Question about Pentax Optio M20 Digital Camera
USB connection problem?
I don't have the priginal USB cable so I bought a universal USB adapter from Walmart. My computer does not recognize the camera so I can get pictures off of it. Ideas?
  • 56 Answers
The Best solution is to get an SD card reader. Then you take the SD memory card out of the camer, put the Sd card into the reader and plug directy into a USB port.  They are very cheap to buy and quite handy.
Posted on Sep 10, 2008
My Iomega LDHD250U 250 GB USB External Hard Drive's Power and Usb ports WILLNOT CONNECT!!!!!!! Please help ive been trying to figure out why all day.
Dear Friend, Your I-Omega case might be bad or the controller inside that connects everything. I suggest you to get: http://www.walmart.com/ip/Apricorn-Universal-Hard-Drive-Adapter/10811435. and pulled your hard drive enclosure apart, then removed your hard drive and connect with the external adapter. Usually comes with a SATA or IDE connector for data and power adapter. After connecting everything plug into your PC and it should be able to recognize.
Good Luck#
Jan 13, 2014 | Iomega (33215) 250 GB Hard Drive
LG dvd external drive not recognized by computer
ERROR 43? Check your SATA connection.
HERE'S HOW I FIXED MINE.
(IE. Computer tries to install driver for BD burner, but ultimately fails, and gives the message. "Unsuccessful" and/or "Microsoft Windows stopped device. Error 43") The SATA CONNECTION on my BD burner's EXTERNAL CASE had gone bad.
TO TEST IT. I used a SATA/IDE to USB Adapter Cable I bought for about $10 on amazon.
  • I unscrewed the external case to get at the internal drive, and plugged the SATA adapter cable directly into the internal BD burner drive (bypassing the case assembly), and plugged the other end into my computer USB port.
    • PS My BD burner POWER was working OK, so I left the big white 4pin power adapter connected to the original external case.
VOILA! Both my laptop and my desktop PC recognized the LG BD burner again and assigned it a drive letter (like it used to do).
  • Now I either need to (1) Buy a NEW EXTERNAL case ($10 - $30), (2) install it as an internal drive (could get problematic if "ANYDVD" is installed) or (3) just leave it connected via the cheap adapter cable.
It's super EASY (& inexpensive) to TEST this before spending $$$$ on a new equipment.
Hope this helps someone. It had me miffed for a while there.
Jan 02, 2014 | LG GSA-2166D DVD RW Dual Layer Burner
Connecting with usb port
try a usb/
Parallel Printer Adapter Cable
cable you can find them at office supply stores or others such as walmart.
http://www.walmart.com/ip/15075022?adid=22222222227000586714&wmlspartner=wlpa&wl0=&wl1=g&wl2=&wl3=21486607510&wl4=&wl5=pla&veh=sem
Dec 16, 2012 | HP LaserJet 4p Printer
Wifi modem is not recognized
Try recycling the wireless router by unplugging the power to it and wait 20 seconds then plug the router back in. Sometimes that is all it takes.
After recycling the router if the adapter still does not show any wireless networks make sure you don't have the wireless radio turned off in the software that runs the adapter.
If all fails, try the adapter in another usb port if it is a usb adapter.
You could reinstall the adapter's software and driver.
May 06, 2012 | AcerPower 2000-UD431C - Core 2 Duo E4300...
When this Boynq 841905 Cubite PC speaker is plugged in it seems to disable the USB port on the front of my PC where my wireless adapter is plugged in. If I unplug the speakers USB connection in the back...
click start control panel administrive tools ,computer management ,device manager scroll down universal serial bus controllers you should see a yellow question mark?
right click to reinstall drivers or
if you can see your usb drive but its not working
ports(com&lpt)right click update driver
check the USB leads that attach to the motherboard usually red-white-green-black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems for a computer and its parts also
scroll to disk drives if you can see your drive + to expand right click you should see options to update driver,disable,uninstall scan for hardware changes. or
select properties you should see options in the general tab to troubleshoot,policies,volumes,driver and details under the driver tab you will have the options to check the driver details,update driver,rollback driver or uninstall
hope this helps don
Mar 13, 2011 | Boynq Cubite Computer Speakers
I have a 7 pixel camara I need usb cable and the power adater
I had a problem just like yours and I went to walmart and bought a universal usb cable it was only about $20 and it comes with three or four different ones and I found out that my adapter works on any appliance that I need a usb cable for including my printer
Oct 23, 2009 | Akai Dc7370 Digital Camera
My PC doesn't recognize my LG Xenon with the new data cable I just bought. I have my memory card in my phone and the USB connection set to Mass Storage and downloaded the LG USB driver. I can't figure out...
get a memory card adapter you can get one for reasonably cheap at walmart and hook that up to your computer don't use a cable that will not access files on your memory card
Sep 04, 2009 | LG Xenon GR500 Cell Phone
Drive is a blinking brick of garbage.
Is the hard drive a USB external device?
Does the hard drive spin up at all or does it make clicking sounds?
If the hard drive spins it may not be faulty, it may be a faulty USB hard drive adapter case.
Put the hard drive in another USB hard drive adapter and connect it to a computer, if it still doesn't work then the hard drive has died.
Jul 24, 2009 | Seagate Free Agent Go Small 12 GB USB...
A Canon MP240 four-in-one no USB?
Most USB printers do not include the cable, sorry. You can get a cable at Walmart or almost anywhere, just make sure it is a USB printer cable. It will have the aprox. 3/4" wide end to match the computer and a more square end with one side of the square having an angle on two edges so it can only be pluged in one way. Good Luck
Jul 21, 2009 | Canon PIXMA MP240 All-In-One InkJet...
Pentax Optio M20 Digital Camera Logo
67 people viewed this question
Top Pentax Cameras Experts
Greg Cann
Greg Cann
Are you a Pentax Camera Expert? Answer questions, earn points and help others
