Question about Lexmark X1270 All-In-One InkJet Printer
X1270lexmark all in one willnot work any more
Can not get printer / scanner to work at all.gone thriugh several steps.computer says the printer is getting message but can even get a test page to print
  • 1 more comment
  • Anonymous Sep 05, 2008
    exactly as previous correspondent describes.Printer at least 4 years old.Have ensured printer is on and is connected via a usb port to the computer.
  • Anonymous Sep 06, 2008
    I tried to install the printer to my moniter but nothing works. The monitor says I' ve installed it,but when I tried to get the printer to work,nothing happens
  • anthonykelly Sep 07, 2008
    Inserted new black 17 ink, printer goes through motions but nothing on paper.
Nver could get lexmark x1270 printer to work trying several different repairs. replaced printer with hp laser and worked just fine.
Posted on Sep 08, 2008
Lexmark X4550 Scanner not working
A quick fix for most communication errors can be achieved by resetting the printer and/or rebooting the PC. Simply disconnect the printer from your computer (if USB connected)> reboot your pc > unplug and re-plug the printer into the power source to reset it. When the printer turns on, reconnect it to your computer (if USB connected). Then try to print again once the computer fully recognizes the USB connection or when the WiFi light on the printer turns solid green (if WiFi connected.).
If that doesn't help, try the steps below:
  1. Disconnect the USB cable connecting the printer from your computer.
  2. On your computer, go to Control Panel > Printers and Faxes.
  3. Delete the Lexmark print object.
  4. Reboot computer.
  5. Re-brick your printer by pulling out the power supply - black box where the power cord is plugged into on the back of the printer, and re-plug after 30 seconds.
  6. When the printer turns on, reconnect it to the computer.
  7. Wait until your computer fully recognizes the USB connection. To check, go to Control Panel > Printers and Faxes. If you see a new Lexmark print object in the list, try to print a document to verify that the problem is fixed.
Jan 05, 2012 | Lexmark X4550 Multifunction Wireless Color...
I cant print wireless and how do I set up the scanner to work?
Your wireless communication problem could be caused by several factors. Try to check the status of the WiFi light on the printer. Here's How to identify a Wireless Communication Problem and Resolution Tips.
For your other concern, make sure the printer driver is installed on your computer. The Lexmark OCR scan software, used to scan documents for editing, is available only in the install disc that came with your printer.
For the step-by-step instructions on how to scan, please refer to the Lexmark S405 User's Guide.
Jul 26, 2011 | Lexmark Interpret S405 Wireless All-in-One...
My scanner has not worked since i purchased this printer. My error is as following: CANNOT CMMUNICATE W/SCANNER. cable may be disconected or scanner is turned off. CODE: 2,155,0. PLEASE HELP!!!!
Follow these steps:
1. Unplug the printer.
2. Uninstall the driver.
3. Re-boot your computer.
4. Then reinstall (from the CD if you still have it)
5. Follow install instructions with printer.
6. Test the printer/scanner/etc.
7. If this doesn't work... go to canon's website and download the most current driver for the printer. then redo these steps using the downloaded driver for step 4.
If this doesn't work, return the printer if you still can.
Apr 02, 2011 | Canon PIXMA MP160 All-In-One InkJet...
Hi...I'm having a problem with my printer...can
As you just starting new you need to have a step by step instructions to make it easy for you...remmber that at all times proplems usually simple as wrong connections, not secure conection, bad cable, etc. so you need to log into HP site at http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00040499&cc=us&lc=en&dlc=en&product=3418707 and they have a step by step instructions that test your system and your printer...hope that help if not let me know and I will do my best to help...please do not forget to rate the service so we can improve on it.
Sep 25, 2009 | HP Photosmart C4580 All-in-One InkJet...
Hi.. i want to connect two computers thriugh lan cards. i need the cable specs and all the things i have to do....
First, make sure you have a crossover cable a normal cat5 cable will not work. As for setting up the network, here is a simple tutorial that is step by step and aimed at the novice user.
http://www.leeindy.com/connecting_two_computers_using_crossover_cables.shtml
Good Luck!
Sep 23, 2009 | Intel Desktop Board D865GBF (MBIND865GBF)...
I tried to scan a picture an the scanner said i need to install or run software for feature. i put in the disc that came with the 1610 and it was turned down by the 9400
Hi!
lets do this step by step.
(1) Go to the control panel and use the ADD/REMOVE program and delete everything relating to your printer? scanner.
(2) Go to the printer icon in the control panel and make sure the printer / scanner is gone..No more printer.
(3) Go the C;/program files and delete all folders pertaining to the printer/Scanner.
(4) Reboot.
(5) Re-install the software. Remember if, when you did the first install, did you have to install the software **PRIOR** to connecting the printer? if so, please do it the way you did it initially!
That should solve it.
A last resort is to do a System restore to a date that it worked. Do you Defragment on a regular basis?
Mastersage.............................
Mar 04, 2009 | Computers & Internet
Canon i960 printer will not print magenta color
Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Jan 08, 2009 | Cannon Canon i960 Photo Printer
Scaner is not working of hp3055 color laserjet printer
Step 1:. Check Hardware Driver Installed Properly
- My Computer-Properties-Hardware-Device Manager
- If Yellow mark in printer and Scanner field, the Printer
driver not installed properly.
- So reinstall Printer Software
Step 2: If Scanner Option only not working,
- Go to Scanner Settings(Start-Programs.....)
- Choose Correct Scanner Name.
Or
- Press the Scanner button in hp 3055
- If Hardware driver was installed correctly, its automatically
deduct on your PC
Jul 02, 2008 | HP Color LaserJet 2600n Printer
All in One Scanner/Printer problems
Go to this link and type "cannot communicate with scanner" in the search box. Click Search. Then select the "ERROR: Cannot communicate with scanner" link. You will see several things to try to correct your problem. Usually, this error shows up if there is another USB device connected which prevents the computer from "seeing" the scanner, even though it can print without problem. So do try to disconnect any other USB device (except mouse or keyboard) and reboot the system.
May 20, 2008 | Canon PIXMA MP160 All-In-One InkJet...
SOFTWARE MALFUNCTION NO DIRECTOR OR SOLUTION CENTER
What Operating system are you using? One thing I would recommend trying is uninstalling all software related to the printer/scanner, then turn off the computer and unplug the printer from the computer. Turn the computer back on then restart the computer and try reinstalling. Your problem could be that the computer is not uninstalling the printer/scanner all the way meaning the computer is still detecting the printer/scanner. Those steps would fix it if that is the case.
Oct 22, 2007 | HP PSC 1410v All-in-One Printer
Lexmark X1270 All-In-One InkJet Printer Logo
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
