1830CL Cool Mini Split Air...
How many VoltAmps does the LG LS-K1830CL consume?, What is the voltage?, Mono or 3 fase?...
BTUs: 18,000 (C)
SEER: 10
Interior Voltage: 36
Voltage: 208/230 VAC
Maximum 8.5 amps
Single phase.
Is it helpful?
Dec 28, 2010 | LG LS-K1830CL Cool Mini Split Air...
I have installed an LMU246 with two heads. One 9000 BTU and the other is a 12000 BTU. The 12000 seems to work fine but the 9000 head dosent cool and when I tried it on heating, a c7 code comes...
with the Lmu24 you have a variable speed compressor i wouldn't suggest attacking this repair on you own, get a Nate certified Sr. service tech out there and have them do cause your taking about high end cutting edge compressor technology, how ever if you need them i can email you a pdf copy of both owners and service manual.
Oct 01, 2010 | LG LS-K1830CL Cool Mini Split Air...
LG 18000 ac leaks water in the front of unit indoors.
the drain pan is either clogged or the unit is not mounted properly. If the drain pan is clogged simply clean it and the problem goes away. In the case of the unit mounting, check the angle of the unit and the drain pan inside, if it tilted to the front even just a little then water would leak. the drain pan should lean toward the drain and away from the front.
I hope this helps.
Jun 05, 2009 | LG LS-K1830CL Cool Mini Split Air...
IR Codes for LG ductless air conditioner
I, have a LS120cp lg ductless.The only way I,can get the unit to run is by pressing the test button on outdoor board.
Jun 04, 2008 | LG Heating & Cooling
LG LS-K1830CL Cool Mini Split Air Conditioner Logo
124 people viewed this question
Top LG Heating & Cooling Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a LG Heating and Cooling Expert? Answer questions, earn points and help others
