Question about Sharp Office Equipment & Supplies
Al1540cs problem I have had this copier for many years. has always worked great. recently when something is copied, it is turning out a single black line down the middle of the page. if copying a dark picture, is turning out a white line in the middle from the top to bottom.
Check the toner and cartiga
Posted on Sep 05, 2008
Black vertical line when copying a book page.no light leaks.
If it is along the edge of the print, it may be the edge of the book page you are seeing. if it is going through the text of the page, your scan carriage is likely skipping. If you don't see this on copies of single sheets of paper laid on the glass, then the weight of the book may be deforming the glass enough to catch the scan carriage as it passes. If you see it on single copied sheets, there is probably something on one of the scan rails under the glass that the carriage is "hopping" over as it passes. You could try watching the scan carriage move while holding the lid open to see if the carriage "hops" once during a scan.
Nov 10, 2013 | Panasonic KXMB2030 AllInOne Printer
Hi. I have a paragon 4001-00 timer hooked up to my pool filter. It's worked great for the last 25 years but recently it has become finicky. It will always turn off, but sometimes it won't turn...
If new X2772 tripper hasn't solve problem, it might be time for new timer.
http://waterheatertimer.org/Paragon-timers-and-manuals.html#4000
4001-00 is 120Volt single pole single throw timer in Nema1 indoor enclosure
Wiring terminals 1 2 3
Black Hot wire from breaker connects to terminal 1
Black wire going to load connects to terminal 2
White neutral wires connect to terminal 3
Crossover Intermatic timer is T101
http://waterheatertimer.org/How-to-wire-T104-Intermatic-timer.html#T101
Wiring terminals A 1 2
White neutral wires connect to terminal A
Jul 06, 2011 | Paragon 4001-00 24-hr Timer Control 120v...
Printer problems
UNPLUG THE PRINTER AND USE Q-TIPS AND RUBBING ALCOHOL TO CLEAN THE ROLLERS AND THE TRACK INSIDE OF PRINTER.THEN PLUG BACK IN AND SHOULD CLEAR UP THE PROBLEM.
Feb 10, 2009 | Epson Aculaser C1100 Printer
Single copy out of double original w/o using paper feeder
Does your machine have double siding capabilities?
If so on the control panel under original / copy. select 1:2, this will give you a double sided copy from a pair of single originals even off the glass.
Jan 13, 2009 | Minolta DI2510 Black and White Copier
Hello hope you can help me
You can download the driver here:
http://www.nodevice.com/driver/company/Lexmark.html
Just look for lexmark X5470.
Sep 13, 2008 | Lexmark X5470 All-In-One InkJet Printer
Al1540cs error h and 4 flashing it doesn't have same options like al1215
It looks like a fuser error. It isn't showing up at the right temp. Turn the power off, wait 30 seconds, turn the power back on again. If it reappears, you will need a technician to fix the problem.
Jul 16, 2008 | Sharp AL 1215 Black and White Copier
My copier won't print.
Are you sure that your scanner bulb is working. You may hear the scanner moving but the bulb may be burned out which will cause you to get blank pages.
Inkworks
May 13, 2008 | HP PSC 1210 All-In-One InkJet Printer
Scan and Copy Problem
Please click on the web link given below and download the drivers for HP PSC 1510 All-in-one.
CLick on download only button and save it to your desktop.
http://h10025.www1.hp.com/ewfrf/wc/softwareDownloadIndex?softwareitem=mp-47767-1&lc=en&cc=us&dlc=en&product=428800&os=2093
Have a great day!
Mar 19, 2008 | HP PSC 1510 All-In-One InkJet Printer
Dell AIO 962 copy & fax issues
Go to Dell AIO and click on maintenace/ Troubleshoot on top of the page. Then go to maintain or fix quality problems.
Then choose the problem and run it.
Nov 14, 2007 | Dell 962 Photo All-In-One InkJet Printer
135 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
