Carrier 38CKC036 Air Conditioner Logo
Posted on Aug 14, 2011
Was running ac. Now blower won't come on for ac or heat. Error code 24 is displayed. Please advise. Would a blown fuse at ac unit cause blower to stop all together
Anonymous
Level 1:
Problem Solver:
  • Contributor 10 Answers
  • Posted on Aug 14, 2011
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
10
Questions
0
Helped
15122
Points
18
It could be your capacitor. I had a fan capacitor go out on one of my 3 units last year and it cost close to $300 for an AC company to come out and fix it. I watched them fix it and it's something that you can do yourself if you know what you're doing and are careful to hook it up right. I have three AC units and another capacitor went out this year and I found a kit with detailed instructions with pictures and phone support at hvacrepairkits.com. It saved me over $200 on the capacitor replacement.
2003 Honda Accord v6 AC and car alarm electrical issues, maybe connected ?
what sub model accord, v6 LX ,
manual or full climate control option??? guess full.
fuses not checked PCM scanned for DTC errors EVAC, hopeless/?
so car starts and runs sand drives ok, <<< not told that.
yes the AC brain on most modern cars is BCM brain controls
and the brain does control the AC compressor. if that is dead so be AC, THE COMPRESSOR CLUTCH, is run by PCM RELAY.
NOT TOLD OUTSIDE TEMPERATURE NOR COUNTRY../
HERE IS A LIST.
1: CHECK ALL FUSES FIRST, CAB AND ENGINE BAY ALL FUSE BOXES SKIP NONE.
2: CHECK IP CLUSTER FOR ERRORS ,ALARMS ERRORS OR LAMPS GLOWING OR IMMO LAMP SHOWS IMMO IS UNHAPPY, MODE.
3: ENGINE STARTS AND RUNS AND CAR DRIVES.?????????
4: HEAD LAMPS WORK KEY ON AND OFF. ,
5: OTHER ELECTRIC FAILURES OR JUST THE BLOWER ONLY?
6: SCAN THE pcM FOR ERRORS, AC IS CUT DEAD EVEN FOR ENGINE OVERHEATING OR OVERLOADED !!! OR IN LIMP MODE/
yah can't fix modern cars lacking a scan tool, no way./
bLOWER FACTS
PER THE SM BOOK REAL
THERE IS A BLOWER RELAY AND SOME FUSES. 12VDC SIDE.
FUSE 30 DASH
AND 21 HOOD, BOTH MUST BE GOOD. and fuse 12 V6
THE bLOWER gets GROUND FROM THIS
Audio-HVAC--Display Panel
l AND ITS BLOW POWER TRANSISTOR MODULE
SO WE KNOW THE TRANSISTOR IS off. IS CAUSE 1.
ONLY WHY REMAINS!!!!
YES THE CONTROLLER DOES NOT WANT TO RUN ANY DEAD BLOWER AND RISK ICE DAMAGE TO THE EVAP CORE.
THE Audio-HVAC Display Panel, READS MOTOR SPEED ACTUAL. speed (a kind blower tachometer wire)
IF SAY A INSECTS NEST JAMMED UP THE BLOWER FAN
THE AUDIO -HVAC, MODULE SEE THAT AND CUTS AC DEAD BY DESIGN AND HARD GOOD REASons/
the THE Audio-HVAC , has the ICE up sensor and monitors R134a
high/low switch and if wrong, tells the PCM to shut down its
Clutch solenoid to compressor ending all AC .
I am no sure what blower does.
but I can say this tell of blower works in heat mode or blower + no AC no HEAT mode. yes then the blower is not bad, nor the controller
what is wring is inputs to the controller are dead wrong
and not scanning the PCM after fuses is why you don't know.
l;earn now this works
Audio-HVAC
Display
Module
https://eautorepair.net/Marketing/Default.asp
not checking fuses first then scanning the PCm is why answers simple are not found.
like these and scads more.
Trouble Code: HVAC 12 (3.0L V6 VIN - Std)
A Problem in the Blower Motor Circuit
Trouble Code: HVAC 13 (3.0L V6 VIN - Std)
HVAC Control Unit Internal Error
Trouble Code: HVAC 14 (3.0L V6 VIN - Std)
An Open in the Evaporator Temperature Sensor Circuit (ICE Up preventions)
Trouble Code: HVAC 15 (3.0L V6 VIN - Std)
A Short in the Evaporator Temperature Sensor Circuit(ICE UP)
Replaced the thermostat on a rbhc-24 with a honeywell and unit won't run now
transformer has a fuse buried in the windings making it impossible to change. It's new transformer time.
Auto fan does not start electric furnace
see this causes and fix it. God bless you
If the furnace won't run, check the electrical service panel for a blown fuse or tripped breaker. Also make sure the power switch on or near the furnace is turned on. Check the unit for a reset button and try it. Some units have a built-in breaker or fuse panel.
If there is not enough heat, raise the thermostat setting five degrees to see if it turns the unit on. If the unit still does not generate enough heat, check the comfort controls . Clean or replace a dirty filter, clean the blower assembly (see the Forced-Air Distribution Fix-It Guide), and make sure that all registers are open and not blocked.
If the furnace turns on and off repeatedly (cycles), clean or replace the filter; and clean the blower assembly (see Forced-Air Distribution Fix-It Guide).
If the furnace is noisy, make sure access panels are mounted and fastened securely; spray squeaking belts with fan-belt dressing and replace worn or damaged belts; adjust the blower belt; lubricate motor and blower oil ports.
If the element does not heat, refer to the Heating Element Fix-It Guide for guidance.
Maytag Neptune Model #MDE5500ATW How to tell if the thermal fuse is blown
If this THERMAL fuse is blown it would not operate at all. If it runs but don't heat it probably is a limit or the heater. If you see a lot of junk in the vent pipe AND it still runs then the heater limits are gone. If the vent it clear but filter housing or blower has an issue then it won't run and the thermal fuse is gone bye bye.
SERVICE MANUAL for slopefaced dryer
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Sep 03, 2012 • Dryers
My 04 Kia Sedona overheats when the AC is on only and only during the summer.Then the Ac loses it's coolness.
Hello and welcome to FixYa! If you have overheating problem, it can lead to multipleissues. You may be running on low coolant that's why the vehicle overheats. Ifthat's the case, please add coolant and make sure that it sits on the rightlevel, too much coolant can cause overheating too for coolant will overflow. The vehicle may have a faulty or worn out radiator blowermotor that's why it overheats. If that's the case then you will need a blowermotor replacement to resolve the issue. If the radiator is clogged with dirt and rusts this issueoccurs too. The coolant doesn't flow normally on the cooling system if it'sclogged. If that's the case, I strongly suggest that you have the radiatorflushed to drain out dirt and rusts. If you think that the radiator served youenough then it's better to have it replaced. Please do check the radiator hoses, If you have worn outhoses it can cause coolant leakage which can result to overheating. A tiny holeis good enough for the vehicle to overheat. A faulty thermostat sensor can cause the issue too. If youhave worn out thermostat, the fan may not trigger that's why the fan won't workwhen under stressed conditions. A blown radiator blower fuse can cause thisissue too so I suggest that you check the radiator blower fuse and replace itwhen necessary. What causes the radiator blower fan fuse to blow? It's becauseof a failing radiator blower motor, If that's the case have the radiator blowerfan motor replaced. If the fluid in radiator doesn't circulate then it meansthat you have a blown head gasket or a faulty water pump. I suggest that you gofor the water pump replacement first specially if you think that it's near theend of it's service life. Usually, water pops out the radiator when engine isreved (a sign of faulty water pump and possible blown head gasket). Hope you find this information helpful enough and thank youfor using FixYa! Have a good one!
2002 Intrepid cam sensor was replaced - now engine overheats. No evidence of leaks or coolant pump failure. Please advise.
My bmw 318 is blower fan not working
Blown Fuse
  • Usually the first thing to inspect when the blower fan stops working is the fuses to see if any are blown. Locate the 10A cluster fuse or the 25A HVAC fuse in your car manual, and examine them to determine if they need replacing. The car owner's manual will tell you where to find the fuses that are connected to the heat and/or air conditioning. On the interior fuse panel of the car, a 30 amp fuse is labeled "Heater" or "HVAC."
Bad Blower MotorIf the fan only works on setting number 3 or 4, or just on the highest setting, it is most likely that your blower motor is failing and is about to die. Use a voltmeter to test the amount of voltage at the blower motor connector with your ignition on and AC running. If it reads 12V, the motor needs replacing.Automatic Climate Control SystemAnother thing that causes the blower fan to malfunction is the Automatic Climate Control System (ACCS). If the ACCS's settings are off, it may cause the fan to stop working. If it is the climate control on the car, typically it is a bad thermostat or electrical circuit that is the culprit.
hope this helps, James Booth
Ac blower will not run while ac is turn on but run by itsself
That means you have lost 24 volts somewhere.
The most common causes for that are as follows.
1) a blown fuse. (usually a blade fuse mounted on the board)
2) a broken/loose/disconnected wire.
3) a bad 24V transformer.
When the unit loses control voltage (24V) it brings on the blower motor. This is done for safety reasons.
3helpful
1998 BMW 328i heater/AC blower is not running
You have clean the blower unit , may be its dirty then . and then check the blower resistor unit for malfunction.
Blower motor Issue
hmmm ...ok...we need to diagnose the brain...check fuses and relays ..anything related to a/c heat blower motor and power to head unit /blower resistor blower.... and advise..also... get code check to see if a soft code stored telling us the cause..... advise
Top Carrier Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Jay Finke
Jay Finke
Mike Cairns
Mike Cairns
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
