Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
Convergence Problem The symptoms are the TV will start up perfect everytime but the convergence is off a lot on the sides (pincusion). I can get into the service settings and manually configure the convergance so that the picture looks pretty good in standard definition but when in High definition I can only stretch the green out to about 75% of the total screen size. Red and Blue I am able to stretch to full screen. Under the service menu I can't change any of the geometry settings. I read that some possible problems could be CPL230, RF009, RL231, IF001 along with the CL037, TL029 and DL032. I have also heard that it could be the convergence power board, but I am able to change the convergence for all colors just not all the way. Do I just need to change the focus on the front of the TV because of the new flyback? I haven't played with any of the hardware settings yet. Do I need to worry about damage caused stretching the convergence too much with the software adjustments? Thanks
  • modeuce Sep 06, 2008
    Thanks for the quick reply! I'm sorry, after i posted I did remember that I could change all of the geometry settings except H Amplitude, EW Amplitude, EW Trapezium, and maybe a couple others. It sounds like you nailed it. I will try to replace those as soon as I can and get back to you.
    I can't find tl120. Did you happen to mean TL029 was the ew buffer?
    Genius:
  • 1,030 Answers
Ok first question. I assume your a tech. YOU could change geometry settings ... which ones ... i have had a similar problem before does the horizontal amplitude work... will piture go in or out, this is a ew correction problem that looks like convergence. the main cause of this is DL032,DL030, and CL032....sometimes the ew buffer tl120. you then might have to go and reconverge the set good luck
Posted on Sep 05, 2008
We just started having convergence problems with our WS65905. I performed the standard convergence adjustments and have the red/blue bars perfectly aligned. On the screen we have green and pink bleeding...
Yes, call local tv repairman to fix the issue because convergence output section got some problem like cold/ dry solder joints, devalued few resistors that can also cause of these symptoms and defective convergence output ICs are also one of bad convergence reasons in rear projection tv, all that happened because of heat and high amount of current drain in convergence circuit and its common problem of rear projection tv.
Visual check by experienced tech is necessary and repair would cost you around $250 to $350
Hope these info will help you.
Thanks.
Jul 25, 2010 | Televison & Video
"Perfect Focus" problem on Samsung HCN4727W
You have a bad sensor, a bad digital convergence board, or the new board is not working correctly. I would start by swaping out the convergence board or exchange it for another one. Good Luck
Nov 08, 2007 | Televison & Video
Pincusion/Convergence Problem
You can find some presets on the display section of the motherboard. You try adjust to fine tune the picture.
Keep a mirror in front of the TV and try adjust the presets slowly with the help of a properly insulated screw driver.
Caution TV venerates very high voltages.
Jul 25, 2009 | Televison & Video
The blue color sags in regular tv but is fine in hd
Your TV most likely has one or more possible problems.
Problem #1: Convergence Chip Failure ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Problem #2 CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
2c07611.pngSolution #2
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc.
Apr 06, 2009 | Akai PT4298HD Rear Projection Television
Convergence Problem
have you checked the resistance of the pico fuse
Sep 05, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Distorted Picture
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
Convergence problems are very common on all Projection TV sets including Sony, Samsung, JVC, Philip Magnavox, Panasonic, Akai, Pioneer, Hitachi, Zenith, and others. You can get a convergenece repair kit from the link below.
Common Symptoms include....
  • Screen looks 3D
  • TV shuts off after powering on - TV may also make a chirping noise.
Here are some photos of convergence problems.
Using your original remote go-to the settings menu then goto the convergence section.
You should be able to move RED and BLUE in all directions - up, down, left, and right.
If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem.
Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a solution
93a1209.pngCONVERGENCE SOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses.
This is a a fairly easy DIY job if you know what you are doing. If you have never done this before we would advise calling a shop or if you want to do it yourself get a complete kit with instructions and support from www.TvRepairKits.com
Aug 02, 2008 | Toshiba 65HDX82 65" Rear Projection...
Mitsubishi VS-50501A convergence problem
Projection TV sets have several common problems listed below.
Problem #1) Convergence
Symptoms:
  • Screen Looks 3-D
  • Colors wont align
  • Screen may look distorted
  • No Audio/Video - makes a chirping sound.
Example Photo:
Problem #2 CRT Fluid has clouded over.
Symptoms
  • Dull Video, Washed out
  • White/Bright looking video
  • Halos around objects
  • Red/Orange looking
Example Photo:
You can see more examples and find a fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
May 01, 2008 | Mitsubishi VS-50501 50" Rear Projection...
Bad ghosting of all colours
The most likely cause is shorted convergence chips and possibly a few pico fuses.
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony,Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer2_bing.gif Hitachi,Mitsubishi,Zenith and others.
You can get a convergenece repair kit with instructions from the links below.
Here are some of the most common problems with these sets...
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2
Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
You can see some more examples and find a fix herebb0cf99.png http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jan 09, 2008 | Samsung PCL545R 54" Rear Projection...
COLORS ON BOTTOM LEFT SIDE
You probably have a problem with your convergence board. Try resetting the convergence manually on your TV - go to Philips website for instructions on doing this if you have lost the Quick Start Guide. If the manual convergence fails, then your convergence board needs to repaired or replaced.
Dec 24, 2007 | Philips 55PP9401 55" Rear Projection...
Zenith 46" with a "hour-glass" picture.
If the hour glass figure is a seperation of colors that appear to be convegence mis aligned, then, the convergence ICs would be the problem. If the picture is clear and you have a bending on the sides then the pincusion circuit in the horizontal circuit is where to look. Be careful of this circuit, it does control the high voltage. The only way to have a board checked is to have an Authorized Service Center look at it. It does, however, sound like there is a cold solder joint in the power supply that has gradually opened up and now is permanantly open. Call Zenith (LG) to see who they recommend.
Mar 25, 2007 | Zenith Z46Z83D 46" Rear Projection...
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
121 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
