Question about RCA HD52W59 HDTV Projection Television
Power button blinks, tv won't turn on
I have an RCA HD52W59. When it is plugged in the power button flickers green, the set does not power on. Even after it is unplugged, it continues to hold a charge for about a minute. I saw the info about the flyback, so I pressed and held the power button while I plugged it in. The power button flashed nine times, then paused and flashed once. This cycle of 9 and 1 repeats as long as I hold down on the power button. After releasing the power button (with the set still plugged in) the power continues to flicker and fade in and out, with no set pattern. Please, please, please help.
  • RCA Master
  • 8,617 Answers
Replace the flyback, that should straighten it out. You need flyback 259296 you can get one at the following link with free step by step instruction on how to replace it, from beginning to end.
Posted on Sep 06, 2008
No Picture/No Sound
This is very possibly a power surge, can you tell me how many times the light blinks, you probably have a bad power board now if you had a power surge.
Aug 11, 2007 | RCA HD52W59 HDTV Projection Television
I turn my RCA HD52W59 tv on and there is no picture. The green power light blinks 5 or six times but no picture.
Check the Capacitors on the Power supply board. They look like little soda pop cans. They all should be flat tops. If you see some buldging tops? They are bad and need to be replaced. Please use caution though Unplug the tv and discharg all large capacitors before proceeding. Cause even an unplugged unit the Caps hold a charge that can kill you.
Jan 05, 2011 | RCA HD52W59 HDTV Projection Television
RCA projection HD52W59 won't turn on 2 green flashes at power but
Most techs dont know much about the ITC222A chassis which is what your model is. I would double check the ribbon cables that connect the Main deflection board and signal board. There are two of them just be sure they are proerly seated into their sockets as Those connections can cause that type of random operation
Jun 20, 2009 | RCA HD52W59 HDTV Projection Television
I have an RCA HD50LPW62A television set....We recently had a power outage. The green power button is on and will not go off. We have tried disconnecting the TV and plugging it back in again, to no avail....
usually has a bunch of bad capacitors in the power supply. they may have the top puffed up. these are in the power supply where there are high voltages. not an easy repair
Feb 24, 2009 | RCA HD52W59 HDTV Projection Television
RCA TV Will Not Power On - Powered Off Suddenly
I have the same problem. Just Monday it started, Green light blinks but nothing comes on. Any suggestions?
May 31, 2008 | RCA HD52W59 HDTV Projection Television
TV wont turn on.
I am sorry to hear about your problem with your rca... I work on these sets daily. (so that should tell you how dependable..First thing you can tell is that is not the main fuse.. THe main processor is recieving power and then something in the startup procedure upset the processor.. so it shut it down. unfortantly thats where the troubeshooting begins....technicians have specail computer equipment that alows them to read errors codes much like that of a car... most of the time it will be a high voltage issue. hoizontal transistor. flyback..if you have to replace a board you may even need special euipmwent to do that...Does the set make any noises chirps or squeals..did it smell ...what what is doing when it whent out
May 05, 2008 | RCA HD52W59 HDTV Projection Television
42' rca problems
my tv did the same thing my power supply board had went out had to replace it now I have no problem did you notice a hiss when you cut it on if so it is the same problem
Apr 07, 2008 | RCA HD52W59 HDTV Projection Television
does the set fire up or is it dead.
Aug 12, 2007 | RCA HD52W59 HDTV Projection Television
RCA HD52W59 HDTV Projection Television Logo
137 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
