Question about Sony Playstation 3 (PS3) Console
My ps3 wont stay on
My playstation 3 will not stay turned on. When I turn on the power the system starts to boot then turns off and beeps 3 times. Console will not accept any discs either.
  • 1 more comment
  • Anonymous Nov 16, 2008
    Im having the same problem. I thought maybe it was an overheating issue but I left it off overnight and still the same problem.
    Did you find a fix or have to send it in?
  • Anonymous Dec 05, 2008
    i have the same issue. Called sony, they said I have to send it in to be serviced. Cost out of warrenty is 149.
  • riverrat73 Feb 17, 2009
    I have the sane problem. Starts to power up then 3 beeps powers down and flashes red. I dont know what to do.
  • 23 Answers
This sounds like an over heating issue. Do any fans come on when you first start up the system?
Posted on Sep 14, 2008
My ps3 beeps three times and wont power on
If ur psP console wont start up....then the things to check are>>> 1.check ur power cable 2.check whether u have inserted the disc properly and precisely. 3.check the insertion of memory card... 4.check the video port.......
If the system turns on but then turns itself off, beeps at you and flashes it's lights at you then you have over heated the system.
click here to download repair guide
Dec 21, 2010 | Sony Playstation 3 (PS3) Console
My playstation 3 wont start up, I press the power on button and it goes to start but then switches off
Follow the procedure below to fix the problem on your ps3,
1. Turn off Playstation®3.
2. Hold the power button down; the system will turn on and turn off once again.
3. Once the System has been shutdown, re-press you finger until you hear 2 consecutive beeps
4. When you hear the 2 beeps take finger off power button.
5. You will be prompted to plug in your controller via USB and then hit the PS button
6. The Recovery menu will pop up.
The current Recovery Menu supports:
• Restart System: Restarts the PLAYSTATION®3 System.
• Restore Default Settings: Reset all system settings back to default.
• Restore File System: Checks for corrupt/missing system files.
• Rebuild Database: Rebuilds the OS for the PLAYSTATION®3.
• Restore PS3 System: Fresh restore; Deletes everything and starts from Scratch.
• System Update: Update the PLAYSTATION®3 System.
Take care.
Aug 25, 2010 | Sony Playstation 3 (PS3) Console
It turn on and it stay on the main screen
Try these steps below to see if it will fix the problem on your ps3,
Take care.
Jul 03, 2010 | Sony Playstation 3 (PS3) Console
My ps3 wont turn on i tryed to turn it on but it just turns rite back off how do i gett it to stay on
It seems that your ps3 is experiencing the yellow light of doom:
Try this: 1. Turn off Playstation®3.
Jun 14, 2010 | Sony Playstation 3 (PS3) Console
Wont read the disc .my sony playstation 3 wont read any disc.
The PS3 has a special Recovery Menu, which you can access in the following way:
1. Turn off Playstation 3.
• Restart System: Restarts the PLAYSTATION 3 System.
• Rebuild Database: Rebuilds the OS for the PLAYSTATION 3.
• System Update: Update the PLAYSTATION 3 System
From the above select option "Rebuild Database". After PS3 has executed this DB rebuilding operation, the disc games will be visible again in the menu.
Apr 07, 2010 | Sony Playstation 3 (PS3) Console
I turn my system on and it will not go to media icons
turn off switch on back of ps3 hold down the power switch on front then turn switch on the back on hold the front power switch till you hear 2 beeps then let go
Aug 27, 2009 | Sony Playstation 3 (PS3) Console
My ps3 wont turn on
Alright you need to put your ps3 in what is called "safe mode". First make sure there is no disc in the ps3, then turn off the ps3 in the back(main power switch), turn that switch back on, then hold the power button in front until you hear a total of 3 beeps, then let go, the light will be red, hold the power button again and you will hear 2 beep then a quick double beep, let go of power button and the light should stay green. A menu will appear, try all option working your way up from option 1 until it works. If you go through all 6 option and you are still having issues call 1-800-345-7669 to have your ps3 serviced
Aug 10, 2009 | Sony PlayStation 3 40GB System
My ps3 wont turn on
HI, the power supply is unstable or weak. you will need to replace this failing power supply soon. it is damaged.
Jun 16, 2009 | Sony Playstation 3 (PS3) Console
My playstation turns on and everything, but once i plug it in to any kind of television there is no picture or sound
Heres one solution that I found. If your ps3 turns on but does not boot up just stays a black screen most likely the hard drive got corrupted. So unfortunately you will lose all your saves. But to save the system when you power on the ps3 hold the button down its should beep once keep holding it and it should turn red in standby mode. Keep holding the power button down though. It should turn green again keep holding it should beep then double beep this time instead of going into standby. Let go now and some options will come onto the screen. You will need to plug in your ps3 controller and 6 options should come up. Reformat PS3 worked for me but I lost all my saves. Good luck!
Apr 06, 2009 | Sony Playstation 3 (PS3) Console
Nothing comes up on tv when i turn ps3 on and controllers wont connect
Read this very carefully. Turn off your ps3 from the back. Then turn it back on wait unit the light is red. Turn on the system through the front keep holding the power on. You will hear a beep one time that just tell you that the ps3 is powering on keep holding the button until you hear the second beep this will rest your video setting. If that dosnt work call me at sony
Nov 07, 2008 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
190 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
marley mcelhinney
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
