Question about Canon PowerShot SD550 / IXUS 750 Digital Camera
Canon sureshot sd550
I have a problem with my canon sd550. The lens does not come all the way out when I turn it on. Also the camera turns itself off with the lens partially extended in the picture taking mode. If I switch to the picture review mode the lens extens all the way out and back in smoothly. I think the camera jammed up when I waqs using the wide angle and inadvently pushed the shutter release (I don't know how I did that) the camera hasn't worked since.
  • 489 Answers
Hi
Your lens is definitely jammed, and needs to be repaired or replaced.
A couple solutions would be to either buy a defective camera online and make one good camera from the two if you can do that sort of thing yourself, or secondly have it repaired by somebody.
Don't bother trying to send the camera to Canon if it is out or warranty (though you can call them and verify what I'm about to say) because they will want $150+ to do the repair for you. Parts are not cheap to buy from them.
I know of one very affordable digital camera repair business... because I own it. The name is Darntoothysam, feel free to check us out, we are on that big auction website also (I don't plug their name for free), our seller ID is 'darntoothysam'. If you Google "darntoothysam" you will find us.
We have your repair listed as a package in our store for about $70. This covers a new lens, and return shipping of your camera! We even give a 45 day warranty on parts and labor. If you think you can use us then please check us out, even if you need to ask more questions then please feel free to contact me.
Hope this helps,
Thomas
Darntoothysam com
Posted on Oct 18, 2008
Lens won't retract on SD550
Try resetting the camera by removing the battery for 20 mins. then replace the battery go to the camera's menu and set the Date and Time.
May 28, 2012 | Canon PowerShot SD550 / IXUS 750 Digital...
PowerShot SD550 / IXUS 750 Digital Camera: when i turn on my cannon powershot sd550 it displa...
Hello
The problem is that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair centre for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
You can also have a look at THIS link.
Hope the advise is useful. please do not hesitate to let me know if you need any further assistance. Also, please be so kind to let me know if you found this helpful.
Regards
Andrea
May 16, 2010 | Canon PowerShot SD550 / IXUS 750 Digital...
My lens for my canon powershot SD550 is stuck open.when switching the camera power on E18 appears on the screen in the bottom left corner.
The E18 error is fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension.
Here are some things that you can do to try to correct it. They only seem to work for about 40% of lens errors, but if the camera is out of warranty they're worth a try.
Nov 15, 2009 | Canon PowerShot SD550 / IXUS 750 Digital...
Powershot sd550, when turn on showing error e18 and the lens are stuck out.
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Here are some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try.
Jul 17, 2009 | Canon IXUS V2 Digital Camera
My canon sd550 lens are not going down and when i try to take a picture it makes a funny noise and comes up with a blank screen
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Jun 15, 2009 | Canon PowerShot SD550 / IXUS 750 Digital...
Camera won't turn on and the lens is stuck
The lens cannot easily be repaired - they are so fragile it doesn't take much to break them - the camera won't come on properly because it is waiting for the lens to initialise first. suggest a nice friendly repairer or buy another it would be cheaper!!
Jun 16, 2008 | Canon PowerShot SD550 / IXUS 750 Digital...
Lens will not retract
I had a Canon IXUS II do this.
Unfortunately it required a new lens which the repairer could not supply due to its age. The repairer replaced the camera for the same cost with much more recent model! The repair cost was £70 plus postage. (This was 4 years ago now when a new camera would have cost over £199).
If its under warrantee use it - Sadly it might be cheaper at todays prices to replace it instead of have it fixed.
Mar 07, 2008 | Canon PowerShot SD550 / IXUS 750 Digital...
Have a powershot sd550
After many complaints Canon posted this on their web site: "The E18 error code may be displayed if you apply pressure to the zoom lens, lens barrier or surrounding area when handling the camera. Hold the camera so that your fingers do not touch the zoom lens."
There is a lot you can try...
Here is a list of pages with help on the E18 issue:
http://www.e18error.com/repair.html
http://www.bitnet.cx/canon.html
http://blogs.yucs.org/~dwallach/2004/08/canon_e18_error_repair_instruc.html
E18 is a lens error. My guess would be sand got into your lens (into the gears, etc.). These guys should be able to take care of you. http://www.darntoothysam.com/servlet/the-1730/Canon-Powershot-SD550-Camera/Detail
Feb 28, 2008 | Canon PowerShot SD550 / IXUS 750 Digital...
Lens trouble canon powershot sd 550
check here...http://www.fixya.com/support/t102982-e_18_problem
Oct 02, 2007 | Canon PowerShot SD550 / IXUS 750 Digital...
Canon PowerShot SD550 / IXUS 750 Digital Camera Logo
44 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
