FixYa.com
Tags:
Rio Volt SP50 Personal CD Player
Display reads "open"
posted by Guest on Oct 07, 2005
The display of my CD player reads "open" even after I close it. The latch is intact and seems to be working. Any ideas what the problem could be?
Solution #1
posted on Apr 17, 2008
Not Rated (0)
LabRat3
Rank:Wiz Wiz
Rating: 82%, 35 votes
There is a small push tab that tells the playerthat the door is closed. If this small plastic contact is shortened or missing, the player will think the door is open. This needs to be fixed before you try and use the player. If you disable this contact so it always thinks the door is closed, the laser will remain active.
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
posted on Oct 06, 2007
Not Rated (0)
nwlorax
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
In the JVC cd/mp3 player, there is an almost invisible switch to the right and slightly up that I suspect the open/close latch internally engages when a cd/mp3 disk is placed in the player and it is closed.
I fixed this problem by taking a very, very small piece of folded paper and pressing it on the plastic pop-up for this switch.
Works like a charm, and the off and other buttons function normally.
Solution #3
posted on Jan 24, 2006
Not Rated (0)
silly girl
Rank:Wiz Wiz
Rating: 81%, 3239 votes
Hi!
on my Rio the contacts that tell it if its open or close are at the hinge side, 2 metal ribbons that come down from the cover side and touch other metal parts below them on the base side.
I'm not sure if this is the same on your model but check it, if not, then on yours it might detect open/close on the latch mechanism, so check to see if the latch action is normal, or if it feels kinky, sticky etc.
either way - locate the open/close sensors, and make sure they look allright, not bent, broken or dirty, and see what you can do about it.
have a nice day!
This Problem Also Relates To: GPX C3960 Personal CD Player GPX CDPW4604 Personal CD Player GPX MP3 Portable CD Player and Radio Personal CD Player GPX C3976 Personal CD Player GPX C3980RS Personal CD Player GPX C3947 Personal CD Player GPX C3971 Personal CD Player
Can you Help with these Personal CD Players problems?
Personal CD Players
I cant turn on my cd stereo
just stop it and no work any... Answer This...
Personal CD Players
won't play discs
6 cd changer just keeps loading... Answer This...
Personal CD Players
ERROR
Hi, I have a GPX portable cd... Answer This...
Personal CD Players
f61 error code
i have a ak640 hifi and get the... Answer This...
RioVolt SP50 Lock
My RioVolt SP50 is unusable... Answer This...
Repair Service
Find Personal CD Player Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
